查看: 2183|回复: 2
LV驱动程序DAQ下载网址
发表于 2004-12-31 22:09:49 | 显示全部楼层 |阅读模式
<>NI-DAQ Version 7.3 for Windows 2000/NT/XP</P>
<>ftp://ftp.ni.com/support/daq/pc/ni-daq/7.3/install.txt(安装指南 (1.55KB))</P>
<>ftp://ftp.ni.com/support/daq/pc/ni-daq/7.3/NIDAQ730CD1.zip(NI-DAQ CD1 Installation File (498 MB))</P>
<P>ftp://ftp.ni.com/support/daq/pc/ni-daq/7.3/NIDAQ730CD2.zip(NI-DAQ CD2 Installation and Device Documentation File (164 MB))</P>
<P>ftp://ftp.ni.com/support/daq/pc/ni-daq/7.3/readme.html(English ReadMe文档 (39.4 KB))</P>
<P>[/url]http://www.ni.com/pdf/products/zhs/daq_user_manual.pdf[/url]NI-DAQ 7中文版快速入门指南 (PDF文档)</P>
[此贴子已经被作者于2004-12-31 14:11:48编辑过]
 楼主| 发表于 2004-12-31 22:10:31 | 显示全部楼层
产品类别: 多功能数据采集设备
<B>版本:</B> 7.3
<B>类别:</B> 硬件驱动
<B>操作平台:</B> Windows 2000; Windows NT; Windows XP
<B>描述:</B> NI-DAQ for PC Compatibles, version 7.3 for Windows XP/2000/NT
NI-DAQ 7.3 包括三个API(应用程序编程界面),他们包括用来对您的硬件设备进行编程的诸多函数和VI程序库,参数及属性灯。这些API包括传统的NI-DAQ,NI-DAQmx以及NI-SWITCH。
NI-DAQmx 7.3是最新版的数据采集和信号调理系统硬件设备驱动软件,它兼备简单易用性和强大功能性,因为: 利用DAQ Assistant快速完成测量任务 自动检测到即插即用的TEDS传感器并对其进行配置 动态地显示每个已配置好的通道的端口连接情况 利用新的NI-DAQmx VI程序、函数和工具创建更加准确的代码 单点采样的速度可达到50kHz——是以往版本的20倍 使用新的多线程功能防止同步操作时可能造成的堵塞 更好的RT(实时)应用系统开发性能 更多...
The installation files for NI-DAQ 7.2 are spread across two different volumes. The first volume, CD1, contains the components necessary for installing NI-DAQmx and Traditional NI-DAQ. The second volume, CD 2, contains the components necessary to install NI-Switch and all of the NI-DAQ device documentation. If you only want to install NI-DAQmx and/or Traditional DAQ, you only need to download the first volume, NIDAQ720CD1.zip. Note that when running the installer, you will need to deselect NI-Switch from the list the features to be installed.
<B>安装指导: </B>Create a temporary folder on your local hard drive. Extract the <B>NIDAQ730CD1.zip</B> file into the folder created in Step 1. This will create the installation files necessary for installing NI-DAQmx and Traditional NI-DAQ. To install NI-Switch and/or the device documentation, create a second temporary folder on your local hard drive and extract <B>NIDAQ730CD2.zip</B> into it. This will create the installation files necessary for installing NI-Switch and/or the device documentation. To launch the NI-DAQ installer, run the <B>setup.exe</B> program created in Step 2. To launch the NI-DAQ Device Documentation Browser, run the <B>setup.exe</B> created in step 3 and follow the on-screen instructions.
<B>压缩方式:</B> WinZip
<B>更新日期: </B>2004-04-13
 楼主| 发表于 2004-12-31 22:12:43 | 显示全部楼层
为了不要大家次次找网址找得哪么辛苦,所以我把它找出来了,大家直接点击就可以了,不用大家都浪费时间!
GMT+8, 2026-9-28 10:42 , Processed in 0.026898 second(s), 6 queries , Gzip On, File On.
