查看: 784|回复: 0
电子无忧网 批量供应Xilinx USB 下载电缆企业版
发表于 2009-8-28 14:00:06 | 显示全部楼层 |阅读模式
本产品适用于Xilinx 全系列CPLD/FPGA芯片的下载调试。
Xilinx USB 下载电缆 Xilinx Platform USB Cable
全兼容XILINX USB下载电缆,xilinx impact下载线
产品特点
1.完全兼容XILINX原厂Xilinx Platform Cable USB电缆,支持自动升级固件程序;
2.即插即用设备,USB总线供电(无需外接电源);尤其适合于没有并口的笔记本电脑;
3.可配置所有Xilinx的器件;
4.支持边界扫描(JTAG)和Slave Serial配置模式;
5.目标下载时钟频率可选,最高可达24MHz,下载速度快。(普通XILINX电缆 Parallel III并口电缆下载速度仅200KHz);
6.自动电压调节设计可以适应目标板电压从+1.5V~ 5 V;
7.支持Windows和Linux版本的ISE, EDK, Chipscope pro ;
8.兼容全速和高速USB端口;
9.最新ISE9.2版本的固件软件,速度比以前版本软体大幅度提升;
10.质保:推广期间自购买之日起一周之内无条件退款。质量问题,一个月保换,一年保修;
   电子无忧网专业品质保证,解决您使用过程中的问题,免您的后顾之忧;
11.推广期内送2G EDA视频教学资料及FPGA设计学习资料 DVD光盘,让您设计学习更快捷;
12.我们同时提供大门数FPGA评估开发套件及项目解决方案,具体信息欢迎登录网站查询;
更多产品信息,欢迎登录网站或电话查询。
联系人:孙婧云
All compatible Xilinx Platform USB Cable
True plug-and-play
Bus-powered USB device (no power supply required)
Selectable target clock frequency up to 24 MHz
Compatible with Full-Speed and Hi-Speed USB ports
USB-IF certified
Firmware downloadable over cable
Target power status LED
CE and FCC compliant
Compatible with target voltages in the range of +1.5 VDC to +3.3 VDC
iMPACT and ChipScope support in ISE 6.3.03i (Windows only)
Linux support in ISE 7.1i
Supports Boundary Scan and Slave-Serial configuration modes
SUPPORT:
Virtex Series  Spartan Series  CoolRunner XC9500 Config FLASH
Virtex-5 Spartan-3A CoolRunner-II XC9500XV Platform Flash
Virtex-4 Spartan-3E CoolRunner XPLA3 XC9500XL XC18Vxx Series
Virtex-II Pro Spartan-IIE XC9500
Virtex-II Spartan-II
Virtex-E Spartan
Virtex
This release includes further reduction of Erase, Program and Verify (EPV) times:
- XCF00P by 50% (approx.)
- XCF00S by 60% (approx.)
- XC18V00 PROMs by 65% (approx.)
- CPLDs by 30% to 50% (approx.), depending on family
Significant algorithm improvements:
- Reduced programming time for Platform Flash PROMs     (XCF00P) by 70%
- Reduced programming times for CPLDs between 15         and 50%, depending on family
- Enhanced performance with Xilinx EDK tools:
- MicroBlaze download times reduced ~500%
- PowerPC download times reduced ~5000%
- Debug latency (MicroBlaze and PowerPC) reduced ~500%
TEL: 010-51299598  010-62535108-11  FAX:010-62535108-17
MOBIL:13671276968
QQ:349646210     MSN:dz51.com@163.com
GMT+8, 2026-9-28 06:38 , Processed in 0.019237 second(s), 7 queries , Gzip On, File On.
