查看: 847|回复: 2
请大家帮忙提供下解决意见
发表于 2009-5-31 10:12:33 | 显示全部楼层 |阅读模式
我在采用ni采集卡进行计数时遇到下面的这个问题:
Measurements: Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
基本都是在timeout的那个时间就弹出这个出错框了。请教下各位,碰到过这种情况吗?
发表于 2009-5-31 12:31:13 | 显示全部楼层
溢出覆盖了。
 楼主| 发表于 2009-5-31 14:05:46 | 显示全部楼层
2# 三岁就很帅
请问,有什么解决的办法吗?
GMT+8, 2026-9-29 13:39 , Processed in 0.027666 second(s), 7 queries , Gzip On, File On.
