貌似上面没说清楚。。。。。
[0-9]+中的这个+,是取所有满足[0-9]的最大可能的,还是把help里这话贴出来比较清楚些:
Matches the longest number of instances of the expression preceding +; there must be at least one instance to constitute a match. For example, be+t matches bet and beet but not bt.
满足最大数目的instance,并且至少有一个instance得到满足?嘿,翻译的好差。。。。丢脸了
