查看: 853|回复: 2
如何实时监控一个文件的变化
发表于 2007-9-11 23:16:23 | 显示全部楼层 |阅读模式
I have a file that generate by another program, The program will add more content to this file. So my question is , When this file have been changed, how labview program can be informed and catch out the difference before the old files.
  In another word, when the file have been udpated, I need the update content ,but the original content is not necessary to deal with. Then I can start to deal with the new-adding part.
Thanks a lot for your suggestion.
发表于 2007-9-12 08:44:42 | 显示全部楼层
要看你那个文件的格式吧,如果是普通的TXT文件,你可以一个字符一个字符比较,如果是二进制文件那就没有办法了哦.
发表于 2007-9-12 09:48:48 | 显示全部楼层
GMT+8, 2026-9-30 16:10 , Processed in 0.028208 second(s), 7 queries , Gzip On, File On.
