查看: 5757|回复: 6
[求助]求一个例子的vi(Draw Edges Position.vi)
感叹号 该用户已被删除
发表于 2008-11-14 23:47:15 | 显示全部楼层 |阅读模式
搜索了很久都没找到有下载,看到一个帖子回复提到这个例子(下文贴出来的),不知道如何才能下到。先谢谢大家了
Vous avez oublié d'attacher la list de vosexemples disponibles. Mon dossier exemple contient une soixantaine devis ou llbs. La liste des vis est la suivante :
2D Barcode.vi
AVI Compare.vi
AVI Compressor Comparison Example.vi
AVI Copy.vi
AVI Read Write With Data Example.vi
Add Example.vi
BCG Lookup Example.vi
Barcode Example.vi
Battery Clamp Inspection Example.vi
Blister Pack Inspection Example.vi
Browser Example.vi
Build Elliptical ROI by Radius.vi
Circle Distance Example.vi
Clamp Example.vi
Classification Example.vi
Classification Overlay and Histogram.vi
Classification Particle Analysis.vi
Classification.vi
Color Distance Example.vi
Color Pattern Matching Example.vi
ColorLearn Example.vi
ColorMatching Example.vi
ColorThreshold Example.vi
Compare Example.vi
Compressor Name.vi
Distance Inspection.vi
Draw Edges Position (Clear Overlay).vi
Draw Fails.vi
Draw Pattern Matches Position .vi
Draw Pattern Matches Position With Color and Label.vi
Draw Pattern Matches Position With Separate Color.vi
Draw Pattern Matches Position.vi
Draw Pins Positions.vi
DrawText Example.vi
Edge Detection Example.vi
Extract Example.vi
Find Coins.vi
Fuse Inspection Example.vi
Fuse Overaly Pass Fail.vi
Fusebox Inspection Example.vi
Gauging Example.vi
Generate Distortion Target Lines.vi
Geometric Matching Example.vi
Geometric Matching with Calibration Example.vi
Get DataMatrix Options.vi
Get New Image From Folder (Path).vi
Get New Image From Folder.vi
Get New Image.vi
Get QR Code Options.vi
Golden Template Inspection Example.vi
Histogram Example.vi
IMAQ Vision AVI Folder.vi
IMAQ Vision Example folder.vi
Image Averaging Example.vi
ImageToArray Example.vi
LCD Example.vi
Label Example.vi
Learn Multiple Geometric Patterns Example.vi
Light Meter Example.vi
LineProfile Example.vi
MagicWand Example.vi
Mask Example.vi
Match Multiple Geometric Patterns Example.vi
MathLookup Example.vi
Measure Distortion Target.vi
Mechanical Assembly Example.vi
Meter Example.vi
Morphological Segmentation Example.vi
Nonlinear Calibration Example.vi
OCR Draw Bounding Boxes.vi
OCR Example.vi
OCR First Example.vi
Overlay Area Values.vi
Overlay Blister Pack Matches Position.vi
Overlay Color Distance Results.vi
Overlay Coordinate System.vi
Overlay Fusebox Matches Position.vi
Overlay Line with Arrows Perspective.vi
Overlay Line with Arrows Simple.vi
Overlay Matches Position Color.vi
Overlay Matches Position Simple.vi
Overlay Straight Edges.vi
Particle Analysis Example.vi
Particle Analysis Report Example.vi
Particle Orientation Example.vi
Parts.clf
Perspective Calibration Example.vi
Pins Inspection.vi
Read AVI Example.vi
ReadFile Example.vi
Rotating Part Example.vi
Sample Data.vi
Set AVI Image Size.vi
Simple Calibration Example.vi
Straight Edge Detection Example.vi
Unwrap Barcode Example.vi
[ 本帖最后由 感叹号 于 2008-11-14 23:49 编辑 ]
发表于 2008-11-15 00:06:16 | 显示全部楼层
是不是某个工具包里面的呢兄弟?
感叹号 该用户已被删除
 楼主| 发表于 2008-11-15 00:11:08 | 显示全部楼层
刚接触 一切都不熟悉啊 安装了labview、 Acquisition Software 、Development Module。运行了别人的程序(图像检测方面的) 提示说要加载Draw Edges Position.vi
可能和IMAQ Find CoordSys (2 Rects)有关,这个如何才能下载到?
[ 本帖最后由 感叹号 于 2008-11-15 00:22 编辑 ]
发表于 2008-11-15 00:27:22 | 显示全部楼层
您说是图像方面的,是不是要装IMAQ VISION之类的工具包,这个工具包我也没有用过,希望有用过的兄弟能说说!谢谢!
感叹号 该用户已被删除
 楼主| 发表于 2008-11-15 00:42:47 | 显示全部楼层
http://www.kxcad.com/ni-vision-f ... ordsys-2-rects-2-vi  有IMAQ Find CoordSys (2 Rects)的说明,最后一行说道LabVIEW\examples\Vision\3. Applications\Fuse Inspection Example.llb 用到了这个实例,可怎么才能提取出这个vi?
发表于 2008-11-15 00:44:16 | 显示全部楼层
如果是工具包里面的话,得装了才行,不然也弄不出来的!它是运行的时候再从工具包里面LOAD进来!没有工具包它也不会装载!如果您确信它在您说的这个地方,您可以双击相应的子VI再另存为也可以提取到的!或者直接将它复制到您的VI中当成子VI!
发表于 2008-11-15 22:06:53 | 显示全部楼层
labview的TOOLS菜单提供有FIND VIs ON DISK你可以试下
GMT+8, 2026-9-29 23:08 , Processed in 0.044004 second(s), 10 queries , Gzip On, File On.
