查看: 687|回复: 1
EASY I/O DAQ调试有错
发表于 2005-9-24 23:53:05 | 显示全部楼层 |阅读模式
<>大家好:</P>
<>          因为我在做了一个用EASY I/O DAQ里面函数的例子,调试时有这种错误:</P>
<> NON-FATAL RUN-TIME ERROR:   "EasyIO Sample.c", line 39, col 19, thread id 0x00000CC0:   Function nidaqAICreateTask: (return value == -10401 [0xffffd75f]). unknownDeviceError: The specified device is not a National Instruments product, the driver does not support the device (for example, the driver was released before the device was supported), or the device has not been configured using the Measurement &amp; Automation Explorer.</P>
<P>能有办法调试出来吗?
     </P>
 楼主| 发表于 2005-9-24 23:54:31 | 显示全部楼层
GMT+8, 2026-9-29 02:35 , Processed in 0.031720 second(s), 8 queries , Gzip On, File On.
