查看: 780|回复: 5
急找NISCOPE的相关资料
发表于 2009-4-10 23:20:54 | 显示全部楼层 |阅读模式
请问各位谁有关于NISCOPE的资料吗?最好是有关编程方面的!由于在这方面的书籍很少,对于这方面的编程知识很缺乏,所以只能招大家帮帮忙,拜托了!!先谢谢大家了!!!
发表于 2009-4-10 23:39:38 | 显示全部楼层
转贴一个来自NI的例子!
This example uses the niScope driver to perform a single configured acquisition off of a single channel.  The acquisition will start on an analog edge and this start will cause a 5 V TTL trigger to be exported on a desired PFI/PXI Trigger/RTSI Line.  The niScope Export Trigger VI can be found under Measurement I/O»NI-SCOPE»Triggering»niScope Export Trigger.vi.
This screenshot of the block diagram shows the export trigger VI.
发表于 2009-4-10 23:40:08 | 显示全部楼层
发表于 2009-4-10 23:58:41 | 显示全部楼层
第二个:
NI Scope Synchronization With DAQmx Analog Output版本 3
Requirements: Application Software: LabVIEW Professional Development System 8.6
Driver Software: NI-SCOPE 3.4
Hardware Family: High-Speed Digitizers (Scopes)
Functional Description
This example shows how to synchronize an analog acquisition task using NI Scope with an Analog Output task using NI DAQmx on a PXI system.
The master task is the analog input which exports a Reference Trigger Signal on the PXI TTL 1 line. The slave task, the Analog Output,  is configured with a Digital Trigger on the PXI TTL 1 line, so these two tasks become synchronized because they share the same trigger signal (PXI TTL 1 line)
Caveats and Additional Notes
Software Used: LabVIEW 8.6, NI DAQmx 8.8, NI Scope 3.4.1
发表于 2009-4-10 23:59:24 | 显示全部楼层
 楼主| 发表于 2009-4-15 20:49:22 | 显示全部楼层
谢谢!请问你还有用NIscope做的有关连续采集的例子吗?
GMT+8, 2026-9-29 16:11 , Processed in 0.035274 second(s), 7 queries , Gzip On, File On.
