查看: 1220|回复: 6
VB拷屏
发表于 2008-12-23 09:23:01 | 显示全部楼层 |阅读模式
我要用VB写个拷屏的程序,就是将屏幕拷屏,然后存入一个文件,整了好久没搞定,哪位兄弟可以帮忙啊?谢谢了!
发表于 2008-12-23 09:25:51 | 显示全部楼层
记得以前在一本书中看到过类似的文章,是远程拷屏的,有空再找一下吧.看看能不能找到.
发表于 2008-12-23 09:31:45 | 显示全部楼层
如果你用的是2005,.NET   Framework   2.0   版中是新增了Graphics.CopyFromScreen   方法。
  试试看。
发表于 2008-12-23 09:33:26 | 显示全部楼层
再有就是调用API的方式,以下内容是从网上找到的,可以参考一下,是用C#写的.
struct   GetDeviceCapsIndex
  public   static   readonly   int   DRIVERVERSION   =   0;
  public   static   readonly   int   HORZSIZE   =   4;
  public   static   readonly   int   VERTSIZE   =   6;
  public   static   readonly   int   HORZRES   =   8;
  public   static   readonly   int   VERTRES   =   10;
  [StructLayout(LayoutKind.Sequential,   CharSet=CharSet.Auto)]
  public   struct   LUID
  public   uint   LowPart;
  public   uint   HighPart;
  public   struct   TOKEN_PRIVILEGES
  public   uint   PrivilegeCount;
  public   LUID   Luid;
  public   uint   Attributes;
  public   class   Win32API
  [DllImport("Advapi32",   CharSet=CharSet.Auto)]
  public   static   extern   bool   LookupPrivilegeValue   (string   sysname,string   privname,ref   LUID   luid);
  [DllImport("advapi32",   CharSet=CharSet.Auto)]
  public   static   extern   bool   AdjustTokenPrivileges(IntPtr   handle,   bool   dsall,ref   TOKEN_PRIVILEGES   newstate,int   len,   IntPtr   oldstate,IntPtr   retlen);
  [DllImport("kernel32.dll")]
  public   static   extern   int   GetLastError();
  [DllImport("user32.dll")]
  public   static   extern   bool   ExitWindowsEx(int   uFlags,   int   dwReason);
  [DllImport("gdi32.dll")]
  public   static   extern   IntPtr   CreateDC(
  string   lpszDriver,                 //   driver   name
  string   lpszDevice,                 //   device   name
  string   lpszOutput,                 //   not   used;   should   be   NULL
  Int64   lpInitData     //   optional   printer   data
  public   static   extern   IntPtr   CreateCompatibleDC(
  IntPtr   hdc   //   handle   to   DC
  public   static   extern   int   GetDeviceCaps(
  IntPtr   hdc,           //   handle   to   DC
  int   nIndex       //   index   of   capability
  public   static   extern   IntPtr   CreateCompatibleBitmap(
  int   nWidth,           //   width   of   bitmap,   in   pixels
  int   nHeight           //   height   of   bitmap,   in   pixels
  public   static   extern   IntPtr   SelectObject(
  IntPtr   hgdiobj       //   handle   to   object
  public   static   extern   int   BitBlt(
  IntPtr   hdcDest,   //   handle   to   destination   DC
  int   nXDest,     //   x-coord   of   destination   upper-left   corner
  int   nYDest,     //   y-coord   of   destination   upper-left   corner
  int   nWidth,     //   width   of   destination   rectangle
  int   nHeight,   //   height   of   destination   rectangle
  IntPtr   hdcSrc,     //   handle   to   source   DC
  int   nXSrc,       //   x-coordinate   of   source   upper-left   corner
  int   nYSrc,       //   y-coordinate   of   source   upper-left   corner
  UInt32   dwRop     //   raster   operation   code
  public   static   extern   int   DeleteDC(
  public   class   GDI
  public   static   Bitmap   GetScreen()
  IntPtr   hscrdc,hmemdc;
  IntPtr   hbitmap,holdbitmap;
  int   nx,ny,nx2,ny2;
  nx=ny=nx2=ny2=0;
  int   nwidth,   nheight;
  int   xscrn,   yscrn;
  hscrdc   =   Win32API.CreateDC("DISPLAY",   null,   null,   0);//创建DC句柄
  hmemdc   =   Win32API.CreateCompatibleDC(hscrdc);//创建一个内存DC
  xscrn   =   Win32API.GetDeviceCaps(hscrdc,   GetDeviceCapsIndex.HORZRES);//获取屏幕宽度
  yscrn   =   Win32API.GetDeviceCaps(hscrdc,   GetDeviceCapsIndex.VERTRES);//获取屏幕高度
  nx   =   0;
  ny   =   0;
  nx2   =   xscrn;
  ny2   =   yscrn;
  nwidth   =   nx2   -   nx;//截取范围的宽度
  nheight   =   ny2   -   ny;//截取范围的高度
  hbitmap   =   Win32API.CreateCompatibleBitmap(hscrdc,   nwidth,   nheight);//从内存DC复制到hbitmap句柄
  holdbitmap   =   Win32API.SelectObject(hmemdc,   hbitmap);
  Win32API.BitBlt(hmemdc,   0,   0,   nwidth,   nheight,hscrdc,   nx,   ny,(UInt32)0xcc0020);
  hbitmap   =   Win32API.SelectObject(hmemdc,   holdbitmap);
  Win32API.DeleteDC(hscrdc);//删除用过的对象
  Win32API.DeleteDC(hmemdc);//删除用过的对象
  return   Bitmap.FromHbitmap(hbitmap);//用Bitmap.FromHbitmap从hbitmap返回Bitmap
以上的调用的API声明,以下是主程序:
public   virtual   void   OnGetScreen()
  Bitmap   bmp   =   GDI.GetScreen();
  Sender   sender   =   new   Sender();
  MemoryStream   mem   =   new   MemoryStream();
  bmp.Save(mem   ,   System.Drawing.Imaging.ImageFormat.Jpeg);
  bmp.Dispose();
  byte[]   pic;
  pic   =   mem.GetBuffer();
  mem.Close();
  sender.Send(pic);
发表于 2008-12-23 09:37:04 | 显示全部楼层
以下是一个网友写的VB拷屏的例子,你可以参考一下.
 楼主| 发表于 2008-12-26 09:03:24 | 显示全部楼层
 楼主| 发表于 2008-12-26 19:07:05 | 显示全部楼层
Ricken:
    我还想问一下:如果要将指定的窗口拷屏下来(比方说,现在应用程序正在运行,如果要将计算器的界面拷下来),该怎么整呢?如何将拷屏的图像存入文件呢?谢谢
GMT+8, 2026-9-28 11:31 , Processed in 0.048721 second(s), 12 queries , Gzip On, File On.
