查看: 1566|回复: 6
请问如何获取图形控件上鼠标所到点的坐标值?
发表于 2008-6-14 16:47:54 | 显示全部楼层 |阅读模式
发表于 2008-6-14 16:50:21 | 显示全部楼层
兄弟说的是哪个控件?
发表于 2008-6-14 17:05:41 | 显示全部楼层
Obtains information about the state of the mouse cursor. xCoordinate and yCoordinate return the position of the mouse relative to the top and left coordinates of a specific control. If you pass zero as the controlID, the coordinate information references the top and left coordinates of the panel, excluding the panel frame and title bar. GetRelativeMouseState returns the coordinates even if the mouse is not over the control or the panel.
Prototype
int GetRelativeMouseState (int Panel_Handle, int Control_ID, int *XCoordinate, int *YCoordinate, int *Left_Button_Down, int *Right_Button_Down, int *Key_Modifiers);
发表于 2008-6-14 17:06:08 | 显示全部楼层
兄弟可以看看这个,不知道您要的是不是这样的!
发表于 2008-6-14 17:38:36 | 显示全部楼层
还有就是可以用这个图形控件的事件,鼠标事件的event data中就有鼠标坐标的信息
 楼主| 发表于 2008-6-14 21:35:34 | 显示全部楼层
谢谢以上各位,这个问题我自己解决了
发表于 2008-6-14 22:11:35 | 显示全部楼层
解决了得共享经验给大家学习,呵呵!多谢兄弟!
GMT+8, 2026-9-28 20:15 , Processed in 0.034983 second(s), 6 queries , Gzip On, File On.
