查看: 1003|回复: 1
报表预览
发表于 2005-7-24 20:58:12 | 显示全部楼层 |阅读模式
在VI怎么先显示出来,然后再可以打印出来.前面标有1.到18.项目要能可以增删,对于多个文件,要能象最下面的报表形式要能增删,对于单个文件,不会出现平均和标准方差.各位能给一个例子吗?<img src="attachments/dvbbs/2005-7/2005724152835790.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2005-7/2005724152835790.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
[此贴子已经被作者于2005-7-24 15:29:07编辑过]
发表于 2005-7-25 06:45:40 | 显示全部楼层
可以把它输出到WORD里面是可以看到的,试试然后在LV中嵌入一个WORD的ACTIVX,这样做应该是可以的!但具体没有例子!
GMT+8, 2026-9-29 00:54 , Processed in 0.051600 second(s), 13 queries , Gzip On, File On.
