查看: 3415|回复: 11
一些芯片型号及其作用,方便选型![转贴]
发表于 2008-6-12 10:56:49 | 显示全部楼层 |阅读模式
原贴地址:
http://www.rf-china.com/sixdig/ca.asp
82C54 Programmable Interval Timer, CMOS, 8, 10 and 12MHz
82C55A Programmable Peripheral Interface, CMOS, 5 and 8MHz
82C59A Priority Interrupt Controller, CMOS, 5, 8 and 12.5MHz
CA3140 Op Amp, BiMOS, MOSFET Inputs, Bipolar Outputs, 4.5MHz
CA3140A Op Amp, BiMOS, MOSFET Inputs, Bipolar Outputs, 4.5MHz, Improved Input Characteristics
CA3240 Op Amp, BiMOS, Dual, MOSFET Inputs, Bipolar Outputs, 4.5MHz
CA3240A Op Amp, BiMOS, Dual, MOSFET Inputs, Bipolar Outputs, Low Bias, 4.5MHz
CA3260 Op Amp, Dual BiMOS, MOSFET Inputs, CMOS Outputs, 4MHz
CA3338 D/A Converter, Video, CMOS, 8-Bit, R2R Method, 50MSPS, 1LSB
CA3338A D/A Converter, Video, CMOS, 8-Bit, R2R Method, 50MSPS, 0.75LSB
CD22M3494 Switch, Crosspoint, 16 x 8 x 1, BiMOS-E
CDP68HC68T1 Clock, Real-Time, Serial with RAM, Power Sense/Control, CMOS
DG401 Analog Switch, SPST, Dual, NOpen, TTL Inputs, Single 5V and Dual ±15V Supply, CMOS
DG403 Analog Switch, DPST, Dual, NClosed/NOpen, TTL Inputs, Single 5V and Dual ±15V Supply, CMOS
DG406 Analog Multiplexer, Single 16-Channel, CMOS
DG407 Analog Multiplexer, Differential 8-Channel, CMOS
DG408 Analog Multiplexer, Single 8-Channel, CMOS
DG409 Analog Multiplexer, Differential 4-Channel, CMOS
DG411 Analog Switch, SPST, Quad, NClosed, RON = 35,VLOGIC = 5V, TTL Inputs, Power Supply ±5V to ±20V and Single Supply 5V to 34V
DG412 Analog Switch, SPST, Quad, NOpen, RON = 35, VLOGIC = 5V, TTL Inputs, Power Supply ±5V to ±20V and Single Supply 5V to 20V
DG413 Analog Switch, SPST, Quad, NClosed/NOpen, RON = 35, VLOGIC = 5V, TTL Inputs, Power Supply ±5V to ±20V and Single Supply 5V to 20V
DG441 Analog Switch, SPST, Quad, NClosed, RON = 100, TTL Inputs, Power Supply ±5 to ±20V and Single Supply 5V to 34V
DG442 Analog Switch, SPST, Quad, NOpen, RON = 100, TTL Inputs, Power Supply ±5 to ±20V and Single Supply 5V to 34V
DG444 Analog Switch, SPST, Quad, NClosed, RON = 100, VLOGIC = 5V, TTL Inputs, Power Supply ±5 to ±20V
DG445 Analog Switch, SPST, Quad, NOpen, RON = 100, VLOGIC = 5V, TTL Inputs, Power Supply ±5V to ±20V and Single Supply 5V to 34V
EL1503A ADSL Central Office Line Driver
EL1506 ADSL Central Office Line Driver
EL1507 ADSL Central Office Line Driver
EL1508 ADSL Central Office Line Driver
EL1509 ADSL CPE Line Driver
EL1510 VDSL CO/CPE Line Driver
EL1511 ADSL/VDSL Line Driver
EL1516 Dual Ultra Low Noise Amplifier
EL1516A Dual Ultra Low Noise Amplifier
EL1517 VDSL CO/CPE Line Driver
EL1519 ADSL CPE Line Driver
EL1526 Dual Port Wideband ADSL2++ Line Driver
EL1527 Dual Port ADSL Line Driver
EL1528 Dual Port ADSL2+ Line Driver
 楼主| 发表于 2008-6-12 10:56:59 | 显示全部楼层
EL1529 Dual Port Wideband ADSL2++ Line Driver
EL1848 White LED Step-Up Regulator
EL1881 Video Sync Separator, Low Power
EL1883 Sync Separator with Horizontal Output
EL2044 Single 120MHz Low Power Low Voltage Unity-Gain Stable Op Amp
EL2045 Single 120MHz Low Power Gain-of-2 Stable Op Amp
EL2125 Ultra-Low Noise Low Power Wideband Amplifier
EL2126 Ultra-Low Noise Low Power Wideband Amplifier
EL2141 Single 150MHz Differential Twisted-Pair Driver
EL2142 Single 150MHz Differential Receiver
EL2227 Dual Very Low Noise Amplifier
EL2228 Dual Low Noise Amplifier
EL2244 Dual 120MHz Low Power Unity-Gain Stable Op Amp
EL2250 Op Amp, Video, Dual 125MHz, SR=275V/μs, Low Power, Low Voltage, Single Supply, Clamping, 100mA Output
EL2276 Op Amp, Dual 70MHz, 1mA Low Power, Current Feedback, 55mA Drive, with Disable
EL2386 Op Amp, Triple 250MHz, 3mA, Current Feedback, 55mA Drive, with Disable
EL2444 Quad 120MHz Low Power Unity-Gain Stable Op Amp
EL2480 Quad Current Feedback Amplifier
EL4089 Op Amp, 60MHz, DC-Restored Video Amplifier, with TTL/CMOS Hold
EL4093 Op Amp, 300MHz, DC-Restored Video Amplifier, with TTL/CMOS Hold
EL4332 Multiplexer, Triple, Analog Video, 2:1, 300MHz, Fixed Gain = 2
EL4340 Triple 500MHz Multiplexing Amplifier
EL4342 Triple 500MHz Multiplexing Amplifier
EL4501 Video Front End
EL4511 Video Sync Separator
EL4543 Triple Differential Twisted-Pair Driver with Embedded Sync Encoding
EL4544 Triple 16 x 5 Differential to Single-Ended Crosspoint Switch (Operates in Single-Ended or Differential Input Modes)
EL4581 Video Sync Separator, NTSC PAL SECAM, 50% Slice, S-H, Filter
EL4584 PLL, Video Horizontal Genlock, 4FSC
EL5001 6-Channel Clock Driver
EL5027 2-Channel, Low Power Rail-to-Rail Input-Output Buffer
EL5100 Single 200MHz Slew-Enhanced Voltage Feedback Amplifier with Enable
EL5105 Single 700MHz Slew-Enhanced Voltage Feedback Amplifier
EL5106 Single 350MHz Fixed Gain Amplifier with Enable
EL5108 Single 450MHz Fixed Gain Amplifier with Enable
EL5111 Single 60MHz Rail-to-Rail Input-Output Op Amp
EL5120 Single 12MHz Rail-to-Rail Input-Output Op Amp
EL5123 4-Channel 12MHz Rail-to-Rail Input-Output Buffer
EL5127 4-Channel 2.5MHz Rail-to-Rail Input-Output Buffer
EL5128 Dual VCOM Amplifier and Gamma Reference Buffer
EL5129 Multi-Channel Buffer
EL5144 Single 100MHz Single-Supply Voltage Feedback Rail-to-Rail Amplifier
EL5146 Single 100MHzSingle-Supply Voltage Feedback Rail-to-Rail Amplifier with Enable
EL5150 Single 200MHz Low Offset Voltage Feedback Amplifier with Enable
EL5151 Single 200MHz Low Offset Voltage Feedback Amplifier
EL5152 Single 300MHz Low Offset Voltage Feedback Amplifier with Enable
EL5153 Single 300MHz Low Offset Voltage Amplifier
EL5156 Single 600MHz Low Offset Voltage Feedback Amplifier with Enable
EL5157 Single 600MHz Low Offset Voltage Feedback Amplifier
EL5160 Single 200MHz Low Power Current Feedback Amplifier with Enable
EL5161 Single 200MHz Low Power Current Feedback Amplifier
EL5162 Single 500MHz Low Power Current Feedback Amplifier with Enable
EL5163 Single 500MHz Low Power Current Feedback Amplifier
EL5164 Single 600MHz Current Feedback Amplifier with Enable
EL5165 Single 600MHz Current Feedback Amplifier
EL5166 Single 1.4GHz Current Feedback Amplifier with Enable
EL5167 Single 1.4GHz Current Feedback Amplifier
EL5170 Single 100MHz Differential Twisted-Pair Driver and Fixed Gain Amplifier
EL5171 Single 250MHz Differential Twisted-Pair Driver
EL5172 Single 250MHz Differential Twisted-Pair Receiver
 楼主| 发表于 2008-6-12 10:57:09 | 显示全部楼层
EL5173 Single 450MHz Differential Twisted-Pair Driver and Fixed Gain Amplifier
EL5174 Single 550MHz Differential Twisted-Pair Driver
EL5175 Single 550MHz Differential Twisted-Pair Receiver
EL5176 Single, 250MHz Differential Twisted-Pair Driver with Enable
EL5177 Single 550MHz Differential Twisted-Pair Driver
EL5178 700MHz Differential Twisted-Pair Driver
EL5191 Single 1GHz Current Feedback Amplifier
EL5191A Op Amp, 1GHz, Current Feedback Amplifier, with Enable
EL5192 Single 600MHz Current Feedback Amplifier
EL5192A Op Amp, 600MHz, Current Feedback Amplifier, Single Supply, with Enable
EL5193A Op Amp, 300MHz, Current Feedback Amplifier, with Enable, Low Power
EL5197A Op Amp, 200MHz, Fixed Gain Amplifier (+1, -1, +2), Single 5/10V or Dual Supply ±2.5V to ±5V, with Enable,
EL5202 Dual 400MHz Slew-Enhanced Voltage Feedback Amplifier with Enable
EL5203 Dual 400MHz Slew-Enhanced Voltage Feedback Amplifier
EL5204 Dual 700MHz Slew-Enhanced Voltage Feedbackm Amplifier with Enable
EL5205 Dual 700MHz Slew-Enhanced Voltage Feedback Amplifier
EL5210 Dual 30MHz Rail-to-Rail Input-Output Op Amp
EL5211 Dual 60MHz Rail-to-Rail Input-Output Op Amp
EL5220 Dual 12MHz Rail-to-Rail Input-Output Op Amp
EL5221 Dual 12MHz Rail-to-Rail Input-Output Buffer
EL5223 8-Channel 12MHz Rail-to-Rail Input-Output Buffer
EL5224 8-Channel 12MHz Rail-to-Rail Buffer with 100mA VCOM Amplifier
EL5225 10-Channel Reference Voltage Generator, 3-Wire Serial Interface, TFT-LCD Applications
EL5226 10-Channel Reference Voltage Generator, I2C Control Interface, TFT-LCD Applications
EL5227 8-Channel 2.5MHz Rail-to-Rail Input-Output Buffer
EL5244 Dual 100MHz Single-Supply Voltage Feedback Rail-to-Rail Amplifier
EL5246 Dual 100MHz Single-Supply Voltage Feedback Rail-to-Rail Amplifier with Enable
EL5261 Dual 200MHz Low Power Current Feedback Amplifier
EL5263 Dual 500MHz Low Power Current Feedback Amplifier
EL5300 Triple 200MHz Slew-Enhanced Voltage Feedback Amplifier with Enable
EL5304 Triple 700MHz Slew-Enhanced Voltage Feedback Amplifier with Enable
EL5306 Triple 350MHz Fixed Gain Amplifier with Enable
EL5308 Triple 450MHz Fixed Gain Amplifier with Enable
EL5323 10-Channel 12MHz Rail-to-Rail Input-Output Buffer
EL5324 10-Channel 12MHz Rail-to-Rail Buffer with 100mA VCOM Amplifier
EL5325 12-Channel TFT-LCD Reference Voltage Generator
EL5325A 12-Channel TFT-LCD Reference Voltage Generator with External Shutdown
EL5326 12-Channel Reference Voltage Generator, I2C Control Interface, TFT-LCD Applications
EL5327 10-Channel 2.5MHz Rail-to-Rail Input-Output Buffer
EL5329 Multi-Channel Buffer
EL5360 Triple 200MHz Low Power Current Feedback Amplifier with Enable
EL5362 Triple 500MHz Low Power Current Feedback Amplifier with Enable
EL5364 Triple 600MHz Current Feedback Amplifier with Enable
EL5370 Triple 100MHz Differential Twisted-Pair Driver and Fixed Gain Amplifier
EL5372 Triple 250MHz Differential Twisted-Pair Receiver
EL5373 Triple 450MHz Differential Twisted-Pair Driver and Fixed Gain Amplifier
EL5375 Triple 550MHz Differential Twisted-Pair Receiver
EL5410 Quad 30MHz Rail-to-Rail Input-Output Op Amp
EL5411 Quad 60MHz Rail-to-Rail Input-Output Op Amp
EL5412 40MHz Rail-to-Rail Input-Output Op Amp
EL5420 Quad 12MHz Rail-to-Rail Input-Output Op Amp
EL5421 Quad 12MHz Rail-to-Rail Input-Output Buffer
 楼主| 发表于 2008-6-12 10:57:20 | 显示全部楼层
EL5423 12-Channel 12MHz Rail-to-Rail Input-Output Buffer
EL5424 12-Channel 12MHz Rail-to-Rail Buffer with 100mA VCOM Amplifier
EL5427 12-Channel 2.5MHz Rail-to-Rail Input-Output Buffer
EL5444 Quad 100MHz Single-Supply Voltage Feedback Rail-to-Rail Amplifier
EL5462 500MHz Low Power Quad Current Feedback Amplifier
EL5524 4 x Gamma Buffer with VCOM Amplifier
EL5611 6-Channel VCOM Amplifier
EL5623 Multi-Channel Buffer
EL5624 6 x Gamma Buffer with VCOM Amplifier
EL5624A 6 x Gamma Buffer with VCOM Amplifier
EL5724 8 x Gamma Buffer with VCOM Amplifier
EL5811 8-Channel VCOM Amplifier
EL5824 10 x Gamma Buffer with VCOM Amplifier
EL5825 8-Channel Reference Voltage Generator, 3-Wire Serial Interface, TFT-LCD Applications
EL6140 Dual Laser Diode Driver with APC Amplifier
EL6145 3-Channel Laser Diode Driver with Oscillator and APC Amplifier
EL6173 Laser Diode Driver, 3-Channel, + Osc with APC Amplifier, Enable with L Signal applied to OUTEN
EL6195 Laser Diode Driver with Waveform Generator
EL6196 Laser Diode Driver with Waveform Generator
EL6196A Laser Diode Driver with Waveform Generator
EL6201 Low Power 430MHz HFM Oscillator with Disable
EL6203 Laser Diode Oscillator with Auto Shut-Off
EL6208 Dual 4-Channel Driver with Oscillator and LVDS
EL6215 Laser Diode Driver, 3-Channel, + Osc, Tr=1.0ns Tf=1.1ns, 100mA Output Current, Enable=OSCEN, Power-Up Disable
EL6238 Dual 4-Channel Driver with Oscillator
EL6293 Laser Diode Driver, with Waveform Generator, Clk=125MHz, DVD Rx=4.6, 1ch S/H
EL6296 Laser Diode Driver, Dual with Waveform Generator, Clk=125MHz, DVD Rx=4.6, Serial Input=15Mbps
EL6298 Laser Diode Driver, with Waveform Generator, Clk =200Mhz, 8x8 DAC, Serial Input=25Mhz, 0.12ns Timer Res
EL6830 Dual Laser Driver
EL6833 Dual 4-Channel Laser Driver with Oscillator and LVDS, CD or DVD, Timing via WENxx, Enable = OSEN+OSENB
EL6834 Dual 4-Channel Driver with Oscillator and LVDS
EL6835 Dual 4-Channel Driver with Oscillator and LVDS, Timing via WENxx, Enable = OSEN, External LVDS Term.
EL6838 Dual 4-Channel Laser Driver with Oscillator, CD or DVD, Timing via OUTENx, Enable = OSCEN
EL6839 Dual 4-Channel Laser Driver with Oscillator and LVDS
EL6912 Laser Diode Driver w/ Waveform Generator
EL6915 Laser Diode Driver, with Waveform Generator and I/V, 350mA, 8x8 DAC, Serial Input=25MHz, 120pS Timer Res
EL691X Laser Diode Drivers with Waveform Generator
EL6934 Laser Diode Driver with Waveform Generator
EL6935A Laser Diode Driver w/ Waveform Generator
EL6935B Laser Diode Driver w/ Waveform Generator
EL6938 Laser Diode Driver with Waveform Generator
EL7104 High Speed Single Channel Power MOSFET Driver
EL7154 High Speed Monolithic Pin Driver
EL7156 High Performance Pin Driver
EL7158 Pin Driver, Tri-State, 12A Pk Ultra-High Current, 40MHz Clock, RON 0.5Ω
EL7202 High Speed Dual Channel Power MOSFET Driver
EL7212 High Speed Dual Channel Power MOSFET Driver
EL7222 High Speed Dual Channel Power MOSFET Driver
EL7232 Dual High Speed High Current Line Driver with Tri-State
 楼主| 发表于 2008-6-12 10:57:31 | 显示全部楼层
EL7242 Dual Input High Speed Dual Channel Power MOSFET Driver
EL7243 Dual Input, High Speed, Dual Channel CCD Driver
EL7252 Dual Input, High Speed, Dual Channel Power MOSFET Driver
EL7412 High Speed, 4-Channel Power MOSFET Driver
EL7457 40MHz Non-Inverting Quad CMOS Driver
EL7512 PWM, Integrated FET, High Frequency
EL7513 Integrated FET, Constant Current Boost for 12 White LEDs
EL7515 PWM, High Frequency
EL7516 Single Channel Boost Regulator
EL7518 White LED Step-Up Regulator
EL7530 0.6A PWM/PFM Regulator with Low Quiescent Current, Fsw 1.4MHz
EL7531 1A PWM/PFM Regulator with Low Quiescent Current, Fsw 1.4MHz
EL7532 2A PWM Regulator with 100mS Power On Reset, Fsw 1.5MHz
EL7534 0.6A PWM Regulator with 100ms Power On Reset, Fsw 1.5MHz
EL7535 Monolithic 350mA Step-Down Regulator
EL7536 1A PWM Regulator with 100ms Power On Reset, Fsw 1.5MHz
EL7554 4A PWM Regulator with ±5% Voltage Margining and Sequencing
EL7556D PWM, Synchronous Converter with 6A FETs
EL7563 PWM, Conveter with 4A FETs
EL7564 PWM, Converter with 4A FETs
EL7566 6A PWM Regulator with ±5% Voltage Margining and Sequencing
EL7571 Programmable VID Sync Buck, 5-Bit DAC, with N-Channel FET Drivers, 1%, Pentium II
EL7581 3-Channel DC/DC Converter, Boost Regulator, VCOM Buffer and VON/VOFF Charge Pumps, TFT-LCD Applications
EL7584 4-Channel DC/DC Converter, Boost Regulator, VCOM Buffer, VON/VOFF Charge Pumps and VCOM Amplifier, TFT-LCD Applications
EL7585A 4-Channel DC/DC Converter, Boost Regulator, VON/VOFF LDOs and Logic LDO with Sequencing and Fault Protection, TFT-LCD Applications
EL8100 Single 200MHz Rail-to-Rail Amplifier with Enable
EL8101 Single 200MHz Rail-to-Rail Amplifier
EL8102 Single 500MHz Rail-to-Rail Amplifier with Enable
EL8103 Single 500MHz Rail-to-Rail Amplifier
EL8170 Micropower Single Supply Rail-to-Rail Input-Output Instrumentation Amplifier
EL8171 Micropower Single Supply Rail-to-Rail Input-Output Instrumentation Amplifier
EL8172 Micropower Single Supply Rail-to-Rail Input-Output Instrumentation Amplifier
EL8173 Micropower Single Supply Rail-to-Rail Input-Output Instrumentation Amplifier
EL8200 Dual 200MHz Railto-Rail Amplifier with Enable
EL8201 Dual 200MHz Rail-to-Rail Amplifier
EL8202 Dual 500MHz Railto-Rail Amplifier with Enable
EL8203 Dual 500MHz Railto-Rail Amplifier
EL8300 Triple 200MHz Railto-Rail Amplifier with Enable
EL8302 Triple 500MHz Rail=to-Rail Amplifier with Enable
EL8401 Quad 200MHz Rail-to-Rail Amplifier
EL8403 Quad 500MHz Rail-to-Rail Amplifier
EL9110 Differential Receiver (5 pole) and Equalizer
EL9111 Triple Differential Receiver/Equalizer with Embedded Sync Decoding
EL9112 Triple Differential Receiver/Equalizer
EL9115 Triple Analog Video Delay Line
EL9200 DCP with Single VCOM Amplifier and Up/Down Interface
 楼主| 发表于 2008-6-12 10:57:41 | 显示全部楼层
EL9201 DCP with Dual VCOM Amplifier and Up/Down Interface
EL9202 DCP with Quad VCOM Amplifier and Up/Down Interface
EL9211 Single Channel High Speed VCOM Amplifier
EL9212 Dual Channel High Speed VCOM Amplifier
EL9214 Quad Channel High Speed VCOM Amplifier
HA4314B Multiplexer, Video, 400MHz, 4 x 1
HC5503 SLIC, Balanced PBX/Key System, Low Cost
HC5503PRC SLIC, Low Cost, for Large Telecom Switches
HC5503T SLIC, Balanced PBX/Key System, Low Cost
HC5504B SLIC, EIA/ITU PABX, with 40mA Loop Feed
HC55120 SLIC, Low Power, 30mA Loop Current, Longitudinal Balance 53dB
HC55121 SLIC, Low Power, 30mA Loop Current, Polarity Reversal, Longitudinal Balance 53dB
HC55130 SLIC, Low Power, 45mA Loop Current, Longitudinal Balance 63dB
HC55140 SLIC, Low Power, 45mA Loop Current, Polarity Reversal, Gnd Start, Gnd Key, Line Volt Measurement, with Long Balance 63dB
HC55142 SLIC, Low Power, 45mA Loop Current, Polarity Reversal, Gnd Start, Gnd Key, Line Volt Measurement, with Long Balance 63dB and Pulse Metering
HC55150 SLIC, Low Power, 45mA Loop Current, Line Voltage Measurement, Pulse Metering, Longitudinal Balance 55dB
HC55183 SLIC, Extended Reach Ringing, 75V, Bat. Switch, LB = 45dB
HC55184 SLIC, Extended Reach Ringing, 75V, Bat. Switch, Polarity Reversal, LB = 45dB
HC55185 SLIC, Ringing, VoIP, 75/85/100V, Gnd Start, LB = 53/58dB
HC5549 SLIC, Low Power, with Battery Switch
HFA1100 Op Amp, 850MHz, Low Distortion, Video/RF, Current Feedback, SR = 2300V/μs
HFA1113 Buffer, Closed Loop, Programmable Gain (±1, +2), 850MHz, Video/RF, Output Limiting
HFA1412 Buffer, Quad, Closed Loop, Programmable Gain (±1, +2), 350MHz, Low Power
HFA3101 Gilbert Cell Multiplier, Ultra High Frequency
HI-200 Analog Switch, SPST, Dual, NClosed, RON = 55, TTL Inputs, 80mA Signal Current, CMOS
HI-201 Analog Switch, SPST, Quad, NClosed, RON = 55, TTL Inputs, TON = 240ns, 80mA Signal Current, CMOS
HI-201HS Analog Switch, SPST, Quad, NClosed, RON = 30, TTL Inputs, High Speed, TON 30ns, 80mA Signal Current, CMOS
HI-303 Analog Switch, SPDT, Dual, NClosed/NOpen, RON = 35, TTL Compliant Inputs, CMOS
HI-5043 Analog Switch, DPST, Dual, NClosed/NOpen, RON = 50, TTL Inputs, 80mA Signal Current, CMOS
HI-5051 Analog Switch, DPST, Dual, NClosed/NOpen, RON = 25, TTL Inputs, 80mA Signal Current, CMOS
HI-506 Analog Multiplexer, Single 16-Channel
HI-506A Analog Multiplexer, Single 16-Channel, Overvoltage Protection
HI-507A Analog Multiplexer, 8-Channel Differential, Overvoltage Protection
HI-508 Analog Multiplexer, Single 8-Channel, 883 Compliant
HI-509 Analog Multiplexer, 4-Channel Differential
HI-509A Analog Multiplexer, 4-Channel Differential, Overvoltage Protection
HI-516 Analog Multiplexer, Single 16-Channel or Differential 8-Channel, High Speed
HI-546 Analog Multiplexer, Single 16-Channel, Overvoltage Protection, RON Matching
HI-547 Analog Multiplexer, 8-Channel Differential, Overvoltage Protection, RON Matching
HI-548 Analog Multiplexer, Single 8-Channel, Overvoltage Protection, RON Matching
HI-549 Analog Multiplexer, 4-Channel Differential, Overvoltage Protection, with RON Matching
HI3338 D/A Converter, 8-Bit, CMOS, 50MHz, R2R
HI5660 D/A Converter, 8-Bit, 125/60MSPS, High Speed
HI5714 A/D Converter, 8-Bit, 40/60/75/80MSPS
HI5731 D/A Converter, 12-Bit, 100MSPS, High Speed
HI5735 D/A Converter, 12-Bit, 80MSPS, 650mW, +5V and -5.2V, High Speed Video, TTL Input
HI5741 D/A Converter, 14-Bit, 100MSPS, High Speed
HI5746 A/D Converter, 10-Bit, 40MSPS, Internal Sample and Hold
HI5760 D/A Converter, 10-Bit, 60/125MSPS, Internal Voltage Reference
HI5766 A/D Converter, 10-Bit, 60MSPS
 楼主| 发表于 2008-6-12 10:57:52 | 显示全部楼层
HI5767 A/D Converter, 10-Bit, 20/40/60MSPS, Internal Voltage Reference
HI5805 A/D Converter, 12-Bit, 5MSPS
HI5812 A/D Converter, 12-Bit, 750kHz, Internal Track and Hold, Conversion Time 20s
HI5860 D/A Converter, 12-Bit, 130MSPS, High Speed
HI5960 D/A Converter, 130MSPS, 14-Bit, High Speed
HI7191 A/D, 10kHz, Sigma-Delta Converter, 24-Bit, 0.0015 %FS INL, 20-Bits Resolution No Missing Codes
HIN202 RS-232 Transceiver, 2T/2R, 5V, 120kbps, 0.1μF Capacitors
HIN202E RS-232 Transceiver, 2T/2R, +5V, 230kbps, 15kV ESD (IEC61000), 0.1μF Capacitors, ICC = 8mA
HIN206E RS-232 Transceiver, 4T/3R, +5V, 230kbps, 15kV ESD (IEC61000), 0.1μF Capacitors, Manual Shutdown
HIN207E RS-232 Transceiver, 5T/3R, +5V, 230kbps, 15kV ESD (IEC61000), 0.1μF Capacitors
HIN208E RS-232 Transceiver, 4T/4R, +5V, 230kbps, 15kV ESD (IEC61000), 0.1μF Capacitors
HIN211 RS-232 Transceiver, 4T/5R, +5V, 120kbps, 0.1μF Capacitors, Manual Shutdown
HIN211E RS-232 Transceiver, 4T/5R, +5V, 230kbps, 15kV ESD (IEC61000), 0.1μF Capacitors, Manual Shutdown
HIN213 RS-232 Transceiver, 4T/5R, +5V, 120kbps, 0.1μF Capacitors, Two Active Receivers in Shutdown Mode
HIN213E RS-232 Transceiver, 4T/5R, +5V, 230kbps, 15kV ESD (IEC61000) , 0.1μF Capacitors, Two Active Receivers in Shutdown Mode
HIN232 RS-232 Transceiver, 2T/2R, +5V, 120kbps, 1.0μF Capacitors, ICC = 5mA
HIN232A RS-232 Transceiver, 2T/2R, +5V, 230kbps, 0.1μF Capacitors, ICC = 5mA
HIN232E RS-232 Transceiver, 2T/2R, +5V, 230kbps, 15kV ESD (IEC61000), 0.1μF Capacitors, ICC = 5mA
HIN236 RS-232 Transceiver, 4T/3R, +5V, 120kbps, 1.0μF Capacitors, Manual Shutdown
HIN237 RS-232 Transceiver, 5T/3R, +5V, 120kbps, 1.0μF Capacitors
HIN238 RS-232 Transceiver, 4T/4R, +5V, 120kbps, 1.0μF Capacitors
HIN239 RS-232 Transceiver, 3T/5R, +5V and +12V, 120kbps, External V+ Supply, Requires Only Two External Capacitors
HIN241 RS-232 Transceiver, 4T/5R, +5V, 120kbps, 1.0μF Capacitors, Manual Shutdown
HIP1011 Controller, PCI Hot Plug, +5/+3.3/+12/-12VDC, Adjustable Overcurrent
HIP1011A Controller, PCI Hot Plug, +5/+3.3/+12/-12VDC, Adjustable Overcurrent, with Adjustable Trip Delay to Latchoff
HIP1011B Controller, CompactPCI Hot Plug, +5/+3.3/+12/-12VDC, Adjustable Overcurrent, without Undervoltage Lockout
HIP1011E Controller, Dual Slot CompactPCI Hot Plug, +5/+3.3/+12/-12VDC, Adjustable Overcurrent, without Undervoltage Lockout
HIP1012A Controller, Hot Plug, Dual, Power Distribution, Control for +5/+12V or +5/+3.3V, 50mV Overcurrent Threshold
HIP1013 Controller, Hot Plug, Dual, Power Distribution, Control for +5/+12V or +5/+3.3V, No Current Reg
HIP1020 Controller, Hot Plug, Single, Double or Triple-Output, Adjustable Turn-on ramp, Internal Charge Pump
HIP2100 100V/2A Peak, High-Frequency Half Bridge N-Channel MOSFET Driver
HIP2101 100V/2A Peak, High-Frequency Half Bridge N-Channel MOSFET Driver with TTL-Compatible Logic Inputs
HIP2101E 100V/2A Peak, High-Frequency Half Bridge N-Channel MOSFET Driver with TTL-Compatible Logic Input in Thermally Enhanced SO-8 Package
HIP4080A 80V/2.5A Full-Bridge N-Channel MOSFET Driver with Integrated Charge Pump, Adjustable Dead Time, and Input Comparator
HIP4081A 80V/2.5A Full-Bridge N-Channel MOSFET Driver with Integrated Charge Pump, Adjustable Dead Time, and Independent Input Controls
HIP4082 80V/1.25A Full-Bridge N-Channel MOSFET Driver with Adjustable Dead Time and Independent Input Controls
HIP4083 80V/0.3A Three-Phase High-Side-Only N-Channel MOSFET Driver
HIP4086 80V/1.1A Three-Phase N-Channel MOSFET Driver with Integrated Charge Pump, Adjustable Dead Time, and Independent Input Controls
HIP6004B Microprocessor DC/DC Converter, Buck/Sync-Rectifier, TTL 5-Bit VID DAC, ±1% Reg
HIP6004D Microprocessor DC/DC Converter, Buck/Sync-Rectifier, TTL 5-Bit VID DAC, ±1% Reg
HIP6004E Microprocessor DC/DC Converter, Buck/Sync-Rectifier, 5-Bit VID DAC, ±1% Reg
HIP6006 PWM Controller, Microprocessor DC/DC Converter, Buck/Sync-Rectifier, No DAC, ±1% Reg, 5/12VDC Input to 3.xVDC Output
HIP6012 PWM Controller, Microprocessor DC/DC Converter, Buck/Sync-Rectifier, No DAC, ±1.5% Reg, 5/12VDC Input to 3.x/1.27VDC Output
HIP6018B PWM + Dual Linear, Micro Core/Clock/GTL, TTL 5-Bit VID DAC, Reg PWM ±1%/Linear ±2.5%
HIP6019B Dual PWM + Dual Linear, Micro Core/I-O/Clock/GTL, TTL 5-Bit VID DAC, Reg Core ±1%/I-O ±2%/Linear ±2.5%
HIP6021 Sync Buck PWM + Triple Linear, Micro Core/AGP/Memory/GTL, TTL 5-Bit VID DAC, Reg Core ±1%/Linear ±3%
HIP6301 PWM Controller, 2-4 Phase Sync Buck, 1.10V to 1.85V, ±1.0% Reg, Programmable Droop Voltage, 5-Bit VID DAC
HIP6301V PWM Controller, 2-4 Phase Sync Buck, 1.10V to 1.85V, ±0.8% Reg, Programmable Droop Voltage, 5-Bit Dynamic VID DAC
HIP6302 PWM Controller, 2 Phase Sync Buck, 1.10V to 1.85V, ±1.0% Reg, Programmable Droop Voltage, 5-Bit VID DAC
HIP6311 PWM Controller, 2-4 Phase Sync Buck, 5-Bit VID DAC, 1.100V to 1.850V in 25mV Steps, ±0.8% Reg, Prog Droop Voltage
HIP6311A PWM Controller, 2-4 Phase Sync Buck, 5-Bit VID DAC, 1.100V to 1.850V in 25mV Steps, ±0.5% Reg, Prog Droop Voltage
HIP6501A Triple Linear Controller, ACPI Control Interface, use with HIP6020/21
HIP6521 PWM Controller and Triple Linear Power Controller, Adjustable Outputs, 0.8V Reference, ±2% Reg, 300kHz Fsw
HIP6601B MOSFET Driver, Dual N-Channel, 730mA, 12V Low Side, 5/12V High Side, use with Multiphase Controller, POR = 7.6V
HIP6602B MOSFET Driver, Quad N-Channel, 12V Low Side, 5/12V High Side, use with Multiphase Controller, POR = 7.6V
 楼主| 发表于 2008-6-12 10:58:02 | 显示全部楼层
HIP6603B MOSFET Driver, Dual N-Channel, 730mA, 5/12V Low Side, 5/12V High Side, use with Multiphase Controller, POR = 7.6V
HIP6604B MOSFET Driver, Dual N-Channel, 730mA, 12V Low Side and 5/12V High Side or 5/12V High and Low Side, use with Multiphase Controller, POR = 7.6V
ICL3207 RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps
ICL3207E RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000)
ICL3217 RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps, 13kV ESD, Auto Powerdown
ICL3217E RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ICL3221 RS-232 Transceiver, 1T/1R, +3V to 5.5V, 250kbps, Auto Powerdown
ICL3221E RS-232 Transceiver, 1T/1R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ICL3222 RS-232 Transceiver, 2T/2R, +3V to 5.5V, 250kbps, Manual Powerdown
ICL3222E RS-232 Transceiver, 2T/2R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Manual Powerdown
ICL3223 RS-232 Transceiver, 2T/2R, +3V to 5.5V, 250kbps, Auto Powerdown
ICL3223E RS-232 Transceiver, 2T/2R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ICL3225 RS-232 Transceiver, 2T/2R, +3V to 5.5V, 1Mbps, Enhanced Auto Powerdown
ICL3225E RS-232 Transceiver, 2T/2R, +3V to 5.5V, 1Mbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ICL3227E RS-232 Transceiver, 1T/1R, +3V to 5.5V, 1Mbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ICL3232 RS-232 Transceiver, 2T/2R, +3V to 5.5V, 250kbps
ICL3232E RS-232 Transceiver, 2T/2R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000)
ICL3237 RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps or 1Mbps, Manual Powerdown with Receivers Active
ICL3237E RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps or 1Mbps, 15kV ESD (IEC61000), Manual Powerdown with Receivers Active
ICL3238 RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps, Enhanced Auto Powerdown
ICL3238E RS-232 Transceiver, 5T/3R, +3V to 5.5V, 250kbps, Enhanced Auto Powerdown, 15kV ESD (IEC61000)
ICL3241E RS-232 Transceiver, 3T/5R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Manual Powerdown
ICL3243E RS-232 Transceiver, 3T/5R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ICL3244E RS-232 Transceiver, 3T/5R, +3V to 5.5V, 250kbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ICL3245E RS-232 Transceiver, 3T/5R, +3V to 5.5V, 1Mbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ICL7106 3 1/2 Digit, Liquid Crystal Display, A/D Converters
ICL7107 3 1/2 Digit, LED Display, A/D Converters
ICL7126 3 1/2 Digit, Low Power, Single-Chip A/D Converter
ICL7135 4 1/2 Digit, BCD Output, A/D Converter
ICL7136 3 1/2 Digit LCD/LED, Low Power Display, A/D Converters with Overrange Recovery
ICL7611 Op Amp, CMOS, Rail-to-Rail Output, 1.4MHz, Low Voltage 1-8VDC, Programmable ICC, Low Bias 0.05nA
ICL7612 Op Amp, CMOS, Rail-to-Rail I/O, Programmable ICC, 1.4MHz, Low Voltage 1-8VDC, Low Bias 0.05nA
ICL7621 Op Amp, CMOS, Rail-to-Rail Output, Low Voltage 1-8VDC, RIN = 10E12, IBIAS = 1pA, Dual
ICL7650S Op Amp, CMOS Precision Chopper-Stabilized, Rail-to-Rail Output, High Gain - 150dB, CMRR - 140dB, 2MHz
ICL7660 Voltage Inverter, +5 to ±5V, Input Voltage 1.5-10V, or Voltage Doubler to 18.6V
ICL7660A Voltage Inverter, +5 to ±5V, Input Voltage 1.5-10V, or Voltage Doubler to 18.6V
ICL7660S Voltage Inverter, +5 to ±5V, Input Voltage 1.5-12V, with Freq Boost
ICL7663S Programmable Micropower Positive Voltage Regulator, 1.3 to 16V
ICL7665S Micropower Over/Under Voltage Detector, CMOS
ICL7667 MOSFET Driver, Dual Power, TTL Input, ROUT = 7Ω
ICL7673 Automatic Battery Back-Up Switch, 2.5 to 15V
ICM7228 LED Display Decoder Driver, 8-Character, Microprocessor Compatible, Numeric
ICM7555 General Purpose Timer, CMOS
ICM7556 General Purpose Timer, Dual, CMOS
IPM6220A Advanced Triple PWM and Dual Linear Power Controller, Vbatt Hystersis Typ=300mV
ISL24006 14-Channel Programmable Switchable I2C TFT-LCD Reference Voltage Generator with Integrated 4-Channel Static Gamma Drivers
ISL4221E RS-232 Transceiver, 1T/1R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ISL4223E RS-232 Transceiver, 2T/2R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ISL4238E RS-232 Transceiver, 5T/3R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ISL4241E RS-232 Transceiver, 3T/5R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Manual Powerdown
ISL4243E RS-232 Transceiver, 3T/5R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown
ISL4244E RS-232 Transceiver, 3T/5R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ISL4245E RS-232 Transceiver, 3T/5R, +2.7V to +5.5V, 1Mbps, 15kV ESD (IEC61000), Enhanced Auto Powerdown
ISL4260E RS-232 Transceiver, 3T/2R, +3V to +5.5V, 250kbps, 15kV ESD (IEC61000) with VL
ISL4270E RS-232 Transceiver, 3T/3R, +2.7V to +5.5V, 250kbps, 15kV ESD (IEC61000), Auto Powerdown and VL
ISL43110 Analog Switch, SPST, NOpen, RON = 7 @ +12V, Single Supply +2.4 to +12V, RON Matched
ISL43111 Analog Switch, SPST, NClosed, RON = 7 @ +12V, Single Supply +2.4 to +12V, RON Matched
ISL43112 Analog Switch, SPST, Single, NOpen, RON = 13 @ ±5V, ±1.5V to ±6V Dual Supply, RON Matched
ISL43113 Analog Switch, SPST, Single, NClosed, RON = 13 @ ±5V, ±1.5V to ±6V Dual Supply, RON Matched
ISL43120 Analog Switch, Dual SPST, NOpen/NOpen, RON = 11 @ +12V, Single Supply +2.7 to +12V, RON Matched
ISL43121 Analog Switch, Dual SPST, NClosed/NClosed, RON = 11 @ +12V, Single Supply +2.7 to +12V, RON Matched
ISL43122 Analog Switch, Dual SPST, NOpen/NClosed, RON = 11 @ +12V, Single Supply +2.7 to +12V, RON Matched
ISL43140 Analog Switch, SPST, Quad, NClosed, RON = 50 @, Single or Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43141 Analog Switch, SPST, Quad, NOpen, RON = 50, Single and Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43142 Analog Switch, SPST, Quad, 2xNOpen/2xNClosed, RON = 50 Single and Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43143 Analog Switch, SPST, Quad, NClosed, RON = 18 ±5V, Single or Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43144 Analog Switch, SPST, Quad, NOpen, RON = 18 ±5V, Single or Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43145 Analog Switch or 2-1 Multiplexer, SPST, Quad, 2xNClosed/ 2xNOpen, RON = 18 ±5V, Single or Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43210 Analog Switch or 2-1 Multiplexer, Single SPDT, RON = 11 @ +12V, Single Supply +2.7 to +12V, RON Matched
ISL43231 Low-Voltage, Single and Dual Supply, Triple SPDT Analog Switch
ISL43240 Analog Switch, SPDT, Quad, 2xNClosed/2xNOpen, RON = 18 @ ±5V, Single or Dual Supply, ±2V to ±6V or +2V to +12V, RON Matched
ISL43410 Analog Switch, DPDT or 2 to 1 Mux, Single, RON = 45 @ 12V, Single Supply +2V to +12V, with inhibit, off leakage 1nA
ISL43485 3.3V, Low Power, 30Mbps, RS-485/RS-422 Transceiver
ISL43640 Analog Multiplexer/Demultiplexer, 4 to 1, Single Supply +2 to +12V, RON = 115 @ 5V, Rail to Rail, Pd = <3μW
 楼主| 发表于 2008-6-12 10:58:13 | 显示全部楼层
ISL43681 Low-Voltage, Single and Dual Supply, 8 to 1 Multiplexer
ISL43741 Low-Voltage, Single and Dual Supply, Differential 4 to 1 Multiplexer
ISL43840 Low-Voltage, Single and Dual Supply, Dual 4 to 1 Multiplexer Analog Switch with Enable
ISL43841 Low-Voltage, Single and Dual Supply, Dual 4 to 1 Multiplexer Analog Switch with Latch
ISL43L110 Ultra Low ON-Resistance, +1.1V to +4.5V Single Supply, SPST Analog Switches
ISL43L111 Ultra Low ON-Resistance, +1.1V to +4.5V Single Supply, SPST Analog Switches
ISL43L210 Ultra Low ON-Resistance, Low Voltage, Single Supply, SPDT Analog Switch
ISL43L220 Ultra Low ON-Resistance, Low Voltage, 1.1V to 4.5V, Dual SPDT Analog Switch
ISL4485E RS-485/RS-422 Transceivers, 20Mbps, ESD Protected to ±15kV, Half Duplex, 5V, with Rx/Tx Enables
ISL4486 5V, Ultra High Speed, PROFIBUS, RS-485/RS-422 Transceivers
ISL4489E ±15kV ESD Protected, 1/8 Unit Load, 5V, Low Power, Slew Rate Limited, Full Duplex, RS-485/RS-422 Transceivers
ISL45042 LCD Module Calibrator
ISL45043 I2C LCD Module Calibrator
ISL5120 Analog Switch, SPST, Dual, NOpen, RON = 32 @ 3.3V, 19 @ 5V, 11 @ 12V, Single Supply, +2.7V to +12V
ISL5121 Analog Switch, SPST, Dual, NClosed, RON = 32 @ 3.3V, 19 @ 5V, 11 @ 12V, Single Supply, +2.7V to +12V
ISL5122 Analog Switch, SPST, Dual, NClosed/NClosed, RON = 32 @ 3.3V, 19 @ 5V, 11 @ 12V, Single Supply, +2.7V to +12V
ISL5123 Analog Switch or 2-1 Multiplexer, SPDT, Single, RON = 32 @ 3.3V, 19 @ 5V, 11 @ 12V, Single Supply, +2.7V to +12V
ISL5216 Down Converter, Quad, Programmable, Fixed or Floating Point Inputs, 32-Bit Programmable Carrier NCO, SFDR >115dB SFDR
ISL5217 Up Converter, Quad, Programmable, (QPUC), Sample Rates to 104MSPS, Input Data Rates to 6.5MSPS
ISL5416 Down Converter, Quad, Wideband, Programmable, (WPDC), Fixed or Floating Point Inputs, 32-Bit Programmable Carrier NCO, SFDR >110dB
ISL5571A High Voltage Switch, Subscriber Line Access, 0.5Ω Max RON Match, 28Ω Max Ron
ISL5585 Ringing SLIC, 3.3V Supply, 75/85/100V, 53/58dB, Voice Over Broadband
ISL5586 Ringing SLIC, Low Power, Compatible with 3.3V Devices, Home Gateway
ISL5757 10-Bit, +3.3V, 260+MSPS, High Speed D/A Converter
ISL5761 D/A Converter, 10-Bit, 130/210MSPS, High Speed, +3.3V
ISL5857 12-Bit, +3.3V, 260+MSPS, High Speed D/A Converter
ISL5861 D/A Converter, 12-Bit, 130/210MSPS, High Speed, +3.3V
ISL5957 14-Bit, +3.3V, 260+MSPS, High Speed D/A Converter
ISL5961 D/A Converter, 14-Bit, 130/210/250MSPS, High Speed, +3.3V
ISL6111 Current Regulated PCI Hot Plug Power Switch Controller
ISL6115 Controller, Hot Plug, Power Distribution, Single +12V Control, IntelliTrip? Current Regulation, PGOOD Always Enabled
ISL6116 Controller, Hot Plug, Power Distribution, Single +5V Control and Low Side Switch, IntelliTrip? Current Regulation, PGOOD Always Enabled
ISL6117 Controller, Hot Plug, Power Distribution, Single +3.3V Control and Low Side Switch, IntelliTrip? Current Regulation, PGOOD Always Enabled
ISL6118 Controller, Hot Plug, Dual Slot, 600mA Overcurrent (OC) Fault Protection IC, 2.5V to 5.5V Operating Range
ISL6119 USB Power Supply Controller, Dual Port, 1A Overcurrent (OC) Fault Protection IC, 2.5V to 5.5V Operating Range
ISL6120 Controller, Hot Plug, Power Distribution, Single +2.5V Control and Low Side Switch, IntelliTrip? Current Regulation, PGOOD Always Enabled
ISL6121 Current Limiting Controller, 2A, 2.5V to 5.5V Operating Range, 0.05Ω Integrated Power N-channel MOSFET Switch
ISL6123 Low Voltage 4-Channel Power Sequencer, Programmable Up/Down Sequencing, Enable = High
ISL6124 Low Voltage 4-Channel Power Sequencer, Programmable Up/Down Sequencing, Enable = Low
ISL6125 Low Voltage 4-Channel Power Sequencer, Programmable Up/Down Sequencing, Enable = Low, Open-Drain Logic Outputs
ISL6126 Low Voltage 4-Channel Power Sequencer, Programmable Up/Down Sequencing, Enable = Low, Voltage-Based Sequencing
ISL6127 Low Voltage 4-Channel Power Sequencer, Fixed ABCD-Up/DCBA-Down Sequencing, reduces BOM, Enable = Low
ISL6128 Low Voltage Dual 2-Channel Power Sequencer, Fixed Up/Down Sequencing, Enable = Low
ISL6131 Multiple Voltage Supervisory ICs
ISL6132 Multiple Voltage Supervisory ICs
ISL6140 Hot Plug Controller, Negative Voltage, -10V to -80V, Programmable Inrush Current, OC Shutdown, UV/OV Protection, Active low PWRGD-bar
ISL6141 Hot Plug Controller, Negative Voltage, -20V to -80V, Prog Inrush Current, IntelliTrip? Current Regulation, UV/OV Protection, Active low PWRGD-bar
ISL6142 Hot Plug Controller, Negative Voltage, -20V to -80V, Prog Inrush Current, IntelliTrip? Current Regulation, UV/OV Protection, Prog Time Out, Load current monitor, Active low PWRGD-bar
ISL6144 High Voltage ORing MOSFET Controller
ISL6150 Hot Plug Controller, Negative Voltage, -10V to -80V, Programmable Inrush Current, OC Shutdown, UV/OV Protection, Active high PWRGD
ISL6151 Hot Plug Controller, Negative Voltage, -20V to -80V, Prog Inrush Current, IntelliTrip? Current Regulation, UV/OV Protection, Active high PWRGD
ISL6152 Hot Plug Controller, Negative Voltage, -20V to -80V, Prog Inrush Current, IntelliTrip? Current Regulation, UV/OV Protection, Prog Time Out, Load current monitor, Active high PWRGD
ISL6160 Power Controller, InfiniBand, +12V Bulk and +5V Auxiliary, UV Lockout, OC Protection, Adj Turn-On
ISL6161 Hot Plug Controlller, 12V and 3.3V PCI-Express, Programmable, Adj Turn-On, with Indicators
ISL6172 Dual Low Voltage Hot Plug Controller
ISL6173 Dual Low Voltage Hot Swap Controller
ISL6207 Dual MOSFET Driver, N-Channel, 30V, use with Multiphase Controllers, 2.0 Amp
ISL6208 High Voltage Synchronous Rectified Buck MOSFET Driver
ISL6209 High Voltage Synchronous Rectified Buck MOSFET Driver
ISL6217 PWM Controller for Intel Pentium M
ISL6217A PWM Controller, IMVP License Required, CPU Power for Centrino
ISL6218 Single Phase IMVP-IV Controller for Intel Pentium M
ISL6224 PWM Controller, Output Voltage: 0.9-5.5V, Wide VIN range: 4V-24V, 300/600kHz
ISL6225 PWM Controller, Dual, Regulated Output Voltage 0.9V-5.5V, VTT Tracks VDDQ/2 , VDDQ/2 Buffered Reference Output
ISL6227 Dual Mobile-Friendly PWM Controller with DDR Option
ISL6232 High Efficiency System Power Supply Controller for Notebook Computers
ISL6244 PWM Controller, Multiphase Power Controller with 2, 3, or 4 Phase for AMD Mobile Hammer
ISL6247 Multiphase PWM Controller for Mobile Intel Pentium 4
ISL6248A Multiphase PWM Controller for Mobile Intel Pentium 4
ISL6251 Low Cost Multi-Chemistry Battery Charger Controller
ISL6251A Low Cost Multi-Chemistry Battery Charger Controller
ISL6253 Highly Integrated Battery Charger for Notebook Computers
ISL6255 Highly Integrated Battery Charger with Automatic Power Source Selector for Notebook Computers
ISL6255A Highly Integrated Battery Charger with Automatic Power Source Selector for Notebook Computers
 楼主| 发表于 2008-6-12 10:58:25 | 显示全部楼层
ISL6260 Multi-Phase Core Regulator for IMVP-VI Mobile CPUs
ISL6271A Integrated XScale Regulator
ISL6291 Battery Charger, Li-ion, Li-Polymer, 4.1/4.2V, Programmable Current Limit, 1% Accuracy
ISL6292 Single Input Embedded Charger, Accepts Cardle or USB
ISL6292B Charger Embedded in Wall Adapter Cable Assembly
ISL6292C Single Input Embedded Charger with Remote VSENSE
ISL6292D Single Input Embedded Charger with Blinking Status
ISL6293-2 Auto-Switching Two Input (Cradle and USB) with High Voltage Cradle Input
ISL6294 Single Input Embedded Charger with High Input Voltage Rating
ISL6296 FlexiHash? For Battery Authentication
ISL6298 Small Cell Capacity Applications (ie Bluetooth), Cell Capacity <500mAH, High Accuracy CC Control
ISL6299 Auto-Switching Two Input (Cradle and USB) with High Voltage Cradle Input
ISL6308 3-Phase PWM Controller with High Current Integrated MOSFET Drivers
ISL6310 Two-Phase Buck PWM Controller with High Current Integrated MOSFET Drivers
ISL6401 Single-Ended Current Mode PWM Controller with Synchronize. Reference design provides SLIC power with -24V and -72V outputs.
ISL6402 Dual PWM Controllers with Wide VIN, Fsw 300kHz and Linear Controller
ISL6402A Dual PWM Controllers with Wide VIN, Fsw 1.4MHz and Linear Controller
ISL6405 Regulator, Current Mode Boost PWM, Dual Output LNB Supply, with I2C Interface, Selectable output 13V or 18V @ 750mA
ISL6406 PWM Controller with Adj Fsw 100kHz to 770kHz with Ext Freq Sync
ISL6410 0.6A PWM Regulator with Selectable VOUT of 1.8V, 1.5V, or 1.2V, Fsw 750kHz, Adj POR Delay in QFN pkg.
ISL6410A 0.6A PWM Regulator with Selectable VOUT of 3.3V, 1.8V, or 1.2V, Fsw 750kHz, Adj POR Delay in QFN pkg.
ISL6412 Triple Output, Low-Noise LDO Regulator with Integrated Reset Circuit
ISL6413 Triple Output Regulator with Single Synchronous Buck and Dual LDO
ISL6414 Triple Output, Low-Noise LDO Regulator with Integrated Reset Circuit
ISL6416 Triple Output, Low-Noise LDO Regulator with Integrated Reset Circuit
ISL6420 PWM Controller with Wide VIN, Fsw 100kHz to 1.4MHz
ISL6421 Single Output LNB Supply and Control Voltage Regulator with I2C Interface for Advanced Satellite Set-Top Box Designs
ISL6421A Single Output LNB Supply and Control Voltage Regulator with I2C Interface for Advanced Satellite Set-top Box Designs
ISL6424 Dual Output LNB Supply and Control Voltage Regulator with I2C Interface for Advanced Satellite Set-Top Box Designs
ISL6425 Single Output LNB Supply and Control Voltage Regulator with I2C Interface for Advanced Satellite Set-top Box Designs
ISL6439 PWM Controller with Fsw 300 or 600kHz
ISL6440 Dual PWM Controllers with Wide VIN, Fsw 300kHz
ISL6441 Dual PWM Controllers with Wide VIN, Fsw 1.4MHz and Linear Controller
ISL6443 Dual PWM Controllers with Wide VIN, Fsw 300kHz and Linear Controller
ISL6504 Four-Output Linear Power Controller, ACPI Control Interface, 5Vdual is shut down in S4/S5 Sleep States
ISL6504A Four-Output Linear Power Controller, ACPI Control Interface, 5Vdual stays on in S4/S5 Sleep States
ISL6505 Four-Output Linear Power Controller, ACPI Control Interface, User select 1.2 to 1.5V LAN/Gigabit Ethernet
ISL6506 Dual-Output Linear Power Controller, 5V Dual, 3.3V Dual (1A LDO)
ISL6506B Dual-Output Linear Power Controller, 5V Dual, 3.3V Dual (2A LDO)
ISL6520 PWM Controller, +5V Input, VOUT 0.8V Min @ 1.5%, 300kHz, COMP/OCSET Pin
ISL6520A PWM Controller, +5V Input, VOUT 0.8V Min @ 1.5%, 300kHz, COMP/OCSET Pin, with Shoot-Thru Protection
ISL6521 PWM Controller and Triple Linear Controllers
ISL6522 PWM Controller, +5V or +12V Supply, VOUT = 0.8V Min@ ±1% Reg
ISL6522B Buck and Synchronous Recti?er PWM Controller
ISL6523 PWM Controller and Dual Linear Reg, VRM8.5, 5-Bit DAC, Core ±1% Reg, PWM2 ±3% Reg, Linear ±3%
ISL6524 PWM Controller and Triple Linear Reg, VRM8.5, 5-Bit DAC, Core ±1%, Linears ±3%
ISL6524A PWM Controller and Triple Linear Reg, VRM8.5, 5-Bit DAC, Core ±1%, Linears ±3%
ISL6525 PWM Controller, VOUT 1.20V Min @ ±1% Reg, +5V or +12V Supply, 200kHz Free-Running Osc Programmable 50kHz to 1+MHz
ISL6526 PWM Controller, VOUT 0.8V Min @ ±1.5% Reg, 3.3V to 5V Supply, 300kHz Osc
ISL6526A PWM Controller, VOUT 0.8V Min @ ±1.5% Reg, 3.3V to 5V Supply, 600kHz Osc
ISL6527 PWM Controller with Fsw 300 or 600kHz, External Reference
ISL6527A PWM Controller with Fsw 300 or 600kHz, External Reference
ISL6528 PWM and Linear Power Controller
ISL6529 PWM and Linear Power Controller
ISL6530 Dual PWM Controller, Dual DDR @ 1% Reg, with S3 Sleep Mode
ISL6532 PWM Controller and Triple LDO Regulator 2%, Dual Channel DDR/DDR2 Memory Power, ACPI Compliant, Freq = 250kHz
ISL6532A ACPI PWM Controller and Triple LDO Regulator
ISL6532B PWM Controller and Triple LDO Regulator 2%, ACPI Regulator/Controller for Dual Channel DDR Memory Systems Overcurrent on Vtt
ISL6532C PWM Controller and Triple LDO Regulator 2%, ACPI Regulator/Controller for Dual Channel DDR Memory Systems, Overcurrent on Vtt, 1.5V LDO for Video/Core
ISL6534 Dual PWM Controllers with DDR Mode and Linear Controller
ISL6536 Supervisory IC, 4 Channel
ISL6536A Four Channel Supervisory IC
ISL6537 ACPI Regulator/Controller for Dual Channel DDR Memory Systems
ISL6537A ACPI Regulator/Controller for Dual Channel DDR Memory Systems
ISL6539 Wide Input Range Dual PWM Controller with DDR Option
ISL6548 ACPI Regulator/Controller for Dual Channel DDR Memory Systems
ISL6548A ACPI Regulator/Controller for Dual Channel DDR Memory Systems
ISL6549 PWM Controller and LDO Regulator 1%; Freq = (adjustable 100 to 1000kHz)
ISL6551 ZVS Full Bridge PWM Controller with Synchronous Rectifier Outputs and Current Sharing
ISL6552 PWM Controller, 2-4 Phase, 5-Bit VID, ±1% Reg, VCORE = 1.05/1.825V
 楼主| 发表于 2008-6-12 10:58:34 | 显示全部楼层
ISL6553 PWM Controller, 2-Phase, 5-Bit VID, ±1% Reg, VCORE = 1.05/1.825V
ISL6554 PWM Controller, 2-4 Phase, Intel ? Itanium? Processor, Without Programmable Droop, 5-Bit VID, ±1% Reg
ISL6556A PWM Controller, 2-4 Phase, 6-Bit VID, VOUT = 0.8375 to 1.60V, ±0.5% Reg, RDS (on)sensing with External Temp Compensation, >1MHz operation, Application = μP Core Voltage VR10.X, use with HIP6601B
ISL6556B PWM Controller, 2-4 Phase, 6-Bit VID, VOUT = 0.8375 to 1.60V, ±0.5% Reg, RDS on)sensing and Internal Temp Compensation, >1MHz operation, Application = μP Core Voltage VR10.X, use with HIP6601B
ISL6557A PWM Controller, 2-4 Phase, 5-Bit Dynamic-VID, ±0.8% Regulation, Adjust UV Threshold
ISL6558 PWM Controller, 2-4 Phase, No DAC, Optional Active Voltage Positioning
ISL6559 PWM Controller, 2-4 Phase, 5-Bit VID, ±1% Reg, VCORE = 0.80/1.55V
ISL6560 PWM Controller, 2-Phase Current Mode, 5-Bit VID, Reg ±0.8%, 1.1-1.85 Voltage, VRM 9.0
ISL6561 PWM Controller, 2-4 Phase, 6-Bit VID, Precision rDS(ON) or DCR sensing, Reg ±0.5%
ISL6563 Two-Phase Multiphase Buck PWM Controller with Integrated MOSFET Drivers
ISL6564 Multiphase PWM Controller with Linear 6-Bit DAC Capable of Precision rDS(ON) or DCR Differential Current Sensing
ISL6565A Multiphase PWM Controller with Precision rDS(ON) or DCR Current Sensing for VR10.X Application
ISL6565B Multiphase PWM Controller with Precision rDS(ON) or DCR Current Sensing for VR10.X Application
ISL6566 Three-Phase Buck PWM Controller with Integrated MOSFET Drivers for VRM9, VRM10, and AMD Hammer Applications
ISL6568 Two-Phase Buck PWM Controller with Integrated MOSFET Drivers for VRM9, VRM10, and AMD Hammer Applications
ISL6569 PWM Controller, 2-Phase, 5-Bit DAC, Reg ±1%, VCORE = 0.80/1.55V
ISL6571 MOSFET Driver with Integrated FETs, Synchronous Half-Bridge, 1MHz Freq, use with HIP6301 Controller
ISL6594A High Frequency Three-State MOSFET Driver with Pre-POR Over Voltage Protection and a 36V Internal Bootstrap Schottky Diode. 3.3V PWM Signaling for Use with Digital PWM Controllers. Fixed 12V UGATE with Adjustable LGATE Between 5V and 12V
ISL6594B High Frequency Three-State MOSFET Driver with Pre-POR Over Voltage Protection and a 36V Internal Bootstrap Schottky Diode. 3.3V PWM Signaling for Use with Digital PWM Controllers. Adjustable UGATE and LGATE Between 5V and 12V
ISL6605 MOSFET Driver, Dual, Synchronous Half-Bridge Switch, use with Multiphase Controller, 4 Amp Sink, VBOOT
ISL6608 Synchronous Rectified MOSFET Driver
ISL6612 Advanced Synchronous Rectified Buck MOSFET Drivers with Protection Features
ISL6612A Advanced Synchronous Rectified Buck MOSFET Drivers with Pre-POR OVP
ISL6612B Advanced Synchronous Rectified Buck MOSFET Drivers with Pre-POR OVP
ISL6613 Advanced Synchronous Rectified Buck MOSFET Drivers with Protection Features
ISL6613A Advanced Synchronous Rectified Buck MOSFET Drivers with Pre-POR OVP
ISL6613B Advanced Synchronous Rectified Buck MOSFET Drivers with Pre-POR OVP
ISL6614 Dual Advanced Synchronous Rectified Buck MOSFET Drivers with Protection Features
ISL6614A Dual Advanced Synchronous Rectified Buck MOSFET Drivers with Pre-POR OVP
ISL6614B Dual Advanced Synchronous Rectified Buck MOSFET Drivers with Protection Features
ISL6700 80V/1.25A Peak, Half Bridge N-Channel MOSFET Driver
ISL6721 Single-Ended Current Mode PWM controller with synchronize and advanced fault protection features
ISL6729 Low-Cost Single-Ended Current-Mode PWM for Microcontroller Based Power Converters
ISL6740 Double-ended PWM Controller For Half Bridge and Bus Converter Applications
ISL6740A Double-ended Voltage-mode PWM Controller With Voltage Feedforward
ISL6741 PWM controller for hard-switched full bridge and push-pull applications
ISL6742 Double-ended PWM Controller With Synchronous Rectifier Outputs and Average Current Limiting
ISL6744 Intermediate Bus PWM Controller with Precision Dead-Time Adjustment
ISL6745 Voltage-Mode Bridge Controller with Precision Dead-Time Adjustment
ISL6752 ZVS Full Bridge PWM Controller with Synchronous Rectifier Outputs
ISL6753 ZVS Full Bridge PWM Controller
ISL6840 Improved Industry Standard Single-Ended Current Mode PWM Controller. UVLO = 7.0V; Dmax = 100%
ISL6841 Improved Industry Standard Single-Ended Current Mode PWM Controller. UVLO = 7.0V; Dmax = 50%
ISL6842 Improved Industry Standard Single-Ended Current Mode PWM Controller. UVLO = 14.4 V; Dmax = 100%
ISL6843 Improved Industry Standard Single-Ended Current Mode PWM Controller. UVLO = 8.4V; Dmax = 100%
ISL6844 Improved Industry Standard Single-Ended Current Mode PWM Controller. UVLO = 14.4V; Dmax = 50%
ISL6845 Improved Industry Standard Single-Ended Current Mode PWM Controller. UVLO = 8.4V; Dmax = 50%
ISL81485 5V, 30Mbps, RS-485/RS-422 Transceiver
ISL81486 5V, Ultra High Speed, PROFIBUS, RS-485/RS-422 Transceivers
ISL81487E ±15kV ESD Protected, 1/8 Unit Load, Half Duplex, 5V, Low Power, High Speed, RS-485/RS-422 Transceivers, with Rx/Tx Enables
ISL81487L ±15kV ESD Protected, 1/8 Unit Load, Half Duplex, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 Transceivers, with Rx/Tx Enables and Low Power SHDN
ISL83080E ±15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers
ISL83082E ±15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers
ISL83083E ±15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers
ISL83085E ±15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers
ISL83086E ±15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers
ISL83088E ±15kV ESD Protected, 5V, Full Fail-Safe, Fractional (1/8) Unit Load, RS-485/RS-422 Transceivers
ISL83220E RS-232 Transceiver, 1T/1R, +3V to +5.5V, 250kbps, 15kV ESD (IEC61000), Manual Powerdown
ISL8323 Analog Switch, SPST, Dual, NOpen, Low-Voltage, RON 175 @ 3.3V and 60 @ 5V, Single Supply, +2.7V to +12V
ISL8324 Analog Switch, SPST, Dual, NClosed, Low-Voltage, RON 175 @ 3.3V and 60 @ 5V, Single Supply, +2.7V to +12V
ISL8325 Analog Switch, SPST, Dual, NOpen/NClosed, Low-Voltage, RON 175 @ 3.3V and 60 @ 5V, Single Supply, +2.7V to +12V
ISL83384E RS-232 Transceiver, 2T/2R, +3V to +5.5V, 250kbps, 15kV ESD (IEC61000), Manual Powerdown Disables Transmitters/Receivers
ISL83386E RS-232 Transceiver, 3T/2R, +3V to +5.5V, 250kbps, 15kV ESD (IEC61000), Manual Powerdown with VL
ISL83483 3.3V, Low Power, High Speed or Slew Rate Limited, RS-485/RS-422 Transceivers
ISL83485 3.3V, Low Power, High Speed or Slew Rate Limited, RS-485/RS-422 Transceivers
ISL83488 3.3V, Low Power, High Speed or Slew Rate Limited, RS-485/RS-422 Transceivers
ISL83490 3.3V, Low Power, High Speed or Slew Rate Limited, RS-485/RS-422 Transceivers
ISL83491 3.3V, Low Power, High Speed or Slew Rate Limited, RS-485/RS-422 Transceivers
ISL83699 Ultra Low ON-Resistance, Low Voltage, Single Supply, Quad SPDT (Dual DPDT) Analog Switch
ISL8391 Analog Switch, SPST, Quad, NClosed, RON 20 @ ±5V, Single Supply, +2V to +12V or Dual Supply ±2V to ±6V
ISL8392 Analog Switch, SPST, Quad, NOpen, RON 20 @ ±5V, Single Supply, +2V to +12V or Dual Supply ±2V to ±6V
ISL8393 Analog Switch or 2-1 Multiplexer, SPST, Quad, 2 x NClosed, 2 x NOpen, RON 20 @ ±5V, Single Supply, +2V to +12V or Dual Supply ±2V to ±6V
ISL8394 Analog Switch or Multiplexer, SPDT, Quad, 2 x NOpen, 2 x NClosed, RON 17 @ ±5V, Single Supply, +2V to +12V or Dual Supply ±2.0V to ±6V
ISL84051 Multiplexer, 8 to 1, Low-Voltage 2V-12V, Single or Dual Supply, RON = 100W, TTL/CMOS Inputs
ISL84052 Multiplexer, Dual 4 to 1, Low-Voltage 2V-12V, Single or Dual Supply, RON = 100W, TTL/CMOS Inputs
ISL84053 Analog Switch, Triple SPDT, Low-Voltage 2V-12V, Single or Dual Supply, RON = 100W, TTL/CMOS Inputs
 楼主| 发表于 2008-6-12 10:58:45 | 显示全部楼层
ISL84514 Analog Switch, SPST, Single, NOpen, RON = 20 @ 3.3V, 12 @ 5V and 8 @ 12V, RON Flatness Max 3W , Single Supply, +2.4V to +12V
ISL84515 Analog Switch, SPST, Single, NClosed, RON = 20 @ 3.3V, 12 @ 5V and 8 @ 12V, RON Flatness Max 3W , Single Supply, +2.4V to +12V
ISL84516 Analog Switch, SPST, Single, NOpen, RON = 13 @ ±5V, RON Flatness Max 3W, ±1.5V to ±6V Supply
ISL84517 Analog Switch, SPST, Single, NClosed, RON = 13 @ ±5V, RON Flatness Max 3W , ±1.5V to ±6V Supply
ISL84521 Analog Switch, SPST, Quad, NClosed, Low-Voltage, RON = 65 @ ±5V, 125 @ 5V, 260 @ 3.0V, Single or Dual Supply
ISL84522 Analog Switch, SPST, Quad, NOpen, Low-Voltage, RON = 65 @ ±5V, 125 @ 5V, 260 @ 3.0V, Single or Dual Supply
ISL84523 Analog Switch, SPST, Quad, NOpen/NClosed, Low-Voltage, RON = 65 @ ±5V, 125 @ 5V, 260 @ 3.0V, Single or Dual Supply
ISL84524 Multiplexer, Demultiplexer, 4 Channel, Low-Voltage, RON = 92 @ 5V, Single Supply 2V to 12V, with Inhibit
ISL84525 Analog Switch, DPDT, Low-Voltage, RON = 92 @ 5V, Single Supply 2V to 12V, with inhibit
ISL84541 Analog Switch, SPST, Dual, NOpen, Low-Voltage, RON = 50 @ 3.3V and 30 @ 5V, Single Supply, +2.7V to +12V
ISL84542 Analog Switch, SPST, Dual, NClosed, Low-Voltage, RON = 50 @ 3.3V and 30 @ 5V, Single Supply, +2.7V to +12V
ISL84543 Analog Switch, SPST, Dual, NOpen/NClosed, Low-Voltage, RON = 50 @ 3.3V and 30 @ 5V, Single Supply, +2.7V to +12V
ISL84544 Analog Switch or 2-1 Multiplexer, SPDT, NOpen/NClosed, Dual, Low-Voltage, RON = 50 @ 3.3V and 30 @ 5V, Single Supply, +2.7V to +12V
ISL84684 Ultra Low ON-Resistance, Low Voltage, Single Supply, Dual SPDT Analog Switch
ISL84714 Ultra Low ON-Resistance, Low Voltage, Single Supply, SPDT Analog Switch
ISL84715 Ultra Low ON-Resistance, Low Voltage, Single Supply, SPST Analog Switches
ISL84716 Ultra Low ON-Resistance, Low Voltage, Single Supply, SPST Analog Switches
ISL84780 Ultra Low ON-Resistance, Low Voltage, Single Supply, Quad 2:1 Analog Multiplexer
ISL84781 Ultra Low ON-Resistance, Low-Voltage, Single Supply, 8 to 1 Analog Multiplexer
ISL8483E RS-485/RS-422 Transceivers, ESD Protected to ±15kV, Half Duplex, 250kbps, Slew Rate Limited, 5V, with Rx/Tx Enables and Low Power SHDN
ISL8484 Ultra Low ON-Resistance, Low Voltage, Single Supply, Dual SPDT Analog Switch
ISL8485E RS-485/RS-422 Transceivers, ESD Protected to ±15kV, Half Duplex, 5Mbps, 5V, with Rx/Tx Enables
ISL8487E ±15kV ESD Protected, 1/8 Unit Load, Half Duplex, 5V, Low Power, Slew Rate Limited, RS-485/RS-422 Transceivers, with Rx/Tx Enables and Low Power SHDN
ISL8488E ±15kV ESD Protected, 5V, Low Power, 250kbps, Slew Rate Limited, Full Duplex, RS-485/RS-422 Transceivers
ISL8489E ±15kV ESD Protected, 5V, Low Power, Slew Rate Limited, Full Duplex, RS-485/RS-422 Transceivers
ISL8491 RS-485 Transceiver, Full Duplex, 5Mbps, 5V, with Rx/Tx Enables
ISL8491E ±15kV ESD Protected, 5V, Low Power, High Speed, Full Duplex, RS-485/RS-422 Transceivers
ISL8499 Ultra Low ON-Resistance, Low Voltage, Single Supply, Quad SPDT (Dual DPDT) Analog Switch
ISL88694 SMBus Accelerator (SMA)
ISL95310 Digitally Controlled Potentiometer (XDCP?), Terminal Voltage 0V to 13.2V, 128 Taps Up/Down Interface
ISL95311 Digitally Controlled Potentiometer (XDCP?), Terminal Voltage 0V to 13.2V, 128 Taps I2C Interface
X5083 CPU Supervisor with 8Kbit SPI EEPROM
X9241A Quad Digitally Controlled Potentiometer (XDCP?)
X9259 Quad Digitally Controlled Potentiometer (XDCP?)
X9313 Digitally Controlled Potentiometer (XDCP?)
X93154 Digitally Controlled Potentiometer (XDCP?)
X98014 140MHz Triple Video Digitizer with Digital PLL
X98017 170MHz Triple Video Digitizer with Digital PLL
X98021 210MHz Triple Video Digitizer with Digital PLL
X98024 240MHz Triple Video Digitizer with Digital PLL
X98027 275MHz Triple Video Digitizer with Digital PLL
X9C103 Digitally Controlled Potentiometer (XDCP?)
GMT+8, 2026-9-28 09:53 , Processed in 0.041440 second(s), 6 queries , Gzip On, File On.
