查看: 1854|回复: 6
[labview求助] 求大神帮助!急!谢谢大家:设置虚拟采集卡时提示重置设备时出现问题状态代码: -88705
发表于 2018-5-22 14:14:12 | 显示全部楼层 |阅读模式
我在设置虚拟采集卡的时候总是出现这个错误请问该怎么办?已经把所有的NI全都卸载又重新装了好几次了还是不行,请问该怎么办
重置设备时出现问题。
状态代码: -88705
指定设备不存在或者未在系统中激活。该设备可能未在系统中安装,或未插入设备,或者未正确安装设备。
(温馨提示:为了您的问题能更快得到解决,请将标题写得清晰些,易于吸引有相关经验的朋友进来解答,已帮您修改标题,好运!)
发表于 2018-5-22 14:57:16 | 显示全部楼层
Why Does My DAQ or Simulated DAQ Device Fail the MAX Self-Test With Error -88705?Updated Jan 10, 2018
Reported In
Software
  • Measurement and Automation Explorer (MAX)
Issue DetailsWhy is my DAQ or simulated DAQ device failing when I run a self-test in Measurement & Automation Explorer (MAX) with Error -88705 occurred at a Self-Test.
SolutionPotential causes and corresponding solutions for Error -88705 are stated below:NI Services Not Running
The NI Device Loader Windows Service (nidevldu) and/or NI Configuration Manager Service (is not running. Refer to the Why are NI Device Loader (nidevldu) and NI Configuration Manager Services Not Starting? document for more information on how to start these services.
Computer Restart Needed
This error is sometimes reported if the computer has not been restarted after the installation of the DAQmx driver. Please try restarting your computer.
Firmware Updated Needed
During a driver installation, firmware updates download with the driver for many NI DAQ devices. If you are using a USB devices, this problem can be fixed by unplugging and re-plugging the device.
发表于 2018-5-22 14:57:21 | 显示全部楼层
发表于 2018-5-22 14:57:55 | 显示全部楼层
主要看后面这里:
The NI Device Loader Windows Service (nidevldu) and/or NI Configuration Manager Service (is not running. Refer to theWhy are NI Device Loader (nidevldu) and NI Configuration Manager Services Not Starting? document for more information on how to start these services.
 楼主| 发表于 2018-5-22 15:29:42 | 显示全部楼层
Obama 发表于 2018-5-22 14:57
主要看后面这里:
SolutionPotential causes and corresponding solutions for Error -88705 are stated be ...
谢谢
发表于 2018-8-31 10:55:31 | 显示全部楼层
发表于 2021-3-20 18:32:29 | 显示全部楼层
楼主解决了吗,我遇到了和你一样的问题
GMT+8, 2026-9-28 06:22 , Processed in 0.032368 second(s), 6 queries , Gzip On, File On.
