查看: 1104|回复: 2
Read GIF File
发表于 2009-2-6 12:59:51 | 显示全部楼层 |阅读模式
 楼主| 发表于 2009-2-6 13:00:15 | 显示全部楼层
This example was first published in the LabVIEW Forum, but i want to publish also a LabVIEW 7.1 version.
The additional input "image index" is used to select the image, which should be available at the image data output.
Currently it supports only gif files with version 89a.
Interlaced images are not taken into account.
The vi inside of the "Read GIF File" function can also be used to read all images of a Gif file. More about how to use it can be seen in the GIF._Example.vi which is also part of the attached zip file.
Version 01.01
- first image is now index 0
 楼主| 发表于 2009-2-6 13:00:29 | 显示全部楼层
GMT+8, 2026-9-28 06:26 , Processed in 0.024263 second(s), 7 queries , Gzip On, File On.
