查看: 2481|回复: 5
数据怎么保存为txt文件
发表于 2008-12-5 15:17:09 | 显示全部楼层 |阅读模式
请问如何将4个通道采集的数据按行或者按列保存到文本文件中?请大家帮忙解答呀
发表于 2008-12-6 10:38:48 | 显示全部楼层
试试ArrayToFile函数,看行不
发表于 2009-7-21 11:21:57 | 显示全部楼层
发表于 2009-7-21 13:17:19 | 显示全部楼层
楼主是想将4个通道的数据保存在同一个文件中吗?如果是这样的话,那么你的数据是放在数组中的吗?如果是的话,那么可以直接用C的fprintf()函数,假如你将数据放在数组data[4]中,实现方法如下:
file_data=fopen(pfileName,"w+");
fprintf(file_data,"%4.3",data[0]);
fprintf(file_data,"%s","\t");
fprintf(file_data,"%4.3f",data[1]);
fprintf(file_data,"%4.3",data[2]);
fprintf(file_data,"%4.3f",data[3]);
fprintf(file_data,"%s","\n");
fclose(file_data);
这样就实现了按列存储(第一列为1通道的数据,第二列为2通道的数据,...),以上只是一个最简单的做法,楼主可以根据自己的需要进行扩充
发表于 2009-9-18 10:30:14 | 显示全部楼层
学习一下。
漫凡谚 该用户已被删除
发表于 2009-10-6 15:08:39 | 显示全部楼层
A friend of mine purchased Replica Rolex.The appearance of the watch is so nice that i also want to own it! We together lodged in the web Replica Rolex and chose an attractive Replica Watches.It feels so good that i always wear it on my hand.By now i have worn it for three months and have not found any problem.No wonder the quality is favorable. I believe it and will introduce it to more people!
GMT+8, 2026-9-28 11:40 , Processed in 0.033777 second(s), 8 queries , Gzip On, File On.
