查看: 954|回复: 1
LabVIEW Hyperterminal
发表于 2009-2-6 13:19:45 | 显示全部楼层 |阅读模式
 楼主| 发表于 2009-2-6 13:19:52 | 显示全部楼层
This is an old example I've had for years- but it is still the most requested program I have. This emulates the Hyperterminal program in Windows- letting you connect to a serial device, adjust the setup parameters, and send/receive messages. This is most useful as a way to troubleshoot your device, and once you have communication working you can use the same parameters to write your own LabVIEW program.
GMT+8, 2026-9-28 08:39 , Processed in 0.023363 second(s), 6 queries , Gzip On, File On.
