查看: 921|回复: 3
每次只能删除一条记录???
发表于 2009-5-25 20:06:21 | 显示全部楼层 |阅读模式
DBPrepareSQL (g_DBC_Handle,"DELETE FROM table WHERE Module_Name = ? AND Serial_Number = ? AND Test_Type = ?");
DBCreateParamChar (g_Statement_Handle, "Module_Name", ARAM_INPUT, Value_Module_Name, 20);
DBCreateParamChar (g_Statement_Handle, "Serial_Number", ARAM_INPUT, Value_Serial_Number, 40);
DBCreateParamChar (g_Statement_Handle, "Test_Type",DB_PARAM_INPUT, Value_Test_Type, 20);
DBExecutePreparedSQL (g_DBC_Handle);
DBClosePreparedSQL (g_DBC_Handle);
每次点删除按钮的时候只能删除一条记录,退出界面之后,再重新进入面又可删除一条,请问下,这个是什么原因啊????
发表于 2009-5-26 09:02:04 | 显示全部楼层
当你以为问题可能出在这几行时,问题恰恰可能出现在其它地方!就这几句是无法看出明显的问题的!
 楼主| 发表于 2009-5-26 17:47:42 | 显示全部楼层
哦,看来我还得多调试几次啊!
 楼主| 发表于 2009-5-27 17:27:19 | 显示全部楼层
g_Statement_Handle = DBActivateSQL (g_DBC_Handle, "SELECT * FROM DataTable);
resCode = DBBindColChar ();
while(DBFetchNext (g_Statement_Handle) == DB_SUCCESS)
  resCode = DBDeleteRecord (g_Statement_Handle);
我这样用了之后,就没有出现只能删除一行的现象.
GMT+8, 2026-9-28 09:12 , Processed in 0.034205 second(s), 8 queries , Gzip On, File On.
