查看: 894|回复: 2
Convert Waveform to 2D Array
发表于 2009-2-6 13:06:14 | 显示全部楼层 |阅读模式
 楼主| 发表于 2009-2-6 13:06:32 | 显示全部楼层
The Waveform to 2D Array polymorphic VI will convert any single waveform or 1D array of waveforms to a 2D array of doubles.
The above figure shows a case where this could be used, converting the waveform data being generated by your code into a 2D array for the Write To Spreadsheet File VI.
If instead of a single waveform you have a 1D array of waveforms the Waveform to 2D Array polymorphic VI will adjust the instance to convert the 1D array of waveforms to a single 2D Array of doubles. The resulting array will only have time information in the first column, indexed according to the timing of the first waveform. This instance could easily be modified to provide a different method for this conversion, such as having individual time columns for each waveform/channel
 楼主| 发表于 2009-2-6 13:06:39 | 显示全部楼层
GMT+8, 2026-9-28 07:30 , Processed in 0.042723 second(s), 6 queries , Gzip On, File On.
