查看: 841|回复: 0
datasocket出现问题~~
发表于 2009-11-10 14:09:41 | 显示全部楼层 |阅读模式
请教各位:
      Datasocket数据通信的时候,客户端要开通什么服务吗?我在自己的机子上打开Datasocket服务器,并写数据进去,局域网中的另一台计算机作为客户端,可是没有办法连接,请问可能是什么问题呢?
     客户端的程序:
     int CVICALLBACK OnConnectAuto (int panel, int control, int event,
    HRESULT error;
    char URL[500];
    switch (event)
        case EVENT_COMMIT:
            singleX = 0;
            ClearGraph();
            GetCtrlVal (panel, PANEL_STRING_3, URL);
   //printf("the source is %s\n",URL);
            error = DS_Open (URL, DSConst_ReadAutoUpdate,
                                       DSCallback, NULL, &dsHandle);
            break;
return 0;
void CVICALLBACK DSCallback (DSHandle dsHandle, int event, void *pUserData)
    HRESULT hr = S_OK;
    float singleFloat;
    char message[1000];
    unsigned int sz;
    unsigned type;
    switch (event) {
        case DS_EVENT_DATAUPDATED:
            ClearGraph();
            hr = DS_GetDataType (dsHandle, &type, NULL, NULL);
            if (type & CAVT_ARRAY)
                hr = DS_GetDataValue (dsHandle, CAVT_FLOAT|CAVT_ARRAY, fdata,
                                        5000*sizeof(float), &sz, NULL);
   else
                hr = DS_GetDataValue (dsHandle, CAVT_FLOAT, &singleFloat,
                                        sizeof(float), NULL, NULL);
    if (singleX >= 5000)
                    singleX = 0;
                fdata[singleX] = singleFloat;
                singleX++;
                sz = singleX;
            if (SUCCEEDED(hr))
                GraphData(fdata, sz);
            return;
            break;
        case DS_EVENT_STATUSUPDATED:
            hr = DS_GetLastMessage (dsHandle, message, 1000);
            if (SUCCEEDED(hr))
                SetCtrlVal (panelHandle, PANEL_STATUS, message);
            break;
    return;
这是CVI中所带的源代码~测试的时候却没有办法通过~~
GMT+8, 2026-9-28 08:38 , Processed in 0.021873 second(s), 7 queries , Gzip On, File On.
