查看: 1756|回复: 1
[转帖]AT24Cxx i2c控制程序
发表于 2005-8-14 04:57:59 | 显示全部楼层 |阅读模式
<>  NAME Control_AT24Cxx</P>
<>; This collection of routines allows an AT89C2051 microcontroller to read
; and write the AT24Cxx family of serial CMOS EEPROMS. This version of the
; code is compatible only with the AT89C2051 due to the location of the
; data buffer and stack in RAM. The code may be modified to work with the
; AT89C1051 by relocating or resizing the buffer and stack to fit into the
; smaller amount of RAM available in the AT89C1051. Note that the minimum
; size of the buffer is determined by the page size of the AT24Cxx.
; All five AT24Cxx device operations are supported. Byte Write, Current
; Address Read and Random Read are implemented by the functions WRITE_BYTE,
; READ_CURRENT and READ_RANDOM, respectively. Page Write and Sequential Read
; are special cases of functions WRITE_BLOCK and READ_BLOCK, respectively.
; WRITE_BLOCK and READ_BLOCK process from one byte to the number of bytes
; in a page and transfer data between the AT24Cxx and the RAM buffer.
; The code supports multiple AT24Cxx devices per bus, each with a unique
; address determined by the wiring of the address pins (A0, A1, A2). The
; three-bit programmable address is passed to the WRITE_BYTE, READ_CURRENT,
; READ_RANDOM, WRITE_BLOCK and READ_BLOCK functions, where it is combined
; with the AT24Cxx fixed address (FADDR) and used to address a device on the
; bus. Refer to the AT24Cxx family data sheets for additional information on
; device addressing.
; Functions BYTE_FILL, VERIFY_BYTE_FILL, PAGE_FILL and VERIFY_PAGE_FILL are
; artifacts from the debug process and serve to illustrate the use of the
; device read and write functions with an AT24C64. To modify the code for a
; different member of the AT24Cxx family, simply redefine the values of SIZE
; (the number of bytes per device) and PSIZE (the number of bytes per page).
; To change the fill value, redefine FILL. To change the programmable portion
; of the device address, redefine PADDR to a value from zero to seven.
; The code meets all AT24Cxx family timing requirements when executed by an
; AT89Cx051 microcontroller with a 12 MHz clock. Code modifications may be
; required if a faster clock is substituted.</P>
FADDR  EQU 0a0h  ; fixed address for AT24Cxx EEPROMs
PADDR  EQU 0  ; programmable address (0..7)
SIZE  EQU 2000h  ; bytes per AT24C64
PSIZE  EQU 32  ; bytes per page for AT24C64
FILL  EQU 55h  ; example fill value</P>
<P>; Register definitions.</P>
<P>index  EQU r0  ; buffer pointer
kount  EQU r1  ; byte count register
zdata  EQU r1  ; data register
addr_lo  EQU r2  ; 2-byte address register
addr_hi  EQU r3  ;</P>
<P>; Microcontroller connections to AT24Cxx serial bus lines.</P>
<P>SCL  BIT p1.2  ; serial clock
SDA  BIT p1.3  ; serial data</P>
<P>
  DSEG AT 20H</P>
<P>  ORG 40H
buffer:  DS PSIZE  ; storage for read/write data</P>
<P>  ORG 60H  ; stack origin
stack:  DS 20H  ; stack depth</P>
<P>
  CSEG</P>
<P>  ORG 0000H  ; power on/reset vector
  jmp on_reset</P>
<P>  ORG 0003H  ; external interrupt 0 vector
  reti   ; undefined</P>
<P>  ORG 000BH  ; timer 0 overflow vector
<P>  ORG 0013H  ; external interrupt 1 vector
<P>  ORG 001BH  ; timer 1 overflow vector
<P>  ORG 0023H  ; serial I/O interrupt vector
<P>  ORG 0080H  ; begin code space
  USING 0  ; register bank zero
on_reset:
  mov sp, #(stack-1) ; initialize stack pointer</P>
<P>  ; Initialize AT24Cxx serial bus lines.</P>
<P>  setb SDA  ; high
  setb SCL  ; high</P>
<P>
  call byte_fill
  jc fault</P>
<P>  call verify_byte_fill
  jc fault</P>
<P>  call page_fill
  jc fault</P>
<P>  call verify_page_fill
  jc fault</P>
<P> fault:
  jmp $</P>
<P>
byte_fill:</P>
<P> ; Fill every byte in an AT24Cxx with the same value.
; Writes one address at a time (page mode is not used).
; Returns CY set to indicate write timeout.
; Destroys A, B, DPTR, XDATA, ADDR_HI:ADDR_LO.</P>
<P>  mov zdata, #FILL ; set up fill data
  mov dptr, #0 ; initialize address pointer
x51:
  mov addr_lo, dpl ; set up address
  mov addr_hi, dph ;</P>
<P>  mov b, #120  ; retry counter
x52:
  mov a, #PADDR ; programmable address
  call write_byte ; try to write
  jnc x53  ; jump if write OK</P>
<P>  djnz b, x52  ; try again
  setb c  ; set timeout error flag
  jmp x54  ; exit
x53:
  inc dptr   ; advance address pointer
;  mov a, dpl   ; check low byte
;  cjne a, #(LOW SIZE), x51 ; jump if not last
  mov a, dph   ; check high byte
  cjne a, #(HIGH SIZE), x51 ; jump if not last
  clr c   ; clear error flag
x54:
  ret</P>
<P>
verify_byte_fill:</P>
<P> ; Verify that all bytes in an AT24Cxx match a fill value.
; Reads and verifies one byte at a time (page mode is not used).
; Performs a Random Read function to initialize the internal
; address counter and checks the contents of the first address.
; Then performs multiple Current Address Read functions to step
; through the remaining addressess.
; Returns CY set to indicate read timeout or compare fail.
; Destroys A, B, DPTR.</P>
<P>  mov dptr, #0 ; initialize address pointer/counter
x81:
  call read_random ; try to read
  jnc x82  ; jump if read OK</P>
<P>  djnz b, x81  ; try again
  jmp x86  ; set error flag and exit
x82:
  cjne a, #FILL, x86 ; jump if compare error
  jmp x85  ; do remaining addresses
x83:
  mov a, #PADDR
  call read_current
  jc x87  ; jump if read fails</P>
<P>  cjne a, #FILL, x86 ; jump if compare error
x85:
  cjne a, #(HIGH SIZE), x83 ; jump if not last
  jmp x87  ; exit
x86:
  setb c  ; set error flag
x87:
  ret</P>
<P>
page_fill:</P>
; Writes one page at a time.
; Destroys A, B, DPTR, KOUNT, INDEX, ADDR_HI:ADDR_LO.</P>
<P>  ; First fill buffer.</P>
<P>  mov b, #PSIZE ; bytes per page
  mov index, #buffer ; point to buffer
x61:
  mov @index, #FILL ; put fill value in buffer
  inc index  ; advance pointer
  djnz b, x61  ; next byte</P>
<P>  ; Copy buffer to device, one page at a time.</P>
x62:
  mov addr_hi, dph ;
  mov kount, #PSIZE ; bytes per page</P>
x63:
  call write_block ; try to write
  jnc x64  ; jump if write OK</P>
<P>  djnz b, x63  ; try again
  jmp x66  ; exit
x64:
  ; Add page size to address pointer.</P>
<P>  mov a, dpl  ; get low byte
  add a, #PSIZE ; add page size
  mov dpl, a  ; save low byte
  jnc x65  ; jump if high byte not affected
  inc dph  ; increment high byte
x65:
;  cjne a, #(LOW SIZE), x62 ; jump if low byte not last
  cjne a, #(HIGH SIZE), x62 ; jump if not last
x66:
  ret</P>
<P>
verify_page_fill:</P>
; Reads and verifies one page at a time.
<P>  ; Copy device page to buffer.</P>
x71:
  mov addr_hi, dph ;
x72:
  call read_block ; try to read
  jnc x74  ; jump if read OK</P>
<P>  djnz b, x72  ; try again
x73:
  jmp x77  ; exit
x74:
  ; Verify buffer contents.</P>
x75:
  cjne @index, #FILL, x73 ; jump if compare fails
  djnz b, x75  ; next byte</P>
<P>  ; Add page size to address pointer.</P>
  jnc x76  ; jump if high byte not affected
x76:
;  cjne a, #(LOW SIZE), x71 ; jump if low byte not last
  cjne a, #(HIGH SIZE), x71 ; jump if not last
x77:
  ret</P>
<P>
write_block:</P>
<P> ; Write from one byte to one page of data to an AT24Cxx.
; Called with programmable address in A, address of first byte
; in register pair ADDR_HI:ADDR_LO, data in BUFFER, byte count
; in register KOUNT.
; Does not wait for write cycle to complete.
; Returns CY set to indicate that the bus is not available
; or that the addressed device failed to acknowledge.
; Destroys A, KOUNT, INDEX.</P>
<P>  call start
  jc x38  ; abort if bus not available</P>
<P>  rl a  ; programmable address to bits 3:1
  orl a, #FADDR ; add fixed address
  clr acc.0  ; specify write operation
  call shout  ; send device address
  jc x37  ; abort if no acknowledge</P>
<P>  mov a, addr_hi ; send high byte of address
  call shout  ;
<P>  mov a, addr_lo ; send low byte of address
  call shout  ;
<P>  mov index, #buffer ; point to buffer
x36:
  mov a, @index ; get data
  call shout  ; send data
<P>  inc index  ; advance buffer pointer
  djnz kount, x36 ; next byte
x37:
  call stop
x38:
  ret</P>
<P>
read_block:</P>
<P> ; Read from one byte to one page of data from an AT24Cxx.
; Performs a Random Read which is extended into a Sequential Read
; when more than one byte is read. Called with programmable address
; in A, address of first byte in register pair ADDR_HI:ADDR_LO,
; byte count in register KOUNT.
; Returns data in BUFFER. Returns CY set to indicate that the bus is
; not available or that the addressed device failed to acknowledge.
<P>  ; Send dummy write command to address first byte.</P>
<P>  call start
  jc x35  ; abort if bus not available</P>
  mov index, a ; save copy of device address
  jc x34  ; abort if no acknowledge</P>
  call shout  ;
  call shout  ;
<P>  ; Send read command and receive data.</P>
<P>  call start  ; second start for read
  jc x34  ; abort if bus not available</P>
<P>  mov a, index ; get device address
  setb acc.0  ; specify read operation
x31:
  call shin  ; receive data byte
  mov @index, a ; save data</P>
<P>  cjne kount, #1, x32 ; jump if not last byte
  call NAK  ; do not acknowledge last byte
  jmp x33  ; done
x32:
  call ACK  ; acknowledge byte
  djnz kount, x31 ; next byte
x33:
x34:
  call stop
x35:
  ret</P>
<P>
write_byte:</P>
<P> ; AT24Cxx Byte Write function.
; Called with programmable address in A, byte address in
; register pair ADDR_HI:ADDR_LO, data in register XDATA.
; Destroys A.</P>
<P>  call start
  jc x49  ; abort if bus not available</P>
  jc x48  ; abort if no acknowledge</P>
  call shout  ;
  call shout  ;
<P>  mov a, zdata ; get data
<P>  clr c  ; clear error flag
x48:
  call stop
x49:
  ret</P>
<P>
read_current:</P>
<P> ; AT24Cxx Current Address Read function.
; Called with programmable address in A. Returns data in A.
; or that the addressed device failed to acknowledge.</P>
<P>  call start
  jc x45  ; abort if bus not available</P>
  jc x44  ; abort if no acknowledge</P>
<P>  call shin  ; receive data byte
  call NAK  ; do not acknowledge byte
x44:
  call stop
x45:
  ret</P>
<P>
read_random:</P>
<P> ; AT24Cxx Random Read function.
; register pair ADDR_HI:ADDR_LO. Returns data in A.
<P>  push b
  mov b, a  ; save copy of programmable address</P>
<P>  ; Send dummy write command to set internal address.</P>
<P>  call start
  jc x47  ; abort if bus not available</P>
  jc x46  ; abort if no acknowledge</P>
  call shout  ;
  call shout  ;
<P>  ; Call Current Address Read function.</P>
<P>  mov a, b  ; get programmable address
  call read_current
  jmp x47  ; exit
x46:
  call stop
x47:
  pop b
  ret</P>
<P>
</P>
 楼主| 发表于 2005-8-14 04:58:20 | 显示全部楼层
start:<> ; Send START, defined as high-to-low SDA with SCL high.
; Return with SCL, SDA low.
; Returns CY set if bus is not available.</P><>  setb SDA
  setb SCL</P><>  ; Verify bus available.</P><P>  jnb SDA, x40 ; jump if not high
  jnb SCL, x40 ; jump if not high</P><P>  nop   ; enforce setup delay and cycle delay
  clr SDA
  nop   ; enforce hold delay
  nop   ;
  nop   ;
  nop   ;
  nop   ;
  clr SCL</P><P>  clr c  ; clear error flag
  jmp x41
x40:
x41:
  ret</P><P>
stop:</P><P> ; Send STOP, defined as low-to-high SDA with SCL high.
; SCL expected low on entry. Return with SCL, SDA high.</P><P>  clr SDA
  nop   ; enforce SCL low and data setup
  nop
  setb SCL
  nop   ;
  nop   ;
  nop   ;
  nop   ;
  setb SDA
  ret</P><P>
shout:</P><P> ; Shift out a byte to the AT24Cxx, most significant bit first.
; SCL, SDA expected low on entry. Return with SCL low.
; Called with data to send in A.
; Returns CY set to indicate failure by slave to acknowledge.
; Destroys A.</P><P>  push b
  mov b, #8  ; bit counter
x42:
  rlc a  ; move bit into CY
  mov SDA, c  ; output bit
  setb SCL  ; raise clock
  nop   ; enforce SCL high
  nop   ;
  nop   ;
  nop   ;
  clr SCL  ; drop clock
  djnz b, x42  ; next bit</P><P>  setb SDA  ; release SDA for ACK
  nop   ; enforce SCL low and tAA
  nop   ;
  setb SCL  ; raise ACK clock
  nop   ;
  nop   ;
  nop   ;
  mov c, SDA  ; get ACK bit
  clr SCL  ; drop ACK clock</P><P>  pop b
  ret</P><P>
shin:</P><P> ; Shift in a byte from the AT24Cxx, most significant bit first.
; SCL expected low on entry. Return with SCL low.
; Returns received data byte in A.</P><P>  setb SDA  ; make SDA an input</P><P>  push b
x43:
  nop   ;
  nop   ;
  nop   ;
  mov c, SDA  ; input bit
  rlc a  ; move bit into byte
  djnz b, x43  ; next bit</P><P>  pop b
  ret</P><P>
ACK:</P><P> ; Clock out an acknowledge bit (low).
; SCL expected low on entry. Return with SCL, SDA low.</P><P>  clr SDA  ; ACK bit
  nop   ;
  nop   ;
  nop   ;
  nop   ;
  ret</P><P>
NAK:</P><P> ; Clock out a negative acknowledge bit (high).
; SCL expected low on entry. Return with SCL low, SDA high.</P><P>  setb SDA  ; NAK bit
  nop   ;
  nop   ;
  nop   ;
  nop   ;
  ret</P><P>
  END
</P>
GMT+8, 2026-9-28 08:39 , Processed in 0.025439 second(s), 6 queries , Gzip On, File On.
