型号是:pci-mio-16xe-10,我想用C++来读出采集到的数据.
找到一个好像是例子的程序,不过有点莫名其妙,哪位高人帮我看看 ,谢谢.
* ANSI C Example program:
* Acq-IntClk.c
* Example Category:
* AI
* Description:
* This example demonstrates how to acquire a finite amount of data
* using the DAQ device's internal clock.
* Instructions for Running:
* 1. Select the physical channel to correspond to where your
* signal is input on the DAQ device.
* 2. Enter the minimum and maximum voltages.
* Note: For better accuracy try to match the input range to the
* expected voltage level of the measured signal.
* 3. Select the number of samples to acquire.
* 4. Set the rate of the acquisition.
* Note: The rate should be AT LEAST twice as fast as the maximum
* frequency component of the signal being acquired.
* Steps:
* 1. Create a task.
* 2. Create an analog input voltage channel.
* 3. Set the rate for the sample clock. Additionally, define the
* sample mode to be finite and set the number of samples to be
* acquired per channel.
* 4. Call the Start function to start the acquisition.
* 5. Read all of the waveform data.
* 6. Call the Clear Task function to clear the task.
* 7. Display an error if any.
* I/O Connections Overview:
* Make sure your signal input terminal matches the Physical
* Channel I/O Control. For further connection information, refer
* to your hardware reference manual.
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
int32 error=0;
TaskHandle taskHandle=0;
int32 read;
float64 data[1000];
char errBuff[2048]={'\0'};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1000,10.0,DAQmx_Val_GroupByChannel,data,1000,&read,NULL));
printf("Acquired %d points\n",read);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
