楼主: ttongg
labview 2009 crack
hydrogeneater 该用户已被删除
发表于 2010-9-7 14:56:44 | 显示全部楼层
lum08261984 该用户已被删除
发表于 2010-9-7 16:27:50 | 显示全部楼层
lb4177 该用户已被删除
发表于 2010-9-9 20:58:42 | 显示全部楼层
蒋伟 该用户已被删除
发表于 2010-9-11 09:06:09 | 显示全部楼层
qiang2433 该用户已被删除
发表于 2010-9-12 10:32:48 | 显示全部楼层
Ding```````````````````````````````````
sa efas fwetra fsaef saf sd sade sa
maplesnow 该用户已被删除
发表于 2010-9-14 20:23:01 | 显示全部楼层
发表于 2010-9-17 15:23:42 | 显示全部楼层
chocolate530 该用户已被删除
发表于 2010-9-22 00:40:55 | 显示全部楼层
    ░ ██▀░░      ▄██▄   █ ███ * THE BiTTER END *            ▄█▄   ░    ░▐█▌
     ▐█▌░    ■▄▄  ▀▀    ░  ▀▀█▄▄   presents                  ▀  ▄▄■     ▄▀
      ▀▄       ██                       NI                     ██     ■▀
        ▀■  ▄▄██▀        LabVIEW 2009 v9.0 Mobile Module       ▀██▄▄
      ▄███▀░░      SUPPLiER....: TEAM TBE    DATE ...: 01.09.2009  ░░▀███▄
     ▐███▌░        CRACKER ....: TEAM TBE    TYPE ...: util          ░▐███▌
      ▀███▄░░      PROTECTiON .: FlexLM      OS .....: win         ░░▄███▀
       ░▀███▄░░    LANGUAGE   .: english     SiZE ...: 1 CD      ░ ▄███▀░
         ░ ▀▄▄ ▀▀██▄▄    url:[url]www.ni.com[/url]                    ▄▄██▀▀ ▄▄▀ ░
         ░ ▄▄██▀ ░█████▄▄▄     *  RELEASE NOTES  *    ▄▄▄█████░ ▀██▄▄ ░
       ███▄  ░█      The  NI  LabVIEW Mobile Module extends      █  ░▄███
       ░▀▀██▄▄  ▄    the    LabVIEW   graphical development    ▄  ▄▄██▀▀
       ░    ▀▀▀▀     environment  to  handheld  devices, so     ▀▀▀▀█
              █      you     can    easily    create custom      █  █
              █      applications   to   run   on Microsoft      █
              █      Windows  Mobile for Pocket PC devices.      █  ░
              █      The     LabVIEW    Mobile    Module is      █
              █      compatible    with   several   NI data      █
              █      acquisition   devices,   including the      █
              █      USB-6008, USB-6009, CF-6004,                █
              █      DAQCard-6062E,      DAQCard-6024E, and      █
              █      DAQCard-6036E.   Using  these hardware      █
              █      devices,    you   can   build handheld      █
              █      measurement  systems  for applications      █
              █      ranging   from  automotive  service to      █
              █      field   diagnostics   to physiological      █
              █      monitoring.                                 █
              █      In  addition,  the Mobile Module works      █
              █      with    the   NI   PCMCIA-4050 digital      █
              █      multimeter  (DMM),  so you can build a      █
              █      customized DMM on your handheld device      █
              █      or smartphone.                              █
          ░██▄▄  ░███▄▄▄    *  iNSTALLATiON NOTES  *    ▄▄▄███░  ▄▄██░
     ▐███▌░   █     1) unpack                                     █   ░▐███▌
      ▀███▄░  █     2) burn / mount                               █   ▄███▀
        ▀▀██▄▄░     3) install                                    ▄▄██▀▀
           ▄▀▀██▄   4) crack dir                               ▄██▀▀▄
        ▀▀███▄▄▄████▄▄           *  TBE NEWS  *           ▄▄████▄▄▄███▀▀
           █  █   ░ We got several positions to fill, if at      █
           █  █ ▄   least one of the following characteristics   █
           ░  █▀█▀  fits to you:                                 █
              █     1. You work at any reseller, distributor     █
              █        or software company and have access       █
              █        to new unreleased software                █
              █     2. You are a talented cracker and able to    █
              █        handle one or more of the following       █
              █        protections:                              █
              █        Dongle, FlexLM, Armadillo, SafeDisc,      █
              █        Asprotect, SecuROM                        █
              █     3. You are able to code usefull tools in     █
              █        C/C++ or ASM                              █
              █     4. You are a keygenner and able to handle    █
              █        MD5, RSA, TEA, Blowfish, SHA1, RipeMD,    █
              █        DES, Triple DES or Rijndael Twofish       █
              █     5. You think you got something we might      █
              █        need                                      █
              █         don't hesitate to contact us:            █
              █              bitter@hush.com                     █
       ░  ░▀▀██▄▄░█▀██▄▄▄       *  WE SALUTE  *        ▄▄▄██▀█░▄▄██▀▀ █
           █░  ░████          iMMERSiON - ZWTiSO            ████░  ░█
        ▄  ▄▄███▀  ░        ISO - TMG - ACME - SSG          ░ █▀███▄▄  ▄
  ░ ▀███▄   ▀▀▀████▄▄▄ ░██▄  ▄░  asc by cpN^cRo   ▄  ▄██░ ▄▄▄████▀▀▀   ▄███▀
dzhong 该用户已被删除
发表于 2010-9-22 17:52:14 | 显示全部楼层
hsm88886 该用户已被删除
发表于 2010-9-23 11:46:55 | 显示全部楼层
gfhdfhdfhdfhdfhdfhdfbfdxbdhhsdhfdfhdfhdfhdf
kevin82418 该用户已被删除
发表于 2010-9-23 17:42:25 | 显示全部楼层
好东西啊!谢谢分享
richardhu 该用户已被删除
发表于 2010-9-27 20:34:19 | 显示全部楼层
pistachio 该用户已被删除
发表于 2010-10-4 13:07:28 | 显示全部楼层
suxiyz 该用户已被删除
发表于 2010-10-5 02:58:35 | 显示全部楼层
376743121 该用户已被删除
发表于 2010-10-5 11:02:33 | 显示全部楼层
呵呵,好东西!
GMT+8, 2026-9-28 11:02 , Processed in 0.062640 second(s), 12 queries , Gzip On, File On.
