查看: 4743|回复: 5
ni-pci-6221使用手册
发表于 2009-11-22 11:11:21 | 显示全部楼层 |阅读模式
请问有谁有ni-pci-6221采集卡的使用手册啊?本人正需要用到测采集卡开发设计一个自动控制系统其中需要用到次采集卡来控制步进电机精确转动!
发表于 2009-11-28 15:29:04 | 显示全部楼层
发表于 2009-11-28 15:31:33 | 显示全部楼层
发表于 2009-11-28 15:32:52 | 显示全部楼层
Print  |   [email=?subject=Link to National Instruments Web Site&body=http://sine.ni.com/ds/app/doc/p/id/ds-15/lang/en] E-mail this Page[/email]  |    Open Document as PDF
Requirements and Compatibility | Ordering Information | Detailed Specifications Analog InputAnalog OutputCalibration (AI and AO)Digital I/O/PFIGeneral-Purpose Counter/TimersFrequency GeneratorPhase-Locked Loop (PLL)External Digital TriggersBus InterfacePower RequirementsPower LimitsPhysical RequirementsMaximum Working Voltage12EnvironmentalSafetyElectromagnetic CompatibilityCE ComplianceEnvironmental Management
| Pinouts/Front Panel Connections For user manuals and dimensional drawings, visit the product page resources tab on ni.com.
Last Revised: 2008-12-01 13:13:50.0
Low-Cost M Series Multifunction Data Acquisition - 16-Bit, 250 kS/s, up to 80 Analog Inputs
  • NI recommends high-speed M Series (NI 625x) for 5X faster sampling rates, high-accuracy M Series (NI 628x) for 4X higher resolution, or industrial M Series (NI 623x) for 60 VDC isolation and superior noise rejection
  • 16, 32, or 80 analog inputs at 16 bits, 250 kS/s
  • Up to 4 analog outputs at 16 bits, 833 kS/s (6 μs full-scale settling time)
  • Programmable input range (±10, ±5, ±1, ±0.2 V) per channel
  • Up to 48 TTL/CMOS digital I/O lines (up to 32 hardware-timed at 1 MHz)
  • Two 32-bit, 80 MHz counter/timers
  • Digital triggering
  • X1, X2, or X4 quadrature encoder inputs
OverviewNI M Series low-cost multifunction data acquisition (DAQ) devices provide optimized functionality for cost-sensitive applications. They have up to 80 analog inputs, 48 digital I/O lines, four analog outputs, two counter/timers, and digital triggering. Low-cost M Series devices have a one-year calibration interval. For better accuracy, faster speeds, and an extended two-year calibration service, consider high-speed and high-accuracy M Series devices.
Back to Top
OS Information
  • Windows 2000/XP
  • Windows Vista x64/x86
  • Linux®
  • Mac OS X
Driver Information
  • NI-DAQmx Base
  • NI-DAQmx
Software Compatibility
  • ANSI C
  • LabVIEW
  • LabVIEW SignalExpress
  • Visual Studio .NET
  • Measurement Studio
  • Visual Basic
  • LabWindows/CVI
Back to Top
Comparison TablesFamily
Bus
Analog Inputs
Analog Input Resolution (bits)
Analog Outputs (AO)
AO Resolution (bits)
Max AO Rate (kS/S)
AO Range (V)
Digital I/O
Correlated (clocked) DIO
NI 6220PCI, PXI1616----248, up to 1 MHzNI 6221PCI, PXI, USB1616216833±10248, up to 1 MHzNI 6221 (37-pin)PCI1616216833±10248, up to 1 MHzNI 6224PCI, PXI3216----4832, up to 1 MHzNI 6225PCI, PXI, USB8016216833±10248, up to 1 MHzNI 6229PCI, PXI, USB3216416833±104832, up to 1 MHz
Back to Top
Application and TechnologyM Series for TestFor test, you can use 16-bit, 250 kS/s analog inputs and 1 MHz digital lines with NI signal conditioning for applications including data logging and sensor measurements. Low-cost M Series devices are compatible with the NI SCC and SCXI signal conditioning platforms, which provide amplification, filtering, and power for virtually every type of sensor. These platforms also are compliant with IEEE 1451.4 smart transducer electronic data sheet (TEDS) sensors, which provide digital storage for sensor data sheet information.
M Series for ControlLow-cost M Series digital lines can drive 24 mA for relay and actuator control. With up to four analog outputs, two 80 MHz counter/timers, and six DMA channels, M Series devices can execute multiple control loops simultaneously. Low-cost M Series devices also have direct support for encoder measurements, protected digital lines, and digital debounce filters for control applications. With up to 80 analog inputs, 32 clocked digital lines at rates of 1 MHz, and four analog outputs, you can execute multiple control loops with a single device. For higher-count control loops, you can use M Series devices in conjunction and tightly synchronized with National Instruments analog output devices for 64 or more loops.
M Series for DesignYou can use the wide range of I/O – from 80 analog inputs to 48 digital lines – to measure and verify prototype designs. M Series devices and NI LabVIEW SignalExpress interactive measurement software deliver benchtop measurements to the PC. With LabVIEW SignalExpress interactive configuration-based steps, you can quickly create design verification tests. The fast acquisition and generation rates of low-cost M Series devices along with LabVIEW SignalExpress provide on-the-fly design analysis. You can convert your tested and verified LabVIEW SignalExpress projects to LabVIEW applications for immediate M Series DAQ use and bridge the gap between test, control, and design applications.
Hybrid-Slot-Compatible PXI ModulesPXI M Series modules are hybrid-slot-compatible so that you can use them in both PXI slots and the hybrid slots found in new PXI Express chassis. The PXI Systems Alliance specifies that hybrid-slot-compatible PXI modules use modified slot connectors to mechanically fit in both PXI slots and hybrid slots. This mechanical change:
    Provides compatibility with past, current, and future PXI chassis Maintains existing product specifications Requires no software changes (application or driver)
  • Maintains speed and capability of all PXI communication (PXI Express signaling is not provided)
However, hybrid-slot-compatible PXI modules do not include the pins used to implement PXI local bus communication, which is used for backplane SCXI control from the right-most PXI slot in PXI/SCXI combination chassis (NI PXI-1010, PXI-1011, PXI-1050, and PXI-1052). For these applications, NI provides unmodified PXI M Series modules that maintain the required local bus capabilities. Refer to the SCXI Control of PXI/SCXI Combination Chassis section in the Ordering Information section for part numbers.
Simultaneous and Intelligent Data AcquisitionWhen you need to obtain performance from a data acquisition device beyond the capabilities of a multifunction data acquisition device, National Instruments provides simultaneous sampling with NI S Series and intelligent data acquisition with NI R Series. The S Series architecture dedicates an analog-to-digital converter (ADC) per channel to provide higher aggregate sampling rates compared to multiplexed devices. S Series devices are ideal for applications including IF digitization, transient recording, ultrasound and sonar testing, and high-energy physics. R Series multifunction DAQ devices contain a field-programmable gate array (FPGA) that is reconfigurable using the LabVIEW FPGA Module. R Series multifunction devices combine analog input, analog output, and digital I/O on a single device. You can customize these devices to develop capabilities such as complete control over the synchronization and timing of all signals and operations; user-defined onboard decision-making logic; and digital lines individually configurable as input, output, counter/timers, pulse-width modulation (PWM), flexible encoder inputs, or user-defined communication protocols.
Industrial M SeriesWhen you need performance and accuracy from a data acquisition device in an electrically noisy or harsh environment, consider  industrial NI M Series devices. They offer a set of high-reliability features, including isolation, ±20 mA current I/O, 24 V digital logic levels, and digital debounce filters. Isolation prevents ground loops, rejects high common-mode voltages, and protects users and equipment from high-voltage transients. Four to 20 mA current loops are immune to most sources of electrical noise and voltage (IR) drops along extensive cable lengths. Sourcing or sinking 24 V digital I/O interfaces directly with pumps, valves, relays, and other industry-standard sensors and actuators; programmable debounce filters remove glitches and spikes from switches and relays connected to digital input lines.
Recommended AccessoriesSignal conditioning is required for sensor measurements or voltage inputs greater than 10 V. NI SCXI is a versatile, high-performance signal conditioning platform optimized for high-channel-count applications. NI SCC provides portable, flexible signal conditioning options on a per-channel basis. Visit ni.com/sigcon for NI signal conditioning resources. The NI PCI-6221 (37-Pin) offers a 37-pin D-Sub connector that lowers connectivity costs by 80 percent. The D-Sub connector makes the PCI-6221 (37-Pin) ideal for OEM applications; however, its connector is not compatible with SCC or SCXI signal conditioning.
Recommended Driver SoftwareNational Instruments measurement services software, built around NI-DAQmx driver software, includes intuitive application programming interfaces, configuration tools, I/O assistants, and other tools designed to reduce system setup, configuration, and development time. National Instruments recommends using the latest version of NI-DAQmx driver software for application development in NI LabVIEW and LabWindows™/CVI, ANSI C/C++, C#, Visual Basic .NET, and Visual Basic 6.0. To download the most recent version of NI-DAQmx software, visit ni.com/support/daq/versions. Linux and Mac OS X users can program M Series devices with NI-DAQmx Base driver software. M Series devices are compatible with the following versions (or later) of NI application software – LabVIEW, LabWindows/CVI, or Measurement Studio versions 7.x; LabVIEW SignalExpress 1.x; VI Logger 2.0; or LabVIEW with the LabVIEW Real-Time Module 7.1. M Series devices are not compatible with the Traditional NI-DAQ (Legacy) driver.
NI measurement services software speeds up your development with features including the following:
  • A guide to create fast and accurate measurements with no programming using the DAQ Assistant
  • Automatic code generation to create your application in LabVIEW; LabWindows/CVI; LabVIEW SignalExpress; and C#, Visual Studio .NET, ANSI C/C++, or Visual Basic using Measurement Studio
  • Multithreaded streaming technology for 1,000 times performance improvements
  • Automatic timing, triggering, and synchronization routing to make advanced applications easy
  • Thousands of free software downloads available at ni.com/zone to jump-start your project
  • Software configuration of all digital I/O features without hardware switches/jumpers
  • Single programming interface for analog input, analog output, digital I/O, and counters on hundreds of multifunction DAQ hardware devices
M Series devices are compatible with the following versions (or later) of NI application software – LabVIEW, LabWindows/CVI, or Measurement Studio versions 7.x; and LabVIEW SignalExpress 2.x.
Back to Top
Ordering InformationFor a complete list of accessories, visit the product page on ni.com.
Products
Part Number
Part Number
NI PCI-6220
NI PCI-6220
Each NI PCI-6220 requires: 1 Cable, 1 Connector Block
779065-01   Cable: Shielded - SHC68-68-EPM Cable (2m)
      **Also available: Unshielded
192061-02
   Connector Block: Screw Terminals - SCB-68
      **Also available: BNC Termination
776844-01
NI PXI-6220
NI PXI-6220
Each NI PXI-6220 requires: 1 Cable, 1 Connector Block
779112-01   Cable: Shielded - SHC68-68-EPM Cable (2m)
192061-02
776844-01
NI PCI-6221
NI PCI-6221
Each NI PCI-6221 requires: 1 Cable, 1 Connector Block
779066-01   Cable: Shielded - SHC68-68-EPM Cable (2m)
192061-02
776844-01
NI PCI-6224
NI PCI-6224
Each NI PCI-6224 requires: 2 Cables, 2 Connector Blocks
779067-01
Connector 0:
192061-02
776844-01
Connector 1:
192061-02
776844-01
NI PXI-6224
NI PXI-6224
Each NI PXI-6224 requires: 2 Cables, 2 Connector Blocks
779114-01
Connector 0:
192061-02
776844-01
Connector 1:
192061-02
776844-01
NI PCI-6225
NI PCI-6225
Each NI PCI-6225 requires: 2 Cables, 2 Connector Blocks
779295-01
Connector 0:
192061-02
776844-01
Connector 1:
   Cable: Shielded - SHC68-68 Cable (2m)
191945-02
776844-01
NI PXI-6225
NI PXI-6225
Each NI PXI-6225 requires: 2 Cables, 2 Connector Blocks
779296-01
Connector 0:
192061-02
776844-01
Connector 1:
191945-02
776844-01
NI PCI-6229
NI PCI-6229
Each NI PCI-6229 requires: 2 Cables, 2 Connector Blocks
779068-01
Connector 0:
   Cable: Shielded - SHC68-68-EPM Cable (1m)
192061-01
776844-01
Connector 1:
192061-01
776844-01
NI PXI-6229
NI PXI-6229
Each NI PXI-6229 requires: 2 Cables, 2 Connector Blocks
779630-01
Connector 0:
192061-02
776844-01
Connector 1:
192061-02
776844-01
NI PXI-6229 for SCXI Control in PXI/SCXI Combination Chassis
Each NI PXI-6229 for SCXI Control in PXI/SCXI Combination Chassis requires: 2 Cables, 2 Connector Blocks
779115-01
Connector 0:
192061-02
776844-01
Connector 1:
192061-02
776844-01
NI PXI-6221
NI PXI-6221
Each NI PXI-6221 requires: 1 Cable, 1 Connector Block
779629-01   Cable: Shielded - SHC68-68-EPM Cable (2m)
192061-02
776844-01
NI PXI-6221 for SCXI Control in PXI/SCXI Combination Chassis
Each NI PXI-6221 for SCXI Control in PXI/SCXI Combination Chassis requires: 1 Cable, 1 Connector Block
779113-01   Cable: Shielded - SHC68-68-EPM Cable (2m)
192061-02
776844-01
NI PCI-6221 37-pin
NI PCI-6221 37-pin
Each NI PCI-6221 37-pin requires: 1 Cable, 1 Connector Block
779418-01Cable: Shielded - SH37F-37M Cable (2m)778621-02
Connector Block: Screw Terminals - CB-37FH778673-01
Back to Top
Software Recommendations
NI LabVIEW Professional Development System for Linux®
  • Easy-to-use graphical development environment
  • Rapid user interface development for displaying live data
  • Extensive signal processing, analysis, and math functionality
  • Source code control integration and code complexity metrics
  • Tight integration with a wide range of measurement hardware
  • Multiple communication options (TCP/IP, UDP, serial, and more)
NI Measurement Studio Professional Edition
  • Base analysis and instrumentation components for Microsoft Visual Basic, Visual C#, and Visual C++
  • Cross-platform communication with network variables
  • Scientific user interface controls
  • Code-generating DAQ Assistant and Instrument I/O Assistant
  • Acquire data from GPIB, serial, Ethernet, and plug-in data acquisition devices
  • Requires Microsoft Visual Studio 2008/2005/.NET 2003 or Visual Studio 6.0
NI LabWindows™/CVI for Windows
  • Real-time advanced 2D graphs and charts with support for Windows Vista/XP/2000
  • Complete hardware compatibility with IVI, VISA, DAQ, GPIB, and serial
  • Analysis tools for array manipulation, signal processing statistics, and curve fitting
  • Simplified cross-platform communication with network variables
  • Measurement Studio .NET tools (included in LabWindows/CVI Full only)
  • The mark LabWindows is used under a license from Microsoft Corporation.
NI LabVIEW SignalExpress for Windows
  • Quickly configure projects without programming
  • Control over 400 PC-based and stand-alone instruments
  • Log data from more than 250 data acquisition devices
  • Perform basic signal processing, analysis, and file I/O
  • Scale your application with automatic LabVIEW code generation
  • Create custom reports or easily export data to LabVIEW, DIAdem or Microsoft Excel
Back to Top
Support and ServicesSystem Assurance ProgramsNI system assurance programs are designed to make it even easier for you to own an NI system. These programs include configuration and deployment services for your NI PXI, CompactRIO, or Compact FieldPoint system. The NI Basic System Assurance Program provides a simple integration test and ensures that your system is delivered completely assembled in one box. When you configure your system with the NI Standard System Assurance Program, you can select from available NI system driver sets and application development environments to create customized, reorderable software configurations. Your system arrives fully assembled and tested in one box with your software preinstalled. When you order your system with the standard program, you also receive system-specific documentation including a bill of materials, an integration test report, a recommended maintenance plan, and frequently asked question documents. Finally, the standard program reduces the total cost of owning an NI system by providing three years of warranty coverage and calibration service. Use the online product advisors at ni.com/advisor to find a system assurance program to meet your needs.
CalibrationNI measurement hardware is calibrated to ensure measurement accuracy and verify that the device meets its published specifications. To ensure the ongoing accuracy of your measurement hardware, NI offers basic or detailed recalibration service that provides ongoing ISO 9001 audit compliance and confidence in your measurements. To learn more about NI calibration services or to locate a qualified service center near you, contact your local sales office or visit ni.com/calibration.
Technical SupportGet answers to your technical questions using the following National Instruments resources.
  • Support - Visit ni.com/support to access the NI KnowledgeBase, example programs, and tutorials or to contact our applications engineers who are located in NI sales offices around the world and speak the local language.
  • Discussion Forums - Visit forums.ni.com for a diverse set of discussion boards on topics you care about.
  • Online Community - Visit community.ni.com to find, contribute, or collaborate on customer-contributed technical content with users like you.
RepairWhile you may never need your hardware repaired, NI understands that unexpected events may lead to necessary repairs. NI offers repair services performed by highly trained technicians who quickly return your device with the guarantee that it will perform to factory specifications. For more information, visit ni.com/repair.
Training and CertificationsThe NI training and certification program delivers the fastest, most certain route to increased proficiency and productivity using NI software and hardware. Training builds the skills to more efficiently develop robust, maintainable applications, while certification validates your knowledge and ability.
  • Classroom training in cities worldwide - the most comprehensive hands-on training taught by engineers.
  • On-site training at your facility - an excellent option to train multiple employees at the same time.
  • Online instructor-led training - lower-cost, remote training if classroom or on-site courses are not possible.
  • Course kits - lowest-cost, self-paced training that you can use as reference guides.
  • Training memberships and training credits - to buy now and schedule training later.
Visit ni.com/training for more information.
Extended WarrantyNI offers options for extending the standard product warranty to meet the life-cycle requirements of your project. In addition, because NI understands that your requirements may change, the extended warranty is flexible in length and easily renewed. For more information, visit ni.com/warranty.
OEMNI offers design-in consulting and product integration assistance if you need NI products for OEM applications. For information about special pricing and services for OEM customers, visit ni.com/oem.
AllianceOur Professional Services Team is comprised of NI applications engineers, NI Consulting Services, and a worldwide National Instruments Alliance Partner program of more than 600 independent consultants and integrators. Services range from start-up assistance to turnkey system integration. Visit ni.com/alliance.
Back to Top
Detailed SpecificationsView Detailed Specifications Table of Contents Analog InputAnalog OutputCalibration (AI and AO)Digital I/O/PFIGeneral-Purpose Counter/TimersFrequency GeneratorPhase-Locked Loop (PLL)External Digital TriggersBus InterfacePower RequirementsPower LimitsPhysical RequirementsMaximum Working Voltage12EnvironmentalSafetyElectromagnetic CompatibilityCE ComplianceEnvironmental Management
Specifications listed below are typical at 25 °C unless otherwise noted. Refer to the M Series User Manual for more information about NI 622x devices.
Analog Input
Number of channels
NI 6220/6221
8 differential or 16 single ended
NI 6224/6229
16 differential or 32 single ended
NI 6225
40 differential or 80 single ended
ADC resolution
16 bits
DNL
No missing codes guaranteed
INL
Refer to the AI Absolute Accuracy Table
Sampling rate
Maximum
250 kS/s single channel,
250 kS/s multi-channel (aggregate)
Minimum
No minimum
Timing accuracy
50 ppm of sample rate
Timing resolution
50 ns
Input coupling
DC
Input range
±10 V, ±5 V, ±1 V, ±0.2 V
Maximum working voltage for analog inputs (signal + common mode)
±11 V of AI GND
CMRR (DC to 60 Hz)
92 dB
Input impedance
Device on
AI+ to AI GND
>10 GΩ in parallel with 100 pF
AI- to AI GND
Device off
AI+ to AI GND
820 Ω
AI- to AI GND
820 Ω
Input bias current
±100 pA
Crosstalk (at 100 kHz)
Adjacent channels
-75 dB
Non-adjacent channels
-90 dB1
Small signal bandwidth (-3 dB)
700 kHz
Input FIFO size
4,095 samples
Scan list memory
4,095 entries
Data transfers
PCI/PXI devices
DMA (scatter-gather), interrupts, programmed I/O
USB devices
USB Signal Stream, programmed I/O
Overvoltage protection (AI <0..79>, AI SENSE, AI SENSE 2)
Device on
±25 V for up to two AI pins
Device off
±15 V for up to two AI pins
Input current during overvoltage condition
±20 mA max/AI pin
1 For USB-6225 devices, channel AI <0..15> crosstalk to channel AI <64..79> is -71 dB; applies to channels with 64-channel separation, for example, AI (x) and AI (x + 64).
Settling Time for Multichannel Measurements
Accuracy, full scale step, all ranges
±90 ppm of step (±6 LSB)
4 μs convert interval
±30 ppm of step (±2 LSB)
5 μs convert interval
±15 ppm of step (±1 LSB)
7 μs convert interval
Typical Performance Graphs
Analog Output
Back to Detailed Specs
Number of channels
NI 6220/6224
0
NI 6221/6225
2
NI 6229
4
DAC resolution
16 bits
DNL
±1 LSB
Monotonicity
16 bit guaranteed
Maximum update rate
1 channel
833 kS/s
2 channels
740 kS/s per channel
3 channels
666 kS/s per channel
4 channels
625 kS/s per channel
Timing accuracy
Timing resolution
50 ns
Output range
±10 V
Output coupling
DC
Output impedance
0.2 Ω
Output current drive
±5 mA
Overdrive protection
±25 V
Overdrive current
10 mA
Power-on state
±20 mV2
Power-on glitch
400 mV for 200 ms
Output FIFO size
8,191 samples shared among channels used
Data transfers
PCI/PXI devices
USB devices
AO waveform modes:
  • Non-periodic waveform
  • Periodic waveform regeneration mode from onboard FIFO
  • Periodic waveform regeneration from host buffer including dynamic update
Settling time, full scale step 15 ppm (1 LSB)
6 μs
Slew rate
15 V/μs
Glitch energy
Magnitude
100 mV
Duration
2.6 μs
2 For all USB-6221/6229 Screw Terminal devices, when powered on, the analog output signal is not defined until after USB configuration is complete.
Recommended warm-up time
15 minutes
Calibration interval
1 year
Nominal RangeResidual
Gain
Error
(ppm of
Reading)
Gain
Tempco
(ppm/°C)
Reference
Tempco
Residual
Offset
Error
(ppm of
Range)
Offset
Tempco
(ppm of
Range/°C)
INL Error
(ppm of
Range)
Random
Noise,
σ (&micro;Vrms)
Absolute
Accuracy
at
Full
Scale1 (&micro;V)
Sensitivity2
(&micro;V)
Positive
Full
Scale
Negative
Full
Scale
10-10752552057762443,10097.6
5-5852552060761221,62048.8
1-1952552579763036012.0
0.2-0.21352558017576131125.2
AbsoluteAccuracy = Reading · (GainError) + Range · (OffsetError) + NoiseUncertainty
GainError = ResidualAIGainError + GainTempco · (TempChangeFromLastInternalCal) + ReferenceTempco · (TempChangeFromLastExternalCal)
OffsetError = ResidualAIOffsetError + OffsetTempco · (TempChangeFromLastInternalCal) + INL_Error
1 Absolute accuracy at full scale on the analog input channels is determined using the following assumptions:
TempChangeFromLastExternalCal = 10 °C
TempChangeFromLastInternalCal = 1 °C
number_of_readings = 100
CoverageFactor = 3 σ
For example, on the 10 V range, the absolute accuracy at full scale is as follows:
GainError = 75 ppm + 25 ppm · 1 + 5 ppm · 10     GainError = 150 ppm
OffsetError = 20 ppm + 57 ppm · 1 + 76 ppm       OffsetError = 153 ppm
AbsoluteAccuracy = 10 V · (GainError) + 10 V · (OffsetError) + NoiseUncertainty AbsoluteAccuracy = 3,100 μV
2 Sensitivity is the smallest voltage change that can be detected. It is a function of noise.
Accuracies listed are valid for up to one year from the device external calibration.
AO Absolute Accuracy Table
Gain Error
(ppm of
Reading)
Gain
Tempco
(ppm/°C)
Reference
Tempco
Residual
Offset Error
(ppm of
Range)
Offset
Tempco
(ppm of
Range/°C)
INL
Error
(ppm of
Range)
Absolute
Accuracy at
Full
Scale1
(&micro;V)
Positive
Full
Scale
Negative
Full
Scale
10-10901054051283,230
1 Absolute Accuracy at full scale numbers is valid immediately following internal calibration and assumes the device is operating within 10 °C of the last external calibration. Accuracies listed are valid for up to one year from the device external calibration.
AbsoluteAccuracy = OutputValue · (GainError) + Range · (OffsetError)
GainError = ResidualGainError + GainTempco · (TempChangeFromLastInternalCal) + ReferenceTempco · (TempChangeFromLastExternalCal)
OffsetError = ResidualOffsetError + AOOffsetTempco · (TempChangeFromLastInternalCal) + INL_Error
Digital I/O/PFI
Static Characteristics
Number of channels
NI 6220/6221 (68-pin)/6225
24 total
8 (P0.<0..7>) 16 (PFI <0..7>/P1, PFI <8..15>/P2)
PCI-6221 (37-pin)
10 total
2 (P0.<0, 1>) 8 (PFI <0..7>/P1)
NI 6224/6229
48 total
32 (P0.<0..31>) 16 (PFI <0..7>/P1, PFI <8..15>/P2)
Ground reference
D GND
Direction control
Each terminal individually programmable as input or output
Pull-down resistor
50 kΩ typical, 20 kΩ minimum
Input voltage protection3
±20 V on up to two pins
3 Stresses beyond those listed under Input voltage protection may cause permanent damage to the device.
Waveform Characteristics (Port 0 Only)
Terminals used
Port 0 (P0.<0..7>)
PCI-6221 (37-pin)
Port 0 (P0.<0, 1>)
NI 6224/6229
Port 0 (P0.<0..31>)
Port/sample size
Up to 8 bits
PCI-6221 (37-pin)
Up to 2 bits
NI 6224/6229
Up to 32 bits
Waveform generation (DO) FIFO
2,047 samples
Waveform acquisition (DI) FIFO
2,047 samples
DI or DO Sample Clock frequency4
0 to 1 MHz
Data transfers
PCI/PXI devices
USB devices
DO or DI Sample Clock source5
Any PFI, RTSI, AI Sample or Convert Clock, AO Sample Clock, Ctr n Internal Output, and many other signals
4 Performance can be dependent on bus latency and volume of bus activity.
5 The digital subsystem does not have its own dedicated internal timing engine. Therefore, a sample clock must be provided from another subsystem on the device or an external source.
PFI/Port 1/Port 2 Functionality6
Functionality
Static digital input, static digital output, timing input, timing output
Timing output sources
Many AI, AO, counter, DI, DO timing signals
Debounce filter settings
125 ns, 6.425 &micro;s, 2.56 ms, disable; high and low transitions; selectable per input
6 Port 2 is not available on PCI-6221 (37-pin) devices.
Recommended Operation Conditions, PCI/PXI Devices
Level
Min
Max
Input high voltage (VIH)2.2 V5.25 V
Input low voltage (VIL)0 V0.8 V
Output high current (IOH)
   P0.<0..31>
   PFI <0..15>/P1/P2
-24 mA
-16 mA
Output low current (IOL)
   P0.<0..31>
   PFI <0..15>/P1/P2
24 mA
16 mA
Recommended Operation Conditions, USB Devices
Level
Min
Max
   P0.<0..15>
   P0.<16..31>
   PFI <0..15>/P1/P2
-24 mA
-16 mA
-16 mA
   P0.<0..15>
   P0.<16..31>
   PFI <0..15>/P1/P2
24 mA
16 mA
16 mA
Electrical Characteristics
Level
Min
Max
Positive-going threshold (VT+)
Negative-going threshold (VT-)
0.8 V
2.2 V
Delta VT hysteresis (VT+ - VT-)0.2 V—
IIL input low current (Vin = 0 V) IIH input high current (Vin = 5 V)
-10 &micro;A 250 &micro;A
Digital I/O Characteristics6
Number of counter/timers
2
Resolution
32 bits
Counter measurements
Edge counting, pulse, semi-period, period, two-edge separation
Position measurements
X1, X2, X4 quadrature encoding with Channel Z reloading; two-pulse encoding
Output applications
Pulse, pulse train with dynamic updates, frequency division, equivalent time sampling
Internal base clocks
80 MHz, 20 MHz, 0.1 MHz
External base clock frequency
0 MHz to 20 MHz
Base clock accuracy
50 ppm
Inputs
Gate, Source, HW_Arm, Aux, A, B, Z, Up_Down
Routing options for inputs
Any PFI, RTSI, PXI_TRIG, PXI_STAR, analog trigger, many internal signals
FIFO
2 samples
Data transfers
PCI/PCIe/PXI/PXIe devices
Dedicated scatter-gather DMA controller for each counter/timer; interrupts, programmed I/O
USB devices
Frequency Generator
Number of channels
1
Base clocks
10 MHz, 100 kHz
Divisors
1 to 16
Base clock accuracy
50 ppm
Output can be available on any PFI or RTSI terminal.
Number of PLLs
1
Reference signal
PXI_STAR, PXI_CLK10, RTSI <0..7>
Output of PLL
80 MHz Timebase; other signals derived from 80 MHz Timebase including 20 MHz and 100 kHz Timebases
Source
Polarity
Software-selectable for most signals
Analog input function
Start Trigger, Reference Trigger, Pause Trigger, Sample Clock, Convert Clock, Sample Clock Timebase
Analog output function
Start Trigger, Pause Trigger, Sample Clock, Sample Clock Timebase
Counter/timer functions
Digital waveform generation (DO) function
Sample Clock
Digital waveform acquisition (DI) function
Sample Clock
Device-To-Device Trigger Bus
PCI/PCIe devices
RTSI <0..7>7
PXI/PXIe devices
PXI_TRIG <0..7>, PXI_STAR
USB devices
None
Output selections
10 MHz Clock; frequency generator output; many internal signals
7 In other sections of this document, RTSI refers to RTSI <0..7> for PCI devices or PXI_TRIG <0..7> for PXI devices.
Bus Interface
PCI/PXI devices
3.3 V or 5 V signal environment
USB devices
USB 2.0 Hi-Speed or full-speed8
DMA channels (PCI/PXI devices)
6, analog input, analog output, digital input, digital output, counter/timer 0, counter/timer 1
USB Signal Stream (USB devices)
4, can be used for analog input, analog output, digital input, digital output, counter/timer 0, counter/timer 1
All PXI-625x devices support one of the following features:
    May be installed in PXI Express hybrid slots
  • Or, may be used to control SCXI in PXI/SCXI combo chassis
8 If you are using a USB M Series device in full-speed mode, device performance will be lower and you will not be able to achieve maximum sampling/update rates.
Table 1. PXI/SCXI Combo and PXI Express Chassis Compatibility
M Series DeviceM Series Part NumberSCXI Control in PXI/SCXI Combo ChassisPXI Express Hybrid Slot Compatible
PXI-6220
191332B-04NoYes
PXI-6221191332B-03NoYes
191332B-13YesNo
PXI-6224191332B-02NoYes
PXI-6225192227A-01NoYes
PXI-6229
191332B-01NoYes
191332B-11YesNo
Earlier versions of PXI-6220/6221/6224/6229191332A-0xYesNo
Power Requirements
Current draw from bus during no-load condition9
PCI/PXI devices
+5 V
0.02 A10
+3.3 V
0.25 A10
+12 V
0.15 A
Current draw from bus during AI and AO overvoltage condition9
PCI/PXI devices
+5 V
0.02 A10
+3.3 V
0.25 A10
+12 V
0.25 A
Caution USB-622x devices must be powered with NI offered AC adapter or a National Electric Code (NEC) Class 2 DC source that meets the power requirements
for the device and has appropriate safety certification marks for country of use.
USB power supply requirements
11 to 30 VDC, 20 W, locking or non-locking power jack with 0.080" diameter center pin, 5/16-32 thread for locking collars
9 Does not include P0/PFI/P1/P2 and +5 V terminals.
10 PCI-6221 (37-pin) devices do not use +3.3 V from the bus. The 3.3 V current draw, shown in the Power Requirements section, comes from the +5 V instead.
Power Limits
Caution  Exceeding the power limits may cause unpredictable behavior by the device and/or PC/chassis.
PCI devices
+5 V terminal (connector 0)
1 A max11
+5 V terminal (connector 1)
1 A max11
PXI devices
1 A max11
1 A max11
P0/PFI/P1/P2 and +5 V terminals combined
2 A max
USB devices
+5 V terminal
1 A max11
2 A max
Power supply fuse
2 A, 250 V
11 Has a self-resetting fuse that opens when current exceeds this specification.
Printed circuit board dimensions
PCI-6220/6221/6224/6225/6229
9.7 x 15.5 cm (3.8 x 6.1 in.)
PXI-6220/6221/6224/6225/6229
Standard 3U PXI
Enclosure dimensions (includes connectors)
USB-6221/6225/6229 Screw Terminal
26.67 x 17.09 x 4.45 cm (10.5 x 6.73 x 1.75 in.)
USB-6221/6229 BNC
28.6 x 17 x 6.9 cm (11.25 x 6.7 x 2.7 in.)
USB-6225 Mass Termination
18.8 x 17.09 x 4.45 cm (7.4 x 6.73 x 1.75 in.)
USB-6221/6225/6229 OEM
Refer to the NI USB-622x/625x OEM User Guide
Weight
PCI-6220
91 g (3.2 oz)
PCI-6221 (68-pin)
92 g (3.2 oz)
PCI-6221 (37-pin)
95 g (3.3 oz)
PCI-6224
99 g (3.5 oz)
PCI-6225
103 g (3.6 oz)
PCI-6229
101 g (3.5 oz)
PXI-6220
158 g (5.5 oz)
PXI-6221
162 g (5.7 oz)
PXI-6224
170 g (5.9 oz)
PXI-6225
174 g (6.1 oz)
PXI-6229
171 g (6.0 oz)
USB-6221 Screw Terminal
1.2 kg (2 lb 10 oz)
USB-6225/6229 Screw Terminal
1.24 kg (2 lb 11 oz)
907 g (2 lb)
USB-6221 OEM
131 g (4.6 oz)
USB-6225/6229 OEM
162 g (5.7 oz)
I/O connector
PCI/PXI-6220/6221 (68-pin)
1 68-pin VHDCI
PCI/PXI-6224/6225/6229
2 68-pin VHDCI
PCI-6221 (37-pin)
1 37-pin D-SUB
64 screw terminals
128 screw terminals
USB-6221 BNC
21 BNCs and 30 screw terminals
USB-6229 BNC
32 BNCs and 60 screw terminals
2 68-pin SCSI
USB-6221/6225/6229 Screw Terminal/
USB-6221/6229 BNC screw terminal wiring
16-28 AWG
Maximum Working Voltage12Back to Detailed Specs
NI 6220/6221/6224/6225/6229 channel-to-earth
11 V, Measurement Category I
Caution  Do not use for measurements within Categories II, III, or IV.
12 Maximum working voltage refers to the signal voltage plus the common-mode voltage.
EnvironmentalBack to Detailed Specs
Operating temperature
PCI/PXI devices
0 to 55 °C
USB devices
0 to 45 °C
Storage temperature
-20 to 70 °C
Humidity
10 to 90% RH, noncondensing
Maximum altitude
2,000 m
Pollution Degree (indoor use only)
2
Shock and Vibration (PXI Devices Only)
Operational shock
30 g peak, half-sine, 11 ms pulse
(Tested in accordance with IEC-60068-2-27. Test profile developed in accordance with MIL-PRF-28800F.)
Random vibration
Operating
5 to 500 Hz, 0.3 grms
Nonoperating
5 to 500 Hz, 2.4 grms
(Tested in accordance with IEC-60068-2-64. Nonoperating test profile exceeds the requirements of MIL-PRF-28800F, Class 3.)
SafetyBack to Detailed Specs
This product is designed to meet the requirements of the following standards of safety for electrical equipment for measurement, control, and laboratory use:
  • IEC 61010-1, EN 61010-1
  • UL 61010-1, CSA 61010-1
Note For UL and other safety certifications, refer to the product label or visit ni.com/certification, search by model number or product line, and click the appropriate link in the Certification column.
This product is designed to meet the requirements of the following standards of EMC for electrical equipment for measurement, control, and laboratory use:
  • EN 61326 EMC requirements; Minimum Immunity
  • EN 55011 Emissions; Group 1, Class A
  • CE, C-Tick, ICES, and FCC Part 15 Emissions; Class A
Note For EMC compliance, operate this device with shielded cables.
CE Compliance
This product meets the essential requirements of applicable European Directives, as amended for CE marking, as follows:
  • 73/23/EEC; Low-Voltage Directive (safety)
  • 89/336/EEC; Electromagnetic Compatibility Directive (EMC)
Note Refer to the Declaration of Conformity (DoC) for this product for any additional regulatory compliance information. To obtain the DoC for this product, visit ni.com/certification, search by model number or product line, and click the appropriate link in the Certification column.
National Instruments is committed to designing and manufacturing products in an environmentally responsible manner. NI recognizes that eliminating certain hazardous substances from our products is beneficial not only to the environment but also to NI customers.
For additional environmental information, refer to the NI and the Environment Web page at ni.com/environment. This page contains the environmental regulations and directives with which NI complies, as well as other environmental information not included in this document.
Waste Electrical and Electronic Equipment (WEEE)
At the end of their life cycle, all products must be sent to a WEEE recycling center. For more information about WEEE recycling centers and National Instruments WEEE initiatives, visit ni.com/environment/weee.htm.
Back to Top
PCI/PXI-6220 Pinout
PCI/PXI-6221 (68-Pin) Pinout
PCI-6221 (37-Pin) Pinout
PCI/PXI-6224 Pinout
PCI/PXI-6225 Pinout
PCI/PXI-6229 Pinout
Back to Top
&copy;2008 National Instruments. All rights reserved. CVI, LabVIEW, Measurement Studio, National Instruments, NI, ni.com, SCXI, and SignalExpress are trademarks of National Instruments. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Linux&reg; is the registered trademark of Linus Torvalds in the U.S. and other
countries. Other product and company names listed are trademarks or trade names of their respective companies.
 楼主| 发表于 2009-12-18 09:43:20 | 显示全部楼层
asd030625 该用户已被删除
发表于 2011-4-12 09:37:04 | 显示全部楼层
你现在能用采集卡来控制步进电机精确转动了没有啊??
GMT+8, 2026-9-28 08:38 , Processed in 0.039131 second(s), 8 queries , Gzip On, File On.
