查看: 877|回复: 3
谁能有8.6版的labveiw,帮忙把这个程序转到8.2下,谢谢了
发表于 2009-3-19 22:14:24 | 显示全部楼层 |阅读模式
找到一个利用Report Generation Toolkit读取excel中数据的例子,但是,它是用labview8.6写的,我的版本是8.2,哪位能帮忙转换一下呢?谢谢了
 楼主| 发表于 2009-3-19 22:15:11 | 显示全部楼层
http://decibel.ni.com/content/docs/DOC-3033
上边的是网址,大家也可从那里下载
Reading Excel Data Using the Report Generation Toolkit
创建于: 2009-1-6 上午11:54 作者 Justin_P - 最后修改:  2009-1-6 下午12:39 作者 Justin_P
Requirements:
Application Software: LabVIEW Base Development System 8.6
Driver Software: NI-RIO 3.0
Hardware Family: Reconfigurable I/O (RIO)
Add-on Software: LabVIEW Report Generation Toolkit for Microsoft Office 1.1.3
Product Category: LabVIEW
Development Topic: File I/O
Industry: Education
Application Type: Sound and Audio
Technology: Bluetooth
This simple program is a demonstration of how to use the LabVIEW Report Generation Toolkit to read data from Excel.  The first part of the program is a File Dialog Express.vi that selects the Excel file that you want to read (use the read_eecel_values.xls in the attached zip file).  Then the correct worksheet is selected with the "Excel Get Worksheet.vi".  This is done with the worksheet index number for the first two sheets and by worksheet name in the last.  After each "Excel Get Worksheet.vi" there is an "Excel Get Data.vi".  For the 2-D array data types you must give start and end points for the array.  For non-arrays you only need to give the location of the cell.
附件:
•        Read Excel Values.zip (25.6 K)
204 Downloads
 楼主| 发表于 2009-3-20 08:17:37 | 显示全部楼层
看来还的装8.6的啊
ni 升级太频繁了
 楼主| 发表于 2009-3-20 11:41:54 | 显示全部楼层
自己做了一个
用labview8.2的
希望对大家有所帮助
GMT+8, 2026-9-29 17:33 , Processed in 0.044658 second(s), 11 queries , Gzip On, File On.
