查看: 2615|回复: 3
[求助]YM12232B的C语言程序
zcq353 该用户已被删除
发表于 2005-7-11 22:10:08 | 显示全部楼层 |阅读模式
<>最近老师让编译个LCD的C语言程序,弄的很郁闷,有没有哪位哥哥,姐姐做过 ,帮小弟个忙。</P>
<>hrbhustzhangchaoqi@163.com</P>
发表于 2005-7-11 22:13:10 | 显示全部楼层
这里有12232F的程序,没有用过12232B呢,我看看能不能找到,找到的话我贴上来发给你!
windy1985 该用户已被删除
发表于 2005-8-16 23:17:02 | 显示全部楼层
<>//12232B
#include&lt;ZIKU_new.c&gt;
#define i_m  XBYTE[0x370e]
#define i_s  XBYTE[0x570e]
#define d_m  XBYTE[0xb70e]
#define d_s  XBYTE[0xd70e]</P>
<>/*void delay(uint nn);
void write_char(x,y,array);
void write_chinese(x,y,array);
void lcd_init(void);
void clrscr(void);
void lw(uchar x,uchar y,uchar dd);
void send_command(uchar cmd);
sbit di=P2^7;
sbit e2=P2^6;
sbit e1=P2^5;</P>
<>void delay(uint nn){
  unsigned int mm;
  while(nn--&gt;0)
for(mm=0;mm&lt;5000;mm++){ };
}</P>
<P>
i_m=cmd;
i_s=cmd;
}</P>
<P>void lw(uchar x,uchar y,uchar dd)
if (x&lt;61)
  i_m=0xb8|y;
  i_m=0x00|x;
  d_m=dd;
  else
   x=x-61;
   i_s=0x00|x;
   i_s=0xb8|y;
   d_s=dd;
}</P>
<P>void clrscr(void)
uchar x,y;
for (y=0;y&lt;4;y++)
   for (x=0;x&lt;122;x++) lw(x,y,0);
}</P>
<P>void lcd_init(void)
{</P>
<P> send_command(0xe2);//reset
send_command(0xae);//off display
send_command(0xc0);//set display start line
send_command(0xa4);//off static drive
send_command(0x00);//set colume address
send_command(0xa9);//1/32 duty
send_command(0xa0);//adc select rightward output
send_command(0xee);//read modify write off
send_command(0xaf);//on display</P>
<P>}</P>
<P>void write_chinese(x,y,array)
unsigned char x,y;
unsigned char array[];
unsigned char j,dd;
for(j=0;j&lt;32;j++)
  dd=array[j];
  if(j&lt;16) lw(x+j,y,dd);
  else     lw(x+j-16,y+1,dd);
unsigned char x,y;
unsigned char j,dd;
for(j=0;j&lt;16;j++)
  dd=array[j];
  if(j&lt;8) lw(x+j,y,dd);
  else     lw(x+j-8,y+1,dd);
</P>
windy1985 该用户已被删除
发表于 2005-8-16 23:19:30 | 显示全部楼层
<>从网上找到的,我自己加了字库和几个子程序~按我的译码接好电路应该就可以用!</P>
GMT+8, 2026-9-28 08:39 , Processed in 0.039352 second(s), 13 queries , Gzip On, File On.
