查看: 3106|回复: 2
[转帖]DS18B20测温传感器C51源程序!
发表于 2005-11-5 20:22:44 | 显示全部楼层 |阅读模式
转贴自精诚电子:
*18B20驱动程序,DQ为数据口,接于P2.1
*11.0592M晶振,上拉4.7k电阻
*Author:fyb
*2005-3-25 11:23,OK!
#include<reg51.h>
#include<intrins.h>
#define uchar unsigned char
#define uint  unsigned int
sbit dq = P1^7;
bit  flag;
uint Temperature;
uchar temp_buff[9]; //存储读取的字节,read scratchpad为9字节,read rom ID为8字节
uchar id_buff[8];
uchar *p;
uchar crc_data;
uchar code CrcTable [256]={
0,  94, 188,  226,  97,  63,  221,  131,  194,  156,  126,  32,  163,  253,  31,  65,
157,  195,  33,  127,  252,  162,  64,  30,  95,  1,  227,  189,  62,  96,  130,  220,
35,  125,  159,  193,  66,  28,  254,  160,  225,  191,  93,  3,  128,  222,  60,  98,
190,  224,  2,  92,  223,  129,  99,  61,  124,  34,  192,  158,  29,  67,  161,  255,
70,  24,  250,  164,  39,  121,  155,  197,  132,  218,  56,  102,  229,  187,  89,  7,
219,  133, 103,  57,  186,  228,  6,  88,  25,  71,  165,  251,  120,  38,  196,  154,
101,  59, 217,  135,  4,  90,  184,  230,  167,  249,  27,  69,  198,  152,  122,  36,
248,  166, 68,  26,  153,  199,  37,  123,  58,  100,  134,  216,  91,  5,  231,  185,
140,  210, 48,  110,  237,  179,  81,  15,  78,  16,  242,  172,  47,  113,  147,  205,
17,  79,  173,  243,  112,  46,  204,  146,  211,  141,  111,  49,  178,  236,  14,  80,
175,  241, 19,  77,  206,  144,  114,  44,  109,  51,  209,  143,  12,  82,  176,  238,
50,  108,  142,  208,  83,  13,  239,  177,  240,  174,  76,  18,  145,  207,  45,  115,
202,  148, 118,  40,  171,  245,  23,  73,  8,  86,  180,  234,  105,  55,  213, 139,
87,  9,  235,  181,  54,  104,  138,  212,  149,  203,  41,  119,  244,  170,  72,  22,
233,  183,  85,  11,  136,  214,  52,  106,  43,  117,  151,  201,  74,  20,  246,  168,
116,  42,  200,  150,  21,  75,  169,  247,  182,  232,  10,  84,  215,  137,  107,  53};
*Function:延时处理
*parameter:
*Return:
*Modify:
void TempDelay (uchar us)
  while(us--);
*Function:18B20初始化
*parameter:
*Return:
*Modify:
void Init18b20 (void)
dq=1;
_nop_();
dq=0;
TempDelay(86);   //delay 530 uS//80
_nop_();
dq=1;
TempDelay(14);   //delay 100 uS//14
_nop_();
_nop_();
_nop_();
if(dq==0)
  flag = 1;   //detect 1820 success!
else
  flag = 0;    //detect 1820 fail!
TempDelay(20);       //20
_nop_();
_nop_();
dq = 1;
*Function:向18B20写入一个字节
*parameter:
*Return:
*Modify:
void WriteByte (uchar wr)  //单字节写入
uchar i;
for (i=0;i<8;i++)
  dq = 0;
  _nop_();
  dq=wr&0x01;
  TempDelay(5);   //delay 45 uS //5
  _nop_();
  _nop_();
  dq=1;
  wr >>= 1;
*Function:读18B20的一个字节
*parameter:
*Return:
*Modify:
uchar ReadByte (void)     //读取单字节
uchar i,u=0;
for(i=0;i<8;i++)
  dq = 0;
  u >>= 1;
  dq = 1;
  if(dq==1)
  u |= 0x80;
  TempDelay (4);
  _nop_();
return(u);
*Function:读18B20
*parameter:
*Return:
*Modify:
void read_bytes (uchar j)
  uchar i;
  for(i=0;i<j;i++)
[此贴子已经被作者于2005-11-7 10:16:24编辑过]
 楼主| 发表于 2005-11-7 20:24:44 | 显示全部楼层
<>再贴一个汇编的:转自C51BBS:</P>
<>;12位分辨率DS18B20程序<BR>;======================================================================<BR>;由于公司代理服务器的限制,不能ftp到laogu.com,如果您<BR>;需更多的DS18B20(C51/PIC/DSP)资料,QQ:432656<BR>;12G最新版本的各种软件,操作系统/编程/代码/资料<BR>;哪位好心人帮我上传一些软件,谢谢!<BR>;======================================================================<BR>;下面代码是本人在前人的基础上,吸收优化,适合本人实际应用。<BR>;;特点:<BR>;1.防止定时器打断时序;<BR>;2.考虑了DS18B20损坏或者断线,单片机不会死循环;<BR>;3.具备补码=〉原码;<BR>;4.复位不正常时给出温度-55度,提醒用户检查;<BR>;5.稳定性:冰水 0度-&gt;用电吹风 120度-&gt;冰水 0度 正常//测试时请不要把引脚弄湿短路<BR>;6.破坏性:加热到150度以上,再降温到120度,软件正常显示实际温度;      <BR>;注意:<BR>;在调试中,发现时序与DS18B20的批次有关,不同批次需要微调时序;<BR>;如果发现结果错误,请先调整debug 1,不行再依次调整debug 2,debug 3……<BR>;或许全部都要调整,看你运气 ^_^;<BR>;CPU    AT89C52        11.0592MHz<BR>;DQ        BIT    P1.7<BR>;**********************************************************************<BR>;[DS18B20模块]//12位分辨率<BR>;检测DS18B20的温度,最多检测3次;如果失败,给出-55度<BR>;出口S1820_L,DS1820_H<BR>;使用资源:A,C,R0,R6,R7,TH0<BR>;Edited by hello 2002/08/19/22<BR>;Changed by hello 2002/08/20/16/06||禁止修改||<BR>;----------------------------------------------------------------------<BR>DS1820:<BR>    MOV    DS1820_L,#70H<BR>    MOV    DS1820_H,#83H<BR>    MOV    TH0,#00        ;防止中断打乱时序<BR>    MOV    R1,#03<BR>DS1820_1:<BR>    LCALL    RE1820        ;RESET DS1820<BR>    JNZ    DS1820_9    ;RESET FAIL<BR>    MOV    TH0,#00        ;防止中断打乱时序<BR>    MOV    A,#0CCH        ;SKIP ROM<BR>    LCALL    WR1820    <BR>    MOV    A,#44H        ;CONVER T<BR>    LCALL    WR1820<BR>    MOV    A,#8        ;/debug 4        <BR>    LCALL    DL100M        ;100ms<BR>    MOV    TH0,#00<BR>    LCALL    RE1820        ;RESET DS1820<BR>    JNZ    DS1820_9    ;RESET FAIL<BR>    MOV    A,#0CCH        ;SKIP ROM<BR>    LCALL    WR1820<BR>    MOV    TH0,#00        ;防止中断打乱时序<BR>    MOV    A,#0BEH        ;Read scratchpad<BR>    LCALL    WR1820<BR>    MOV    TH0,#00        ;防止中断打乱时序<BR>    LCALL    RD1820<BR>    MOV    DS1820_L,A<BR>    LCALL    RD1820<BR>    MOV    DS1820_H,A    ;采样完成<BR>    ;SJMP    DS1820_EXIT<BR>    CJNE    A,#80H,$+3    ;以下给同事提供方便,将补码还原成原码<BR>    JC    DS1820_EXIT<BR>    CPL    A<BR>    SETB    ACC.7<BR>    MOV    DS1820_H,A<BR>    MOV    A,DS1820_L<BR>    CPL    A<BR>    INC    A<BR>    MOV    DS1820_L,A<BR>    SJMP    DS1820_EXIT<BR>DS1820_9:<BR>    DJNZ    R1,DS1820_1<BR>DS1820_EXIT:    <BR>    RET<BR>;-------------------------------------------------------------------------<BR>;[DS1820复位模块]<BR>;出口:A<BR>;复位成功:A=#0,复位失败:A=#0FFH<BR>;使用资源:A,R7<BR>;Edited by hello 2002/08/20<BR>;-------------------------------------------------------------------------<BR>RE1820:<BR>    MOV    A,#00H        ;RESET DS1820 OK<BR>    CLR    DQ<BR>    MOV    R7,#100<BR>    DJNZ    R7,$<BR>    DJNZ    R7,$    <BR>    ;DQ=#0,DELAY=255*2+100*2=710us  /debug 3<BR>    SETB    DQ<BR>    MOV    R7,#35<BR>    DJNZ    R7,$        ;DQ=#1,DELAY=35*2=70us    <BR>    /debug 3<BR>    JNB    DQ,RE1820_1    ;RESET OK,GOTO RE1820_1<BR>    MOV    A,#0FFH        ;FAIL,A=#0FFH    <BR>RE1820_1:<BR>    MOV    R7,#240<BR>    DJNZ    R7,$        ;DELAY=160*2=320us    <BR>    /debug 3<BR>    RET<BR>;------------------------------------------------------------------------<BR>;[DS1820写1个字节]<BR>;入口:A<BR>;使用资源:A,C,R6,R7<BR>;Edited by hello 2002/08/20<BR>;------------------------------------------------------------------------<BR>WR1820:<BR>    MOV    R6,#08        ;1B=8bit<BR>WR1820_1:<BR>    CLR    DQ<BR>    MOV    R7,#6<BR>    DJNZ    R7,$        ;DQ=#0,DELAY=7*2=15us    //debug    2<BR>    RRC    A        ;1us<BR>    MOV    DQ,C        ;1us<BR>    MOV    R7,#25<BR>    DJNZ    R7,$        ;DQ=#1,20*2=60us    //debug    2<BR>        <BR>    SETB    DQ<BR>    NOP<BR>    NOP<BR>    DJNZ    R6,WR1820_1<BR>    SETB    DQ<BR>    RET<BR>;----------------------------------------------------------------------<BR>;[DS1820读1个字节]<BR>;出口    :A<BR>;使用资源:A,C,R6,R7<BR>;Edited by hello 2002/08/20    <BR>;----------------------------------------------------------------------<BR>RD1820:<BR>    MOV    R6,#08<BR>RD1820_1:<BR>    SETB    DQ<BR>    NOP<BR>    NOP<BR>    NOP<BR>    CLR    DQ<BR>    NOP<BR>    NOP<BR>    NOP            <BR>    SETB    DQ<BR>    MOV    R7,#7<BR>    DJNZ    R7,$        ;DQ=1,9*2=18us    <BR>    //debug    1<BR>    MOV    C,DQ<BR>    RRC    A<BR>    MOV    R7,#7<BR>    DJNZ    R7,$        ;DQ=1,9*2=18us    <BR>    //debug    1    <BR>        NOP<BR>    DJNZ    R6,RD1820_1<BR>    RET            <BR>;----------------------------------------------------------------------<BR>;**********************************************************************</P>
 楼主| 发表于 2005-11-7 20:25:41 | 显示全部楼层
<><STRONG>DS18B20testcode:</STRONG></P>
<>//*******************************************<BR>//  DS18B20 with 51 core driver<BR>//  use 6MHZ osc  <BR>//  Create Time: 2005 08 18 <BR>//  Modify Time: <BR>//********************************************<BR> <BR>#include"REG51.h"<BR>#include"Uart.h"<BR>#include "INTRINS.h"<BR><BR>sbit DS18B20Pin = P3^5;<BR>unsigned char TempBuffer[10];<BR><BR>//#define SYSTEMDELAY(unsigned int wDelayIndex) {for(wDelayIndex = 100; <BR>wDelayIndex &gt; 0; wDelayIndex-- );}<BR>//********************************************<BR>// Function declare <BR>//********************************************<BR>void SystemDelay( int t);<BR>unsigned char BusWireReset(void);<BR>unsigned char DS18B20ReadSingleByte();<BR>void DS18B20WireSingleByte( unsigned char);<BR>void Read_Temperature(void);<BR><BR><BR>//========================================================<BR><BR>void SystemDelay(int t )<BR>{<BR> <BR>     while(t--);<BR>}<BR>//========================================================<BR><BR><BR>void InitMCUSet(void)<BR>{<BR>    P0 = 0xff;<BR>    <BR>    DS18B20Pin = 1;<BR>    TMOD = 0x21;   //TIME1 use mode 2 reload count ; Time0 use mode 1<BR>    TCON = 0x40;<BR>    SCON = 0x50;  <BR>    PCON = 0x80;  //SMOD = 1;<BR>    TL1  = 0xf3;  //BaudRate is 2400bps  <BR>    TH1  = 0xf3;<BR>    TH0 = 0;<BR>    TL0 = 0;   <BR>    IE   = 0x90;   //EA = 1; ET0 = 0;<BR>    // ET0 = 1;<BR>    // EX0 = 1;<BR>}<BR>//========================================================<BR><BR>unsigned char BusWireReset()<BR>{<BR> <BR>  unsigned char ucFlag = 0;<BR>  DS18B20Pin = 0;<BR> <BR>  SystemDelay(23);<BR>  DS18B20Pin = 1;<BR>  SystemDelay(2);<BR>//_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();<BR>  ucFlag =  DS18B20Pin ;  // if DS18B20PIN == 0 then find device<BR>  SystemDelay(18);<BR>  return ucFlag;     <BR>}<BR>//========================================================<BR><BR>unsigned char DS18B20ReadSingleByte()<BR>{<BR> unsigned char ucData ;<BR> unsigned char i;<BR><BR> for( i = 0; i &lt; 8; i++)<BR> {<BR>  DS18B20Pin = 0;<BR>  _nop_();<BR>  DS18B20Pin = 1;<BR>  _nop_();_nop_(); _nop_();_nop_(); _nop_();_nop_(); <BR>  ucData &gt;&gt;= 1;<BR>  ucData |= (DS18B20Pin == 1)? 0x80:0x00;<BR>  <BR>  SystemDelay(3);<BR> }<BR>// SystemDelay(3);<BR> return ucData;<BR>}<BR>//========================================================<BR><BR>void DS18B20WireSingleByte( unsigned char ucData)<BR>{<BR>     unsigned char i;<BR> for( i = 0; i &lt; 8; i++)<BR> {<BR>    DS18B20Pin = 0;<BR>    DS18B20Pin =  ((ucData &amp; 0x01) == 0x01);<BR>    ucData &gt;&gt;=1;    <BR> <BR>    SystemDelay(3);<BR>    DS18B20Pin = 1;<BR> }<BR>  <BR> // SystemDelay(3);<BR>}<BR>  <BR>//========================================================<BR><BR>void Read_Temperature(void)<BR>{<BR>    unsigned char i;<BR>     <BR>    if(BusWireReset() == 0) UART_SendMultiByte(SucessTable,3 );<BR>    DS18B20WireSingleByte(0xCC); //Skip ROM<BR>    DS18B20WireSingleByte(0x44); // Start Conversion<BR>    //SYSTEMDELAY(2);<BR>    SystemDelay(2);<BR>     <BR>    if(BusWireReset()==0) UART_SendMultiByte(SucessTable,3 );<BR>    DS18B20WireSingleByte(0xcc); // Skip ROM<BR>    DS18B20WireSingleByte(0xBE);  // Read Scratch Pad<BR>    for( i = 0; i &lt; 8; i++)<BR>    {<BR>        TempBuffer = DS18B20ReadSingleByte();<BR>    }<BR>         UART_SendMultiByte(TempBuffer,2);<BR>}<BR> <BR>//========================================================<BR><BR>void main(void)<BR>{<BR> InitMCUSet();<BR> UART_SendMultiByte(HexTable,16);<BR><BR> while(1)<BR>{ <BR> Read_Temperature();<BR> SystemDelay(30000);<BR>   <BR> }<BR>}<BR><BR><BR><BR>#ifndef __UART_H__ <BR>#define __UART_H__ <BR><BR><BR>//#include"Definetype.h"<BR><BR>//#define SYSCLK      11059200 <BR>#define SYSCLK        20000000 <BR>#define BAUDRATE0   9600<BR>#define DB_SENDMAXSIZE 0x10<BR>#define DB_RECMAXSIZE  0x10<BR><BR><BR>#define UART_LENGTH_R   1<BR>#define UART_COMMEND_R  2<BR>#define UART_DATA_R     3<BR>#define UART_VERIFY_R   4<BR><BR>#define UART_LENGTH_SEND   1<BR>#define UART_COMMEND_SEND  2<BR>#define UART_DATA_SEND     3<BR>#define UART_VERIFY_SEND   4 <BR><BR>bit  g_bReceiveSuccess  = 0;<BR>unsigned char g_ucReceiveIndex = 0; <BR>unsigned char g_ucRecvStyle = UART_LENGTH_R; <BR><BR>unsigned char g_ucSendIndex = 0;<BR>unsigned char g_ucSendStyle ;<BR>unsigned char  g_ucVerifySum;<BR><BR>#define UART_BUFFERSIZE  0x0f   // Length + Commend + Datas + SumVerify<BR>#define COMMEND     0x0A<BR><BR>char    code     HexTable[]={"0123456789ABCDEF"}; <BR>unsigned char   code    SucessTable[]= {0x00,0x01,0x02};<BR><BR>struct UartPackage <BR>{<BR>  unsigned char ucLength;<BR>  unsigned char ucCommend;<BR>  unsigned char ucDataBuffers[12];<BR>  unsigned char ucVerifySum;     <BR>};<BR><BR>struct UartPackage  UartRX,UartTX; <BR><BR>//void UART_SendMultiByte( unsigned char  *Buffer ,unsigned ucLenth); <BR>void UART_SendMultiByte( unsigned char  *Buffer ,unsigned ucLenth)<BR>{<BR> unsigned char i;<BR> ES = 0;<BR> for(i = 0; i &lt; ucLenth; i++)<BR> {<BR> SBUF = Buffer;<BR> while(!TI); TI = 0;<BR> }<BR> ES = 1;<BR><BR>}<BR><BR><BR><BR><BR>#endif<BR></P>
GMT+8, 2026-9-28 11:30 , Processed in 0.025752 second(s), 7 queries , Gzip On, File On.
