CLAD的题,请问大侠CLAD的题,请问大侠.有些题甚至不明白题意,希望各位大侠能告诉我答案,如果能写上一两句提示一下更好,题目下面的选项是我的选择。谢谢
1)Which chart update mode plots new data from left to right, then clears the chart and plots the newer data?
A
| Strip Chart
| B
| Sweep Chart
| C
| Step Chart
| D
| Scope Chart
我认为是B,完全蒙的
2)Which of the following is a recommended terminal connection for the Append Text Table to Report VI shown below?
2009-3-8 21:49
A
| column width (1)
| B
| column headers
| C
| row headers
| D
| All of the above
D
3)Which of the following functions should be used to replace an element of an existing Cluster when the order of elements in the Cluster is unknown?
A
| Unbundle
| B
| Bundle by Name
| C
| Unbundle by Name
| D
| Bundle
D
4)All of the following statements concerning Sequence Structures are true, EXCEPT:
A
| The use of a single Sequence Structure in a VI prohibits parallel operations.
| B
| Sequence Structures guarantee order of execution.
| C
| Sequence Structures should be replaced with a While Loop containing Case Structures whenever possible.
| D
| Sequence Structures halt execution when an error occurs in one of the frames.
D
5)How would you turn off the Debugging capabilities of a VI?
A
| You cannot turn off debugging because it is an integral part of the LabVIEW environment.
| B
| Make the VI a SubVI and then select Above Priority to automatically turn of debugging.
| C
| Select VI Properties, and deselect Allow Debugging from the Execution sub-menu.
A
6)How does changing a DAQ board from a 0-10 volt range to a -10 to 10 volt range, affect the minimum voltage change that can be detected?
A
| The minimum voltage change that can be detected will depend inversely with the resolution of the board.
| B
| The minimum voltage change that can be detected will be split in half.
| C
| There will be no effect on the minimum voltage change that can be detected.
| D
| The minimum voltage change that can be detected will be doubled.
D
7)Program functionality comments should be included on the:
A
| Block Diagram.
| B
| Front Panel.
| C
| Both A. and B.
| D
| None of the above. Comments are not needed in graphical programming.
C
