查看: 747|回复: 2
求助!想了解pci6024的详细参数!
发表于 2008-6-16 19:38:17 | 显示全部楼层 |阅读模式
各位大虾,有知道pci6024数据采集卡参数的吗?或者在哪里可以查到?我在百度上收了半天没有找到!希望知道的,能告诉下!!谢谢了!
发表于 2008-6-16 22:53:37 | 显示全部楼层
如下所示:
[ 本帖最后由 cpubbs 于 2008-6-16 22:54 编辑 ]
发表于 2008-6-16 22:54:43 | 显示全部楼层
Specifications Summary
General
Form Factor PCI
OS Support Windows, Real-Time, Linux, Mac OS
DAQ Product Family E Series
LabVIEW RT Support Yes
Analog Input
Number of Channels 16 SE/8 DI
Sample Rate 200 kS/s
Resolution 12 bits
Simultaneous Sampling No
Maximum Voltage Range -10..10 V
      Range Accuracy 16.504 mV
Minimum Voltage Range -50..50 mV
      Range Accuracy 0.106 mV
Number of Ranges 4
On-Board Memory 512 samples
Analog Output
Number of Channels 2
Update Rate 10 kS/s
Resolution 12 bits
      Range Accuracy 8.127 mV
Minimum Voltage Range -10..10 V
Current Drive (Channel/Total) 5 mA
Digital I/O
Number of Channels 8 DIO
Timing Software
Logic Levels TTL
Maximum Input Range 0..5 V
Maximum Output Range 0..5 V
Input Current Flow Sinking, Sourcing
Programmable Input Filters No
Output Current Flow Sinking, Sourcing
Current Drive (Channel/Total) 24 mA/192 mA
Watchdog Timer No
Supports Programmable Power-Up States? No
Supports Handshaking I/O? No
Supports Pattern I/O? No
Counter/Timers
Number of Counter/Timers 2
Resolution 24 bits
Maximum Source Frequency 20 MHz
Minimum Input Pulse Width 10 ns
Logic Levels TTL
Maximum Range 0..5 V
Timebase Stability 100 ppm
GPS Synchronization No
Pulse Generation Yes
Buffered Operations Yes
Debouncing/Glitch Removal No
Number of DMA Channels 1
Timing/Triggering/Synchronization
Synchronization Bus (RTSI) Yes
Triggering Digital
Physical Specifications
Length 17.5 cm
Width 10.7 cm
I/O Connector 68-pin male SCSI-II type
GMT+8, 2026-9-30 05:04 , Processed in 0.033604 second(s), 6 queries , Gzip On, File On.
