查看: 1034|回复: 3
labview8.5可否与VISTA系统兼容?有哪些开发软件与它不兼容?
发表于 2009-1-7 14:38:36 | 显示全部楼层 |阅读模式
想换成VISTA系统开发,不知道labview8.5可否与VISTA系统兼容?好像labview8.5对多核开发挺强得,是这样吗?
我还用vc6.0 、。net2003、matlab7.5、foxpro数据库、oracle8i。。。开发软件,不知道有哪些与VISTA系统不兼容?
给个建议先!
谢谢!
发表于 2009-1-7 19:35:27 | 显示全部楼层
Platforms Supported
LabVIEW 8.5 includes the following changes in platforms supported:
LabVIEW 8.5 supports Windows Vista x86 and x64.
LabVIEW 8.5 supports Macintosh computers with both Intel and PowerPC processors.
发表于 2009-1-7 19:35:57 | 显示全部楼层
Windows Vista Compatibility Issues
LabVIEW 8.5 supports the Windows Vista OS on 32 and 64-bit systems with the following functionality changes.
The In Port and Out Port VIs do not appear on the Functions palette because they allow read/write access to any I/O port on the system, which is discouraged for security reasons on the Vista OS.
(Windows Vista x86) VI components install properly but show up as unsigned in the Windows Defender log. The VIs do run properly.
(Windows Vista x64) These VIs return error -4850
 楼主| 发表于 2009-1-9 13:47:04 | 显示全部楼层
GMT+8, 2026-9-29 20:18 , Processed in 0.031372 second(s), 7 queries , Gzip On, File On.
