查看: 796|回复: 1
NI 5422的问题
flora6677 该用户已被删除
发表于 2008-4-23 13:23:56 | 显示全部楼层 |阅读模式
NI PXI-5422硬件前面板上的PFI0/1连接头是起个什么作用的?
发表于 2008-4-24 22:44:51 | 显示全部楼层
好东东呀
PFI lines are multipurpose programmable function input/outputs. These lines serve as connections to virtually all internal timing signals. Many NI high-speed digitizers have two digital lines that can import a trigger, import or export a reference clock, or output various signals. The function of each PFI line is independent. However, only one trigger source can be imported during acquisition.
Caution  If you enable a PFI line for output, do not connect any external signal source to it; doing so can damage the device, the computer, and the connected equipment.
GMT+8, 2026-9-30 08:34 , Processed in 0.044089 second(s), 14 queries , Gzip On, File On.
