查看: 640|回复: 5
在打包时,总出现如下的错误提示
发表于 2009-3-8 13:26:33 | 显示全部楼层 |阅读模式
The following file(s) are not found on the system:
D:\WORK\builds\andan Application\data\lvjpeg
但是看了一下,这个文件lvjpeg.dll,是存在的啊
是我哪里用错了吗
labview是8.2的
 楼主| 发表于 2009-3-8 13:40:54 | 显示全部楼层
发表于 2009-3-8 16:36:48 | 显示全部楼层
检查你的project里面有没有断开的vi
发表于 2009-3-8 17:04:57 | 显示全部楼层
打开一些VI,看保存没,没保存保存下。应该可以。
Any way, rather than just copying the files to my project heirarchy, I opened the two VIs (_Excel Dynamic VIs.vi and _Word Dynamic VIs.) and noticed that they had the unsaved asterisk (*) in the title bar. I "Saved All" and that fixed the problem.
 楼主| 发表于 2009-3-8 19:47:58 | 显示全部楼层
http://forums.ni.com/ni/board/message?board.id=170&message.id=202624
fjczd 发表于 2009-3-8 13:40
http://forums.ni.com/里有详细的说明
 楼主| 发表于 2009-3-25 21:19:59 | 显示全部楼层
I had the same problem with the lvjpeg folder as Brandon. I had just built another application where the problem did not occur, but my new project used the Report Generation Toolset. So I included the _Excel Dynamic VIs.vi and _Word Dynamic VIs.vi in the project. When I built the executable, the lvjpeg folder was displayed as a part of the executable package. Then I built the installation package, I got the same error message. And as it turns out, I had also completely deleted all NI products from my workstation so that I would have a clean install of LV 7.1, LV 8.0.1, and LV 8.2.0. (Of course, the Report Generation Toolset only works on the LV 8.2.0 installation, sad to say).
Chuck
GMT+8, 2026-9-29 17:33 , Processed in 0.028423 second(s), 6 queries , Gzip On, File On.
