查看: 803|回复: 1
求助:我用signalexpress打不开TDMS文件
发表于 2008-6-10 15:07:32 | 显示全部楼层 |阅读模式
我使用的Signalexpress是V2.5的。没有使用LABVIEW,操作如下。
File»Import»Import Logged Signals From SignalExpress TDMS Files
选择SignalExpress Data文件夹内的TDMS文件,但无法打开。
总是提示:无法选择该文件夹名;已存在同名文件
发表于 2008-6-11 14:49:01 | 显示全部楼层
The zip file attached at the bottom of this KnowledgeBase article contains an installer that adds an option in the File menu in LabVIEW SignalExpress to import Logged Signal from LabVIEW TDMS File...  After you have downloaded and installed this update, follow the steps illustrated in the diagrams below. Make sure that you unzip the entire folder before running the installer.
Now, to configure the signal to be imported:
Select File » Logged Signal from LabVIEW TDMS File...
In the Source File Path select the TDMS file you created in LabVIEW
In the Destination File Path you will have to select a blank TDMS file (make sure to create this before you select it)
In the File Contents panel select the group name of the signals you want to import.
Select the Block Size and the Number of samples.
Select the Start time.
Click on Convert File button.
You will now be able to see your imported signal in the log panel.
SE update.zip
Write TDMS to SE.vi
[ 本帖最后由 lgh269 于 2008-6-11 14:51 编辑 ]
GMT+8, 2026-9-30 05:07 , Processed in 0.048158 second(s), 12 queries , Gzip On, File On.
