查看: 760|回复: 6
帮忙看看这几个题
发表于 2008-10-21 10:16:01 | 显示全部楼层 |阅读模式
For best performance when programming a sequence of functions or calculations, you should use a:
A
Stacked Sequence structure.
B
Flat Sequence structure.
C
Both A. and B. have the same performance.
Under which of the following settings would you not apply a gain to your signal?
A
10 V signal with 0-5 V ADC range
B
10 V signal, with 0-10 V ADC range
C
1 V signal with 0-10 V ADC range
D
5 V signal with 0-10 V ADC range
All of the following statements about Arrays are true, EXCEPT:
A
Arrays may be used to store data generated in loops.
B
Array elements are not ordered.
C
Arrays may contain either Controls or Indicators, but not both.
D
Arrays group data elements of the same type.
E
All of the above statements are true.
 楼主| 发表于 2008-10-21 16:12:51 | 显示全部楼层
发表于 2008-10-21 16:14:41 | 显示全部楼层
 楼主| 发表于 2008-10-21 17:03:25 | 显示全部楼层
才3道题,咋会出现4个答案....
发表于 2008-10-21 19:07:49 | 显示全部楼层
发表于 2008-10-21 20:45:58 | 显示全部楼层
 楼主| 发表于 2008-10-22 00:00:45 | 显示全部楼层
编辑同样的代码a+b=c,如果分别使用Stacked Sequence structure和Flat Sequence structure结构,再使用Tools下面的VI性能和内存检查,发现二者的代码占用内存空间貌似是不一样的啊...................欢迎讨论
GMT+8, 2026-9-29 23:08 , Processed in 0.042819 second(s), 9 queries , Gzip On, File On.
