查看: 27|回复: 0
MLB The Show 26: U4GM Tips for 2026 Finest 2 Program Missions
发表于 6 天前 | 显示全部楼层 |阅读模式
The 2026 Finest 2 Program gives MLB The Show 26 Diamond Dynasty players plenty of reasons to spend more time building their squads. With 12 reward milestones and multiple mission categories, there are several ways to earn Program Points without relying on one type of game mode. The trick is to use eligible players whenever possible, allowing hits, strikeouts, innings, and Parallel XP to count toward multiple objectives. If you're also planning to improve your roster outside the program, MLB Stubs can provide additional flexibility when preparing for future upgrades.
1. Complete Moments First for Easy Points
The five designated Finest 2 Moments are a good place to start. Each challenge awards six Program Points, giving you 30 points for completing the entire set.
These Moments feature:
• Jake McCarthy
• Otto Lopez
• Drake Baldwin
• Rafael Devers
• Yoshinobu Yamamoto
There is another opportunity to earn points through the previous Finest program. Collecting 99 OVR Finest Pete Crow-Armstrong from Finest 1 provides 20 bonus points toward Finest 2.
That means players who already own Crow-Armstrong can secure a combined 50 points from the Moments and collection bonus. If you haven't completed Finest 1 yet, this is another reason to check its remaining rewards.
2. Focus on Finest 2 Player Missions
Once you've unlocked a few cards, put them straight into your lineup and pitching rotation. The program-specific missions reward players for using the new Finest 2 cards.
Here are the main objectives:
• Record 5 hits: Earn 10 Program Points.
• Pitch 5 innings: Earn 10 Program Points.
• Earn 500 Parallel XP: Earn 10 Program Points.
• Earn 1,500 Parallel XP: Earn 10 Program Points.
• Earn 2,500 Parallel XP: Earn 10 Program Points.
These missions are easier to manage when you rotate eligible players into your regular squad. For example, use Finest 2 hitters to work toward the hit and PXP objectives while assigning an eligible pitcher to handle innings.
You can also buy MLB Stubs if you're planning other Diamond Dynasty roster improvements alongside your program grind.
3. Take Advantage of 2026 Finest Series Missions
The wider Finest Series missions offer another source of Program Points. Unlike the player-specific objectives, these challenges cover several general baseball statistics.
The available missions include:
• Record 15 hits for 5 points.
• Record 8 extra-base hits for 5 points.
• Pitch 10 innings for 5 points.
• Record 15 strikeouts for 5 points.
• Accumulate 5,000 Parallel XP with eligible Finest Series players for 10 points.
One important detail is card eligibility. Not every card with Finest in its name necessarily qualifies. Retro Finest cards, for example, should not be confused with the 2026 Finest Series when checking mission requirements.
4. Complete General Missions Along the Way
General statistical objectives are useful because they don't require a specific Finest card. You can make progress with your regular Diamond Dynasty roster.
There are three main targets:
• 26 hits: 10 Program Points.
• 26 innings pitched: 10 Program Points.
• 26 strikeouts: 10 Program Points.
Try to complete these objectives naturally while working through the other missions. There's little reason to play separate games for every target when one session can contribute to several challenges.
5. Don't Forget the Repeatable PXP Missions
Players who want additional progress have two repeatable Parallel XP objectives to consider:
• Earn 4,000 PXP with Finest 2 players for 10 points.
• Earn 6,000 PXP with eligible Finest Series players for 10 points.
These are particularly useful if you've already finished the easier statistical challenges but still need more Program Points.
Check your progress between games, replace completed objectives with new ones, and keep your eligible pitchers and hitters in regular rotation. Having cheap MLB Stubs available can also help when you're considering additional squad upgrades.
Best Strategy for Finishing Finest 2
The most efficient approach is to complete Moments first, claim any available collection bonus, and then build a lineup around eligible Finest players. Prioritize missions that overlap instead of focusing on one objective at a time.
Finest 2 rewards consistent play rather than complicated strategies. Make every hit, inning, and strikeout count, and you'll have a much smoother path through the program. Whether you're chasing the final Yoshinobu Yamamoto reward or simply expanding your collection, cheap MLB Stubs for sale are another option to consider as you prepare for your next Diamond Dynasty challenge.
GMT+8, 2026-11-12 07:39 , Processed in 0.028157 second(s), 5 queries , Gzip On, Redis On.
