查看: 3519|回复: 6
如何制作MP3播放器
发表于 2007-9-30 09:10:47 | 显示全部楼层 |阅读模式
在LabView8.20里该怎么制作一个MP3播放器呢?
example里有个播放器的例子,但是只能播放.wav格式的波形文件.
发表于 2007-10-1 10:14:42 | 显示全部楼层
发表于 2007-10-1 19:58:07 | 显示全部楼层
论坛精华列表贴中有收录的,好运!有源码的,呵呵,国庆快乐!
 楼主| 发表于 2007-10-2 09:04:33 | 显示全部楼层
回复 #3 cpubbs 的帖子
我下来用了,一运行cpu就100%,我的是labview 8.2的版本
 楼主| 发表于 2007-10-2 09:05:20 | 显示全部楼层
那个mp3播放器里面的read me
GAMP (pronounced JeeAMP) is an MP3 player for the LabVIEW Windows platform.
-It includes a playlist feature that allows continuous play and random shuffle.
-GAMP uses ActiveX to control the Windows Media Player.
-This VI has a "virtual" titlebar.  This is accomplished using the LabVIEW Win32 utilities that are downloadable from NI's website.You do not need to download the utilities as I have included the necessary VIs in the LLB file.
***Important***
You need to include the "LVWUtil32.dll" file in the same directory as GAMP.llb
GAMP was created by Jim Kring, Cal-Bay Systems, Inc.
发表于 2007-10-26 09:05:15 | 显示全部楼层
 楼主| 发表于 2007-11-7 09:04:27 | 显示全部楼层
谢谢楼上的兄弟啊,确实加个延时就可以了
GMT+8, 2026-9-30 14:10 , Processed in 0.041550 second(s), 7 queries , Gzip On, File On.
