查看: 1266|回复: 1
DAQMAX程序打包成EXE文件时出错处理!
发表于 2005-7-15 01:55:06 | 显示全部楼层 |阅读模式
<>今天我们的一个朋友说遇到了打包出错的问题,后来在我这里打包也出现了同样的错误,</P>
<>错误报告为:Error 7 occurred at Build Application.vi &gt;&gt; Dist Cmp Settings to Disk Hier.vi &gt;&gt; Dist Report Read Link Info Error.vi</P>
<>解决办法:只要在打包的界面上有一个application settings,将上面的Disconnect type definitions and remove unused polymorphic VI instances前面的check box取消掉就可以了,原文说明如下:</P>
<P>
Application Builder Hangs/Crashes when Trying to Build a DAQmx Base VI into an Application</P>
<P>Primary Software: Driver Software&gt;&gt;NI-DAQmx Base
Primary Software Version: 1.5</P>
<P>Primary Software Fixed Version: N/A</P>
<P>Secondary Software: N/A</P>
<P>Problem: I am trying to build an application that uses DAQmx Base 1.5 and it hangs in the middle, what is wrong?</P>
<P>Solution: If you uncheck the box to "Disconnect type definitions and remove unused polymorphic VI instances" the application should build without hanging. This behavior does not exist in DAQmx Base v1.4. In DAQmx Base v1.4, the Application Builder will give you an error if you have this box checked </P>
 楼主| 发表于 2005-7-15 01:56:09 | 显示全部楼层
这一次要感谢CPUBBS论坛网友fltt发的这个资料给我了,呵呵,非常谢谢!我以前也没有遇到过同类的问题!
GMT+8, 2026-9-29 00:20 , Processed in 0.027509 second(s), 8 queries , Gzip On, File On.
