查看: 993|回复: 1
怎么在指定的路径下新建一个文件夹?
发表于 2009-9-12 10:48:19 | 显示全部楼层 |阅读模式
在指定的路径下新建一个文件夹,用哪个函数?怎么写?
发表于 2009-9-12 22:03:18 | 显示全部楼层
Creates a new directory based on the specified directory name.
file:///c:/program%20files/national%20instruments/cvi85/bin/libref/note.gifNote    You can create only one directory at a time.
Example/* Make a new directory named \DATA\WAVEFORM on drive C */
/* assuming that C:\DATA does not exist */
MakeDir ("C:\\DATA");
MakeDir ("C:\\DATA\\WAVEFORM");
file:///c:/program%20files/national%20instruments/cvi85/bin/libref/dot.gif Prototype file:///c:/program%20files/national%20instruments/cvi85/bin/libref/dot.gif
int MakeDir (char Directory_Name[]);
GMT+8, 2026-9-28 07:31 , Processed in 0.025942 second(s), 7 queries , Gzip On, File On.
