查看: 1846|回复: 3
关于USB配置问题
发表于 2007-9-30 11:14:29 | 显示全部楼层 |阅读模式
现有一USB设备,而且有他的驱动程序。我现在想知道怎么去配置这些参数
现他驱动的INF如下:
;; Rigolusb.inf
;; *********  PLEASE READ ***********
;; The wizard cannot create exact INF files for all buses and device types.
;; You may have to make changes to this file in order to get your device to
;; install. In particular, hardware IDs and logical configurations require
;; intervention.
;; The Windows DDK documentation contains an excellent INF reference.
;--------- Version Section ---------------------------------------------------
[Version]
Signature="$Windows 95$"
Provider="Rigol Technologies"
; If device fits one of the standard classes, use the name and GUID here,
; otherwise create your own device class and GUID as this example shows.
Class="USB Test and Measurement Device"
ClassGUID={ff646f80-8def-11d2-9449-00105a075f6b}
; "68" is the ASCII code for "D" and is compliant with other Rgiol drivers:
DriverVer=08/13/2005,68.1.0.0
;--------- SourceDiskNames and SourceDiskFiles Section -----------------------
; These sections identify source disks and files for installation.  They are
; shown here as an example, but commented out.
;[SourceDisksNames]
;1 = "Install Disk",Disk1,,
;[SourceDisksFiles]
;Rigolusb.sys = 1
;Rigolusb.inf = 1
;--------- ClassInstall/ClassInstall32 Section -------------------------------
; Not necessary if using a standard class
; 9X Style
[ClassInstall]
Addreg=Class_AddReg
; NT Style
[ClassInstall32]
Addreg=Class_AddReg
[Class_AddReg]
HKR,,,,"Rigol USB Test and Measurement Device"
HKR,,Icon,,"-20"
;--------- DestinationDirs Section -------------------------------------------
[DestinationDirs]
Rigolusb_Files_Driver = 10,System32\Drivers
;--------- Manufacturer and Models Sections ----------------------------------
[Manufacturer]
%MfgName%= RIGOL Technologies
[RIGOL Technologies]
;%DeviceDesc%=Rigolusb_DDI, USB\VID_0400&PID_05dc
%DeviceDesc%=Rigolusb_DDI, USB\Class_FE&SubClass_03&PROT_00
%DeviceDesc%=Rigolusb_DDI, USB\Class_FE&SubClass_03&PROT_01
;---------- DDInstall Sections -----------------------------------------------
; --------- Windows 9X -----------------
; Experimentation has shown that DDInstall root names greater than 19 characters
; cause problems in Windows 98
[Rigolusb_DDI]
CopyFiles=Rigolusb_Files_Driver
AddReg=Rigolusb_9X_AddReg
[Rigolusb_9X_AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,Rigolusb.sys
HKR, "Parameters", "BreakOnEntry", 0x00010001, 0
; --------- Windows NT -----------------
[Rigolusb_DDI.NT]
AddReg=Rigolusb_NT_AddReg
[Rigolusb_DDI.NT.Services]
Addservice = Rigolusb, 0x00000002, Rigolusb_AddService
[Rigolusb_AddService]
DisplayName    = %SvcDesc%
ServiceType    = 1                  ; SERVICE_KERNEL_DRIVER
StartType      = 3                  ; SERVICE_DEMAND_START
ErrorControl   = 1                  ; SERVICE_ERROR_NORMAL
ServiceBinary  = %10%\System32\Drivers\Rigolusb.sys
[Rigolusb_NT_AddReg]
HKLM, "System\CurrentControlSet\Services\Rigolusb\Parameters",\
; --------- Files (common) -------------
[Rigolusb_Files_Driver]
Rigolusb.sys
;--------- Strings Section ---------------------------------------------------
[Strings]
ProviderName="Rigol Technologies"
MfgName="Rigol Technologies"
DeviceDesc="Rigol USB Test and Measurement Device"
DeviceClassName="USB Test and Measurement Device"
SvcDesc="Rigol USBTMC"
发表于 2007-9-30 16:21:23 | 显示全部楼层
兄弟,你这个是RIGOL的示波器还是其他的仪器啊?
我用过DS1102CD
哪个USB驱动好象是用来和他们的上位机软件相连的
还有一个是动态连接库
可以在LV里面调用的
 楼主| 发表于 2007-9-30 23:54:44 | 显示全部楼层
我用的是他们的万用表,我知道他有个自带的DLL文件,可以用API来操作。但容易出问题,而且很麻烦;如果能配置VISA 的USB是最好了,就不用那么麻烦了
 楼主| 发表于 2007-10-9 12:15:51 | 显示全部楼层
难道都没人懂得配置吗?
GMT+8, 2026-9-30 15:10 , Processed in 0.027581 second(s), 7 queries , Gzip On, File On.
