查看: 1374|回复: 1
SOS!生成安装文件问题。
发表于 2007-9-3 09:07:04 | 显示全部楼层 |阅读模式
我用labview的信号处理工具包做了小波变换的程序,在生成应用文件和安装文件后在其他计算机上提示找不到一个文件为instrib.in下面的WA.dll文件,还有一些工具包里的文件,都是高级信号处理工具包的文件,一直不能运行,跪求达人指点!谢谢!
发表于 2007-9-3 21:25:40 | 显示全部楼层
Why Is My Application Looking for LVWA.dll, WACore.dll, or WARef.dll?
Primary Software: LabVIEW Toolkits>>Advanced Signal Processing Toolset
Primary Software Version: 1.0
Primary Software Fixed Version:
Secondary Software:
Problem:
My LabVIEW application using the LabVIEW Advanced Signal Processing Toolkit runs fine on my development machine. I built an application and am trying to install and run it on a host machine, but the application is asking for LVSA.dll, WACore.dll, or WARef.dll. Where can I find these and how can I include them with my executable?
Solution:
When distributing applications with the NI LabVIEW Advanced Signal Processing Toolkit, you should include the following files as Support Files when you build your executable:
LVWA.dll, found in your C:\Program Files\National Instruments\Advanced Signal Processing Toolkit\SPT 7.0 Start-Up Kit\data directory
WACore.dll, found in your C:\WINDOWS\system32 directory.
WARef.dll, found in your C:\WINDOWS\system32 directory.
GMT+8, 2026-9-30 16:10 , Processed in 0.027529 second(s), 7 queries , Gzip On, File On.
