查看: 112|回复: 3
labwindows table怎么自动换行?
发表于 2021-2-23 16:07:24 | 显示全部楼层 |阅读模式
 楼主| 发表于 2021-2-25 09:07:06 | 显示全部楼层
 楼主| 发表于 2021-3-23 15:25:39 | 显示全部楼层
可通过属性变量设置,自动调整行高和自动换行,
SetTableCellAttribute (panelHandle, PANEL_TABLE, MakePoint (3, 2), ATTR_WRAP_MODE, VAL_CHAR_WRAP);
SetRowHeightToTallestCellContents (panelHandle, PANEL_TABLE, 2);
 楼主| 发表于 2021-4-6 15:24:26 | 显示全部楼层
还需要配置行的size mode
SetTableRowAttribute (panelHandle, PANEL_TABLE, -1, ATTR_SIZE_MODE, VAL_USE_EXPLICIT_SIZE);
GMT+8, 2026-9-28 04:34 , Processed in 0.030110 second(s), 6 queries , Gzip On, File On.
