查看: 2007|回复: 11
求助:关于异步时钟
发表于 2008-7-1 14:59:27 | 显示全部楼层 |阅读模式
请问一下在cvi7.0与cvi8.0中对异步时钟的定义有什么不同吗?为什么在7.0里编译能通过的程序在8.0里面编译时总是提示有错呢?提示连接错误.出错信息如下:
  Undefined symbol '_NewAsyncTimer@24' referenced in "ScanFrq.c".
  Undefined symbol '_DiscardAsyncTimer@4' referenced in "ScanFrq.c".
  Undefined symbol '_SetAsyncTimerAttribute' referenced in "ScanFrq.c".
请高手帮我分析一下原因!
[ 本帖最后由 tonwelzt 于 2008-7-3 10:24 编辑 ]
发表于 2008-7-1 18:56:29 | 显示全部楼层
兄弟最好上传程序,这样方便编译调试查错!不然不容易查出来的!比如您这种情况有些是没有添加相应的LIB的原因!
 楼主| 发表于 2008-7-3 10:03:00 | 显示全部楼层
回复 2# cpubbs 的帖子
下面是主程序。请大狭帮忙查找一下出错的原因,小弟先在这里拜谢了。
#include <windows.h>
#include "excel2000.h"
#include <analysis.h>
#include "toolbox.h"
#include <rs232.h>
#include "analysis.h"
#include <mmsystem.h>
#include <asynctmr.h>
#include <utility.h>
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "ScanFrq.h"
static ExcelObj_App               ExcelAppHandle = 0;
static ExcelObj_Workbooks         ExcelWorkbooksHandle = 0;
static ExcelObj_Workbook          ExcelWorkbookHandle = 0;
static ExcelObj_Window            ExcelWindowHandle = 0;
static ExcelObj_Sheets            ExcelSheetsHandle = 0;
static ExcelObj_Worksheet         ExcelWorksheetHandle = 0;
static ExcelObj_Range             ExcelRangeHandle = 0;
static ExcelObj_Dialog            DialogHandle = 0;
static VARIANT MyCellRangeV;
static ERRORINFO ErrorInfo;
BSTR   TempBSTR=0;
char   fileName[MAX_PATHNAME_LEN];
WAVEFORMATEX        m_WaveFormatEx;
HWAVEOUT              m_hPlay;
HWAVEIN                    m_hRecord;
LPWAVEHDR             OutlpHdr, InlpHdr;
#define SamplesRate  11000
int             CycNum;
static int      SamplesLength, InputNum;
double          Vrms0=0, Vrms;
int             Fo=0, FoCount=0, VrmsCount=0, Count=0;
static double   MeanVal, StdDist, MeasArray[30];
short           *iOutput, *iInput;
double          *fOutput, *fInput,*f1Output;
double          *sineWave=NULL;
double          Phase=0.0;
static int      panelHandle;
static int      StartFrq, StopFrq, StepFrq, ATimerCount;
static double   StepTime, Level, freq, sinefreq;
static int      ATimerID=0;
int CVICALLBACK ATimer_Process (int panel, int control, int event,void *callbackData,
                                    int eventData1, int eventData2);
int Test(void);
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
                       LPSTR lpszCmdLine, int nCmdShow)
        if (InitCVIRTE (hInstance, 0, 0) == 0)
                return -1;
        CA_InitActiveXThreadStyleForCurrentThread (0, COINIT_APARTMENTTHREADED);
    SetSleepPolicy (VAL_SLEEP_MORE);
        if ((panelHandle = LoadPanel (0, "ScanFrq.uir", PANEL)) < 0)
                return -1;
        Clear1D (MeasArray, 30);
        Count=MeanVal=StdDist=0;
        SetCtrlVal(panelHandle, PANEL_Count, Count);
        SetCtrlVal(panelHandle, PANEL_Avage, MeanVal);
        SetCtrlVal(panelHandle, PANEL_STD_V, StdDist);
        do
            ATimerID=NewAsyncTimer(0.01, -1, 0, ATimer_Process, 0);
        while(ATimerID<=0);
        OpenComConfig(1, "", 9600, 1, 8, 1, 256, 256);
        memset(&m_WaveFormatEx,0x00,sizeof(m_WaveFormatEx));
        m_WaveFormatEx.wFormatTag = WAVE_FORMAT_PCM;
        m_WaveFormatEx.nChannels = 1;
        m_WaveFormatEx.wBitsPerSample = 16;
        m_WaveFormatEx.cbSize = 0;
        m_WaveFormatEx.nSamplesPerSec = SamplesRate;
        m_WaveFormatEx.nAvgBytesPerSec = m_WaveFormatEx.nSamplesPerSec*(m_WaveFormatEx.wBitsPerSample/8);
        m_WaveFormatEx.nBlockAlign = (m_WaveFormatEx.wBitsPerSample/8)*m_WaveFormatEx.nChannels;
        DisplayPanel (panelHandle);
        RunUserInterface ();
        waveOutReset(m_hPlay);
        waveOutClose(m_hPlay);
        waveInReset(m_hRecord);
        waveInClose(m_hRecord);
        if (iOutput)        free(iOutput);
        if (fOutput)        free(fOutput);
        if (iInput)                free(iInput);
        if (fInput)                free(fInput);
        DiscardPanel (panelHandle);
        CloseCom (1);
        DiscardAsyncTimer (-1);
        return 0;
编译时具体的出错信息如下:
3 Project link errors
    ——Undefined symbol '_NewAsyncTimer@24' referenced in "ScanFrq.c".
    ——Undefined symbol '_DiscardAsyncTimer@4' referenced in "ScanFrq.c".
    ——Undefined symbol '_ATimer_Process' referenced in "ScanFrq.c".
发表于 2008-7-3 10:19:19 | 显示全部楼层
压缩一下程序上传吧兄弟,这样没有办法调试的!在CVI中调试比较容易查到原因!直接贴上来,很多相关的东西都没有,没有办法查的,比如一些相关的面板之类的,呵呵!
 楼主| 发表于 2008-7-3 10:25:58 | 显示全部楼层
回复 4# cpubbs 的帖子
谢谢大狭了  已经上传了!
 楼主| 发表于 2008-7-3 10:30:45 | 显示全部楼层
回复 4# cpubbs 的帖子
我这里还有另外一个项目的程序,我考过来在我的8.0里面调试好象也有同样的问题的,并且都是连接错误。
发表于 2008-7-3 10:49:19 | 显示全部楼层
这个只有定义,没有函数实体,估计是一个文件损失!
发表于 2008-7-3 10:49:51 | 显示全部楼层
至于您上面说到的那几个问题,将它的这个FP加上就可以解决了,但这个文件损失的没有办法,我一会找一下路径给您看加哪个FP!
发表于 2008-7-3 10:50:43 | 显示全部楼层
C:\Program Files\National Instruments\CVI85\toolslib\toolbox\asynctmr.fp
将它添加到项目中即可!那几个问题就可以解决了,上面那另外一个缺失的函数的,您得找原作者要!
 楼主| 发表于 2008-7-3 11:12:13 | 显示全部楼层
回复 9# cpubbs 的帖子
多谢多谢了!我按照您说的方法添加后已经可以调试通过了,多谢大狭帮忙。嘿嘿 这个问题已经困绕小弟好几天了。
发表于 2008-7-7 22:05:22 | 显示全部楼层
异步时间控件不是怎么好用的
是由系统多媒体时钟控制不影响其他程序,但是会“卡”
suyanju 该用户已被删除
发表于 2009-10-14 09:33:17 | 显示全部楼层
楼主您好!请问下面这句话的作用是什么?正在迷惑中,请帮忙指点迷津!谢谢阿!
GMT+8, 2026-9-28 09:51 , Processed in 0.062871 second(s), 15 queries , Gzip On, File On.
