查看: 3460|回复: 2
labview板卡中接口中针脚PFI是什么的缩写啊?
发表于 2007-12-18 09:22:05 | 显示全部楼层 |阅读模式
labview板卡中接口中针脚PFI是什么的缩写啊?总是不知道这个是什么意思
发表于 2007-12-18 22:00:58 | 显示全部楼层
PFI lines are multipurpose programmable function input/outputs. These lines serve as connections to virtually all internal timing signals. Many NI high-speed digitizers have two digital lines that can import a trigger, import or export a reference clock, or output various signals. The function of each PFI line is independent. However, only one trigger source can be imported during acquisition.
Caution  If you enable a PFI line for output, do not connect any external signal source to it; doing so can damage the device, the computer, and the connected equipment.
 楼主| 发表于 2007-12-21 16:23:20 | 显示全部楼层
谢谢斑竹^_^好热心的斑竹
GMT+8, 2026-9-30 12:31 , Processed in 0.030012 second(s), 7 queries , Gzip On, File On.
