查看: 940|回复: 2
GPIB的同步和非同步有什么差别?
发表于 2007-8-4 21:28:44 | 显示全部楼层 |阅读模式
GPIB write/read中有一个asynchronous和synchronous的选项,请问这两种模式有什么差别么?
发表于 2007-8-5 23:39:23 | 显示全部楼层
供参考
In terms of software driver calls, synchronous I/O makes a call to the driver on a given thread, and that thread blocks in the driver until the I/O either completes or times out. Nothing else can occur on that thread of execution. If you have set LabVIEW to run in single-threaded mode (or if you are running on Mac OS 8/9) then this means that nothing else at all can happen in LabVIEW while that I/O call is going on.
An asynchronous call means that control can return to LabVIE
W while the I/O is ongoing. LabVIEW can do other nice things like update the GUI. Then it can poll the driver periodically to see if it is done. You see that happening with a timeout of 0 so that LabVIEW remains in control of what it wants to happen when.
Dan Mondrik
Senior Software Engineer, NI-VISA
National Instruments
 楼主| 发表于 2007-8-6 07:07:23 | 显示全部楼层
GMT+8, 2026-9-30 17:07 , Processed in 0.023738 second(s), 7 queries , Gzip On, File On.
