查看: 4097|回复: 17
labview pdf工具包Carya PDF Toolkit
发表于 2008-11-30 20:56:55 | 显示全部楼层 |阅读模式
Carya PDF Toolkit:
INSTALLATION
There are two ways to install the Carya PDF Toolkit:
1.
Copy the directories into your 'userlib'-folder on your computer and restart LabVIEW. OR
2.
Add the Toolkit to your palette:
LabVIEW 7.1
A Select "Tools" >  "Advanced" >> "Edit Palette Views...".  Select in the "Functions" Window "User Libaries". Rightclick in this window and click "Insert"> "Submenu...". Select "Link to an existing menu file (.mnu)". Browse to the Toolkit directory and select the dir.mnu file in the Toolkit Folder.
LabVIEW 8
A Select "Tools" >  "Advanced" >> "Edit Palette Set...". Select in the "Functions" Window "User Libaries". Rightclick in this window and click "Insert"> "Subpalette...". Select "Link to an existing palette file (.mnu)". Browse to the Toolkit directory and select the dir.mnu file in the Toolkit Folder.
CONTENTS
The following directories contains the Carya PDF Toolkit:
- Attach: VIs that attach the data after the previous attached objects;
- Document: VIs to Create and Save PDF-documents;
- Examples, VIs with PDF examples;
- Get, Get object or PDF information;
- Insert, VIs that inserts the objects in a user-specified box in your PDF-document;
- Set, Set object or PDF information;
- SubVIs, Used SubVIs in PDF-toolkit;
- Tools, VIs for your comfort.
Show Context Help (Ctrl+H) to see the description of the VI's.
QUESTIONS
For any questions contact Carya Automatisering for support: PDFToolkit@carya.nl
LICENSE
Read the License for this Toolkit on our website: www.carya.nl or contact us: PDFToolkit@carya.nl
 楼主| 发表于 2008-11-30 20:58:02 | 显示全部楼层
发表于 2008-11-30 22:11:04 | 显示全部楼层
这个工具包不同版本不一样,最好注明版本
另外可以从他们网站下载对应版本的TOOLKIT
Louis 该用户已被删除
发表于 2008-12-1 12:02:45 | 显示全部楼层
非常感谢!!!!!!
发表于 2008-12-2 08:11:18 | 显示全部楼层
  感谢您的分享
发表于 2009-1-21 14:10:52 | 显示全部楼层
发表于 2009-1-21 14:45:48 | 显示全部楼层
2# tester
好东西不少啊,都是从哪里弄的呢
是单位买的吗
发表于 2009-3-30 09:23:41 | 显示全部楼层
发表于 2009-3-31 12:05:48 | 显示全部楼层
同感,朋友如何能把它去掉,而且能显示中文?
发表于 2009-4-21 22:07:50 | 显示全部楼层
发表于 2009-4-25 05:27:28 | 显示全部楼层
感謝提供寶貴資料!
发表于 2009-4-28 16:12:45 | 显示全部楼层
发表于 2009-5-5 16:01:49 | 显示全部楼层
这个工具包不同版本不一样,最好注明版本
lgh269 发表于 2008-11-30 22:11
是的
发表于 2010-6-10 14:27:22 | 显示全部楼层
发表于 2011-1-21 10:06:35 | 显示全部楼层
GMT+8, 2026-9-28 03:23 , Processed in 0.062909 second(s), 13 queries , Gzip On, File On.
