查看: 2135|回复: 4
AT89C2051驱动步进电机的电路和源码
发表于 2004-11-26 01:48:27 | 显示全部楼层 |阅读模式
<>电路如图所示:</P>
<><img src="attachments/dvbbs/2004-11/2004112517489628.gif" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2004-11/2004112517489628.gif\');}" onmousewheel="return imgzoom(this);" alt="" /></P>
<>程序
stepper.c
stepper.hex </P>
<P>/*
* STEPPER.C
* sweeping stepper's rotor cw and cww 400 steps
* Copyright (c) 1999 by W.Sirichote
*/ </P>
<P>#include c:\mc51\8051io.h /* include i/o header file */
#include c:\mc51\8051reg.h </P>
<P>register unsigned char j,flag1,temp;
register unsigned int cw_n,ccw_n; </P>
<P>unsigned char step[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90}
#define n 400 </P>
<P>/* flag1 mask byte
0x01 run cw()
0x02 run ccw()
*/ </P>
<P>main() </P>
<P>{
flag1=0;
serinit(9600);
disable(); /* no need timer interrupt */
cw_n = n; /* initial step number for cw */
flag1 |=0x01; /* initial enable cw() */ </P>
<P>while(1){
tick_wait(); /* wait for 10ms elapsed */ </P>
<P>energize(); /* round-robin execution the following tasks every 10ms */
cw();
ccw();
} </P>
<P>} </P>
<P>cw(){
if((flag1&amp;0x01)!=0)
cw_n--; /* decrement cw step number */
if (cw_n !=0)
j++; /* if not zero increment index j */
else
{flag1&amp;=~0x01; /* disable cw() execution */
ccw_n = n; /* reload step number to ccw counter */
flag1 |=0x02; /* enable cww() execution */
} </P>
<P>} </P>
<P>ccw(){
if((flag1&amp;0x02)!=0)
ccw_n--; /* decremnent ccw step number */
if (ccw_n !=0)
j--; /* if not zero decrement index j */
else
{flag1&amp;=~0x02; /* disable ccw() execution */
cw_n = n; /* reload step number to cw counter */
flag1 |=0x01; /* enable cw() execution */
} </P>
<P>} </P>
<P>tick_wait(){ /* cputick was replaced by simpler ASM code 10ms wait */ </P>
<P>asm" JNB TCON.5,*"; /* wait for TF0 set */
asm" CLR TCON.5"; /* clear TF0 for further set */
asm" ORL TH0,#$DC"; /* reload TH0 with $DC, TL0 = 0 */
} </P>
<P>energize(){ </P>
<P>P1 = step[(j&amp;0x07)]; /* only step 0-7 needed */
}</P>
<P>
</P>
发表于 2004-12-2 02:04:28 | 显示全部楼层
<>老大,帮我个忙,现在一块步进电机的控制器大概多少钱?</P><>除了控制器  还有什么方法能控制步进电机?</P>
 楼主| 发表于 2004-12-3 01:19:06 | 显示全部楼层
步进电机本来就是靠一个脉冲转一个角度的呀,没有控制器你得加一些脉冲发生器了哦!
 楼主| 发表于 2004-12-6 17:21:12 | 显示全部楼层
步进电机不贵,我昨天看了一下,最小的10块钱,还有15,20,30这样价格的,当然也有更大的就更贵了!
发表于 2004-12-15 01:26:39 | 显示全部楼层
hehe 我指步进电机的控制卡  我查到得都是2000多  我想知道有没有便宜的
GMT+8, 2026-9-28 09:51 , Processed in 0.049462 second(s), 11 queries , Gzip On, File On.
