查看: 830|回复: 0
想问一下PCI-7334的问题,谢谢
发表于 2008-2-22 09:21:47 | 显示全部楼层 |阅读模式
Limit switch , home switch 有什么区别 ?说明书上是这样说的
Axis <1..4> Forward Limit Input
&#8226; Axis <1..4> Home Input
&#8226; Axis <1..4> Reverse Limit Input
These inputs are typically connected to limit switches located at physical
ends of travel and/or at a specific home position。用的是or?
GMT+8, 2026-9-30 11:25 , Processed in 0.022628 second(s), 7 queries , Gzip On, File On.
