查看: 1079|回复: 2
有关 Write To Spreadsheet File 的问题
发表于 2007-5-25 20:55:05 | 显示全部楼层 |阅读模式
各位好,我想请问一下,我用 write to spreadsheet file 函数来保存数据,数据由随数函数产生加上对应的时间(字符型),我把它们建成簇,但要保存时,老是连接类型不对,我想问题在于write to spreadsheet file 的Format 没设好,但我又不知要怎样设,请各位帮我解答一下,谢谢,下面有图:
 楼主| 发表于 2007-5-25 20:58:57 | 显示全部楼层
222
希望大家帮我一下,谢谢了。。。。
发表于 2007-5-25 22:39:03 | 显示全部楼层
you can't use cluster. consult the detail help.
2D data contains the single-precision numbers the VI writes to the file if 1D data is not wired or is empty.
1D data contains the single-precision numbers the VI writes to the file if this input is not empty. The VI converts the 1D array into a 2D array before proceeding. If transpose? is FALSE, each call to this VI creates a new line or row in the file.
The follow code only show you how to connect the 'write to spreadsheet file.vi' , you still need edit this vi to convert a time-string to a number.
GMT+8, 2026-9-30 10:49 , Processed in 0.040964 second(s), 13 queries , Gzip On, File On.
