查看: 1155|回复: 1
State Machine
发表于 2009-2-6 13:13:01 | 显示全部楼层 |阅读模式
 楼主| 发表于 2009-2-6 13:13:11 | 显示全部楼层
If the program you are writing needs to be event-driven instead of following the traditional data-flow style of LabVIEW, start with this. Simply place the different events into the case structures.
GMT+8, 2026-9-28 07:30 , Processed in 0.030512 second(s), 6 queries , Gzip On, File On.
