查看: 1058|回复: 3
Vi, Vit, Ctl Icon and Documentation Editor
发表于 2009-2-6 13:02:30 | 显示全部楼层 |阅读模式
 楼主| 发表于 2009-2-6 13:02:52 | 显示全部楼层
With the RUAG ICON Editor you can Edit the ICONS's and the Documentation of Vi, Vit, Ctl
RUAG ICON Editor v1.5.1 - 25.10.2006Copyright © 2006, Martin Hasler----
This is the currend RUAG ICON Editor for LabVIEW 8.x
Have a lot of Fun with LabVIEW
Author:Martin.Hasler
martin.hasler@aerodynamics.ch
Description:Copy the Files Icon.llb and RUAG-Icon-Editor.vi into your LabVIEW 8.x/project/  DirectoryIf you start LabVIEW the next Time, the RUAG-ICON-Editor appears under LabVIEW Tools (Werkzeuge).With the RUAG Icon Editor you can create or modify ICONS from Vi, Vit, Ctl and you can edit the Documentation.
The information about the ICON will be saved into the VI-Documentation.=> First: Click  "Load Directory" => Click "Tree-Control" to choose your VI to modify.=> You can modify the colorsets by Editing the Color_Set.vi in theIcon.llb. Do not forget to click on: Save current values as default.=> DO NOT USE THE FOLLOWING SINGN IN THE TITLE OR BODY!!    §
!http://forums.lavag.org/style_emoticons/default/excl.gif|alt=http://forums.lavag .org/style_emoticons/default/excl.gif!  => Dobble -click your VI in the "Tree-Control" to open the VI.Support:If you have any problems with this code or want to suggest features:
http://forums.lavag.org/index.php?showtopic=4471
Version History:
V1.0 The Original Version 1 was made by Pascal Helfenstein  phelfens@fhzh.ch
V1.1  You can reload the old Icon.            &n bsp;       You can Choose Color Sets.            &n bsp;       Help button.                     Changes will be saved into the VI documentation.
V1.2  You can Edit Icons in llb            &nbs p;      You can Edit Icons from *.vit, *.ctl, *.vi
V1.3  The Pictures (New Icon, Old Icon etc.) are bigger            & nbsp;      Bug Fixed that you have to press "Write Icon" twice for Vi's which are in a Project.
V1.4  More Documentation, (BD & FP) "Straighten the Code"
V1.5  "Edit Documentation" included
V1.5.1 Rearranged all Buttons. If you edit the Icon the first time, text=black, Title and Body= white An old version of the ICON Editor (LabVIEW 7.1) is available on request
 楼主| 发表于 2009-2-6 13:03:07 | 显示全部楼层
 楼主| 发表于 2009-2-6 13:03:54 | 显示全部楼层
GMT+8, 2026-9-28 07:29 , Processed in 0.030643 second(s), 7 queries , Gzip On, File On.
